Using a metal snake on ABS plastic drain pipe?
   / Using a metal snake on ABS plastic drain pipe? #61
Glug glug glug, as others have said and you suspect, is it sucking air through the water in the pipes instead of the vent.
And, as others have said, it could be several things. A blockage. Improper venting. No venting. Many old houses don't have vents on remodeled bathrooms. Can't help you too much there. Try and see if the sink has a vent for sure. If it doesn't, you may have to install a Studor valve under the sink. Rather than trying to explain it, watch this.
   / Using a metal snake on ABS plastic drain pipe? #62
if you have not heard the glugging sound in the past then odds are the obstruction has moved down the pipe and is blocking the vent connection......it also means the water is being sucked out of the trap so you should have an odor present too......it's true that most old houses are not vented adequately but if that was the case here then you would have seen the signs of it long ago......I'd try a solution made up of 1/2 cup baking soda and 1/2 cup salt and pour it down the drain......follow this with some boiling water poured in slowly to just move the solution down the pipes so not a lot of water......then let it sit for a couple of hours or even overnight.......next step is to start pouring boiling water down the drain and see if it has broken up.....if the sink backs up then let it cool down some and hit it with the plunger again.......it takes persistence.........Jack
   / Using a metal snake on ABS plastic drain pipe? #63
My sister's house had the gluging coming from her tub when the toilet was flushed. Turned out the vent pipe had two 90s in the attic instead of a straight shot thru the roof. The plumber first thought it had something to do with the P trap under the bathroom sink. NOT the answer for the fix.
Yes there is an odor in the bathroom, not sure if it was dry rot or what. I am familiar with a Studer vent and can install one. This is the highest spot in the system (upstairs bath) so maybe I could just vent it beneath the sink if I can find room. I will look into that.
I am also going to look in the attic today and look for any vent pipes.
   / Using a metal snake on ABS plastic drain pipe? #65
Has anyone ever used one of these? :
Amazon.com: Drain Cleaning Water Bladder with Garden Hose Attachment, Medium: Home Improvement
It's a bladder that attaches to garden hole with a p*ss hole at the opposite end of hose connection. Insert it in drain, bladder swells up and seals itself in pipe so that pressurized water is forced down drain to clear blockage.
I have one, but have never used it (knock on wood!). Anybody ever use one? With success?
I guess the are issues to look out for, i.e. drain pipes (and toilet seals, etc..) aren't designed to be pressurized, and if blockage is downstream of a vent....
I have blown pipe fittings apart with one of those. I would not use it for indoor plumbing.
   / Using a metal snake on ABS plastic drain pipe? #67
Problem solved so moot for Chief Bodie, but just another method that I've done in an older house.
#1 is similar to the shop vac way you tried. Only not just inserting, sealing, and letting run. Do that, but then lift and reinsert the shop vac hose into the drain rapidly. Think of it as hammering but in reverse with suction. That pulsating negative pressure will help dislodge junk.
#2 is to just run a garden hose to the drain. Plug around drain and overflow, then just force water in. Not full open if you have crazy high city water pressure. That works well for real slow sink drains, not total clogs with standing water.
Agree that plunger probably simplest, but if someone didn't have the physical ability to work it for 10+ minutes vigorously these could be less physically demanding methods.
   / Using a metal snake on ABS plastic drain pipe? #68
Use them all the time... we just call them balloons here.
Very effective in opening up slow lines...
Been managing rentals since 1982 and one of the first things I bought... they come in various sizes...
It's not just the swelling up but the vibration that helps to jog debris loose.
I checked in the attic above the bathroom. There is no vent there. I can try to chase the drain line as it moves down to the basement and see if I find any vent that is tied in, but I doubt I will find anything.
If I add a Studer vent, can I just Tee off the drain line from the trap to the fitting in the wall? Making sure the top of the studer vent is above the high water line in the sink bowl?
I know what a Studer vent it, but I don't understand how it would make a difference compared to the air that is allowed in anyway as the water goes down the drain hole?
   / Using a metal snake on ABS plastic drain pipe? #70
As water drains you have a column of water going down the pipe. This column of water is pushing air in front of it and sucking air behind it. So the air in front needs someplace to go and the air needs a way in from the back somehow.
Thus the regulations requiring vents fairly close to draining appliances. On really long runs and sometimes other issues a vent is needed to allow the air out.
Sinks or tubs full of water and commodes put a lat of water into a pipe fast and thus creates this column of water. A faucet running does so at a slow enough pace to not cause this column of water blockage. Now add a bit of a drain line being clogged issue and it just creates these issues to be worse.
If you have enough water draining fast enough to suck air through a p trap then you have a whole nother set of problems. P trap should always have water in it, never empty enough to allow air through it.
Studder vents do have a life span, can get clogged with lint or bugs or whatever.
There should be a vent at the comode or within a few feet of it, same for the sink, although they can share one.
May not be your problem, might be part of it.
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2012 Chevrolet Cruze Sedan (A55758)
2012 Chevrolet...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55314)
2023 New Holland...
2007 Mazda CX-9 AWD SUV (A55758)
2007 Mazda CX-9...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
