Loader put some hooks on the loader
/ put some hooks on the loader #1
papachaz
Gold Member
Cedartown GA
LS XG 3025 shuttle w/LL 3110 FEL
I've already been out clearing part of the yard that's grown up with privet and scrub. Yesterday I needed the hooks on the loader to pick up and drag out a couple of the trees I pushed over. Hooks have been here all week, just haven't gotten them on yet. Decided instead of going and playing and pushing stuff over again, I needed to get the hooks on first. put 3 on, 1 in front of each of the loader arms, the other in the middle
I'm not a pro welder by any means, and my little mig welder requires multiple passes. If I could just make the second pass look as good as the first one....oh well I can't remember the last weld that failed, even the bird poo ones :laughing:
/ put some hooks on the loader #2
Every bucket should have these hooks installed by default. I do not know why manufactures do not include them.
Nice job!
Nice job!
thanks! I agree they should be on there from the manufacturer
I do...Liability. It's a "loader" not a lifting device.
but aren't you 'lifting' with it while you're loading?? ;)
pic with it on the tractor. one centered, the others in line with the loader arms
/ put some hooks on the loader #6
Yeah, I know. Liability is everything nowadays. :muttering:
ain't the truth. start with the lawyers.....reminds me of a old joke
"what do you have if you have 10,000 lawyers at the bottom of the ocean"?
answer: "a good start"
:D
/ put some hooks on the loader #8
I welded my hooks to a length of 3/16" 2 by 3 angle iron and then welded the angle iron to the top of the loader. As for the hooks, I screwed up 2 ways:
5/16" chain is plenty. But I started with 3/8" and stuck with too heavy chain.
Weld the center hook first. Place outside hooks where you want them then, using chain as a guide, scootch them into position so that the links line up snug. Forgot that last part and chain droops and sometimes falls out.
But it has held up to a lot of abuse so I did okay. No bending of loader top lip.
~Bob
~Bob
that's one advantage of welding on the 'bolt on' hooks, they're already on the plate. I also welded up the holes where the bolts would have gone, so some extra holding power
/ put some hooks on the loader #10
A bit different type of loading that can also get you in trouble. Think a swinging load or highly unbalanced.
That said, I have put two hooks at roughly the quarter points on bucket on my BX. I didn't know where I wanted them as I was a newbie to tractors then, so I ended paying a premium and bought the BXpanded bucket hooks. I really like them and they are easily removable/movable. After 5 years, I haven't moved them so I wouldn't recommend them if you don't mind welding on your bucket.
I would also recommend installing a D ring in the center maybe on the backside, if you put a couple hooks on the outside near the top. The D ring with a shackle is more secure.
/ put some hooks on the loader #11
That was one of the first things i did is order 3 5/16 weld on hooks so far i have only one welded on in the middle will get the other two later when it gets cool.
/ put some hooks on the loader #12
I added these about two weeks ago to my front end loader.
/ put some hooks on the loader #14
That is good loking welding bead, my welding is not that pretty.
/ put some hooks on the loader #15
I had my son put them on for me while he was home. He's a welder/iron worker by trade.
NEW HOLLAND 355 FEED MILL (A64277)
NEW HOLLAND 355...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
Cub Cadet Riding Mower (A66408)
Cub Cadet Riding...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2022 EZ-GO ELITE...
832856 (A61166)
832856 (A61166)
