Front-End Loader 3 point/FEL adaptor plate
/ 3 point/FEL adaptor plate #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
I'd been looking at these for a bit (3 point/FEL adaptor) & recently Titan attachments ran a 20% off sale on theirs. Normally $299, $239 on sale (delivered price). Got here via Fedex ground in 4 days. The version I ordered works for both the 1025R & the 3038e FEL's and came with a CAT 2 top link pin & keeper and a solid link. I'll have to pick up a couple of CAT2/CAT1 bushings for the lift arm pins & top link connections on my attachments.
I can use this for moving 3 point equipment or using implements that don't need PTO, like the landscape blade/rake and I will probably also use it with the decked carryall for things like loading/unloading the truck.
This is what it looks like on the 1025R
... still got the Fedex sticker on it (no packaging other than wrapping the toplink bar & receiver crosspin wrapped in plastic & stuffed in the receiver & taped over). The Fedex guy was happy he could just push it off the back of the truck into the 1025R bucket. Shipping weight indicates 95 lb.
Toplink pin & keeper were shipped just installed in the toplink bracket. The Tri-ball mount was lying around unused since I went to a weight distributing hitch w/convert-a-ball.
Two sets of pins to accomodate a number of FEL's. It will also fit our 3038e 305 FEL.
It'll get stored where I can just drive in & pick it up with the FEL after dropping the bucket.
/ 3 point/FEL adaptor plate #2
I built one. SSQA plate & welded a quick hitch to it. Worked great & was the mount for my old snow plow. Handy for servicing the knives on the flail mower too.
It ran off with the plow & the old L3200. Picked up some SSQA plates from a garage sale & another QH (from a TBN member who doesnt like them) at cheap used prices. Need to get around to welding them together.
IMG_20150117_153836.jpeg20161025_152850.jpeg20161025_152905.jpegIMG_20150612_213853.jpeg
/ 3 point/FEL adaptor plate #3
View attachment 568432View attachment 568433View attachment 568434View attachment 568435
Thats actually a neat idea.
/ 3 point/FEL adaptor plate #4
Instead of having hooks on my bucket, I welded them on the adapter. Here is the Snowsport plow on it for the first time. And the carry-all.
3pt adapter 001_1.JPG3pt adapter 002_1.JPG008 (2)_1.JPGTC snowsport 1_1.JPGweld hooks 002_1.JPG
I'll resurrect this thread to mention that I used the adapter this weekend on the 3038e FEL to mount the landscape blade for pushing snow on the drive & about 1 mile of development road. It actually worked pretty well. There is enough slop in the connection to have a "float" effect even with the FEL set to a particular position & not in the real float mode. No kick springs on a landscape blade like a snow blade, but the area I was clearing (the development road) doesn't have any particular hidden surprises & the stall mat strip sandwiched onto the blade edge handles things like speed bumps without any jolts (at the speed I travel).
It definitely beat the heck out of doing the same work, with the same blade, running backwards to avoid packing the snow! The FEL arm weight helped provide down-force that wasn't there when the blade is attached normally, and there was much better lift when pushing excess snow over an existing berm.
/ 3 point/FEL adaptor plate #6
Has anyone tried to put a quick hitch on this Titan adapter plate to see if it will fit. How thick of steel are the lower holes, will they slide into the lower slots on a QH. or will they hit the back plate before reaching the holes on the QH.
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
2014 BMW 435i Convertible Coupe (A64557)
2014 BMW 435i...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
KMC 13 SHANK H.C. CHISEL PLOW, 3PT (A64278)
KMC 13 SHANK H.C...
