Which coolant?
/ Which coolant? #1
Jesser02Ex
Branson 5220R
Community,
I need help to identify a replacement coolant for my 5220R.
The manual calls for a D4985 compatible coolant, however the governing body recommended in 2016 to mark this coolant as obsolete and discontinued. They claim it addition of SCAs causes it to have a very high silicate level.
They state that all OEMs, except Catapillar, had removed it from their documentation. Cat agreed to remove it from their manuals too. Cummins nolonger recommendation a SCA precharges coolant.
Details can be found here:
Withdrawal of D4985-1(215) Standard Specification for Low Silicate Ethylene Glycol Base Engine Coolant for Heavy Duty Engines Requiring a Pre-Charge of Supplemental Coolant Additive (SCA)
I know I use Rotella HD coolant in my diesel truck in a 50/50 mix. The stock coolant is green and the HD coolants are purple.
What have you used? I need to either top off my current coolant (20hrs) or drain and replace it all.
Looking for input on what I should use. Thanks
/ Which coolant? #2
My manual for 4720H says to use KSM 2142 coolant...
Google found this when I looked: (Automotive Fluid)
BIZOL Coolant G11
Benefits
outstanding long-term cooler protection
increases driving safety
active care for the entire cooling system
Product Description
BIZOL Coolant G11 is a long-life antifreeze based on ethylene glycol for year-round use in petrol and diesel engines, that require a nitrite free antifreeze. Reliably protects from corrosion and overheating. Neutral to seals and tubes. Concentrate. To be mixed with water.
Specifications/Approvals & Recommendations
ASTM D 3306/D 4656 | SAE J 1034 | KSM 2142 | JASO M325 | British Standards 6580
VW Audi/Porsche/Seat/Skoda TL 774C | MB 325.0/325.2 | BMW GS 94000 | GM GME L 1301/Saturn | Fiat Alfa Romeo/Lancia 9.55523 | Chrysler MS-7170 | Ford ESD-M97B49-A | Volvo Cars 128 6083 / 002 | Lada TTM VAZ 1.97.717-97 | Cummins 85T8-2 | Deutz DQC CA-14 | Behr | Perkins | Case JIC-501 | MAN M 324 Typ NF | Iveco 18-1830 | MTU MTL 5048
I'm certain there are suitable different brand
alternatives that meet the same specs
/ Which coolant?
I wonder if Branson updated their manual and I have an older version. Thanks, I’ll check out that specification. I see you are in OK, I am in Coweta.
/ Which coolant? #4
Here is a picture from the 20/25 series Branson service manual. Hope it helps.
/ Which coolant?
Thanks again. I continue to research and the KSM standard appears to be the European equivalent of ATSM.
I’m not finding an American option for KSM 2142, so I went to the Cummins website and looked at their recommendations. They suggest Fleetguard products.
https://www.cumminsfiltration.com/sites/default/files/LT36237.compressed_0.pdf
I’ll keep searching, but I can’t help but wonder how old my manual is to have an ATSM listed coolant.
/ Which coolant? #7
I'm going through a similar process at my place,
what I have found are three basic groups of engine coolants
1) the old conventional glycol type, usually green in color
2) OAT a newer style, Organic Acid Technology coolant
3) HOAT the newest style, Hybrid Organic Acid Technology
And then I find this;
Different colored antifreeze is used to identify the type of antifreeze being used. Inorganic Acid Technology (IAT) antifreeze is green in color. Organic Acid Technology (OAT) antifreeze is orange, red, green, pink or blue. Hybrid Organic Acid Technology (HOAT) antifreeze is orange or yellow in color.
I am not sure what is the best way to go, I have several vehicles and several types of anti-freeze it would be nice to find one that was approved and worked well for all of them.
What I have started doing was when I changed out something that required draining or adding a lot to a system was completely draining and blowing out the existing coolant, flushing with water and using air to blow out everything again a couple of times. Then I have started using Rotella ELC. I am still looking reading and wondering as to the best way to go and may well end up redoing every thing I have swapped over again.
I have seen contamination issues with mixing coolants twice now, once with a Dex Cool vehicle that got conventional, and once with a Dodge that we think had a OAT that got mixed with conventional. The DEX Cool required quite a bit of disassembly to get cleaned out and back in service. The Dodge "just" took several hours of flushing and circulating dish soap through the system to get cleaned up for a refill. The Dex Cool was a dozen years ago and the Dodge this year.
In conclusion flush repeatedly and well and install the product of your choice, green needs changing every couple of years the other colors every 4-5 years.
/ Which coolant? #8
It is certainly more confusing than it used to be.
I purchased several cases of Peak Fleet Charge with SCA additives on close out at Advance Auto several months ago. This coolant is pink in color. To my knowledge this is just regular ethylene glycol green antifreeze (IAT) with SCA additives that gives it the pink color.
Years ago I used Wynn's SCA additive to my old 92 F250 Powerstroke and it was pink in color. So to my knowledge this coolant would be OK with any green or (IAT) type coolant.
I also read that you can mix up to no more than 25% of the types of coolant without compatibility issues. Whether or not this is true I have no idea.
/ Which coolant? #9
I use 5 yr 50k mile, yellow bottle (Prestone) car coolant at 50-50. Since the same components are used why not. Only exception I can see would be if you had a sleeved diesel engine and drove it 500k miles on an overhaul, you'd want some sort of chemical neutralizer to prevent the little bubbles that form on the surface of the sleeves and erode them. JD made a fluid additive which they quit making a few years ago and my OTR Cummins had an Ionic filter cartridge in the water line. None of my current tractors are sleeved and I really doubt I'll live long enough to put the equivalent of 500k highway miles on them so I don't worry about it.
/ Which coolant? #10
Wow, I think some people are over thinking this. I just went down to Walmart and got some of the super cheap SuperTech Antifreeze (regular ole ethylene glycol), cut it with 50% water, topped off my system and never looked back. I will be willing to bet it never causes a problem. If it was a GM car and it used the Orange DEX, I'd be a bit worried, but it isn't, so I'm not.
/ Which coolant? #11
I use nothing but CAT-1 spec'd ELC coolant in my diesel engines. It's good for 300K miles. I've used Fleetguard, Rotella and one other (maybe CAT?) ELC coolant. If they're spec'd as meeting CAT-1, it's good to go in my book.
They now have a Super-ELC that's supposedly good for 600K miles. I'm sure that's for the Long Haul Truckers not for hobby farm tractor owners like me.
/ Which coolant?
Well this thread has grown.
Since I didn't need full flush, I went to Walmart and picked up a bottle of their 50/50 coolant. I only need to top off my overflow reservoir and it fit the need. In my 7.3 Powerstroke (navistar) I use the Cat-1 (Cat brand) coolant cut 50/50. I'm at 25 hours on my 3 week old tractor. At my 50 hour service, I'll drain all the coolant and replace it with Cat-1 coolant to my trucks and tractor are use the same.
I really appreciate all the feedback and conversation on this topic. I agree coolant has more options than Oil, but I also determined I was overthinking the issue. Thanks everyone!
/ Which coolant? #14
Keep an eye on your new tractor. I assumed my 6530 had 5 year coolant and learned otherwise when I went to drain, flush and refill at 5 years. Had a lot of white corrosion I had to flush out. Coolant was milky, not coolant green and after draining you could look down and the tubes had corrosion blockages here and there.
/ Which coolant?
My goal is to flush the factory coolant in 30 hours and add a 5-year coolant.
2007 STERLING LT7500 SERIES CRANE TRUCK (A67714)
2007 STERLING...
2015 John Deere CX15 (A64126)
2015 John Deere...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
LOOK! (A63111)
LOOK! (A63111)
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
