MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,338
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Glug glug glug, as others have said and you suspect, is it sucking air through the water in the pipes instead of the vent.
And, as others have said, it could be several things. A blockage. Improper venting. No venting. Many old houses don't have vents on remodeled bathrooms. Can't help you too much there. Try and see if the sink has a vent for sure. If it doesn't, you may have to install a Studor valve under the sink. Rather than trying to explain it, watch this.
