Turn signal / warning lamps
   / Turn signal / warning lamps #1
BubbaJr
Western Ohio
2016 KUBOTA B2650 w/cab & A/C
I found out the hard way that the lenses in the signal lamps are press fit plastic to plastic. On my B2910 they were held on by 3 screws, not anymore. Apparently several weeks ago I knocked the rear lens out of the left turn signal lamp. Friday when I was mowing I fortunatly saw the lens laying in the grass. I apparently ran over it last week and broke the center out of it.
I called my dealer and they had one in stock, so I went up yesterday morning and got it. Now I am going to use some caulk to help hold it in place, and will also do the same for the other lenses.
I have found a lot of cost cutting measures since my old B2910 was built. :smiley_aafz:
   / Turn signal / warning lamps #2
I've been looking at how much more plastic is on these newer machines... kind of scary compared to my 3/4 metal BX2200...
   / Turn signal / warning lamps #3
I hear you. I still have a bur in my saddle over no right side grab handle on the fender. Holes are there for you to mount it once you pay the $80 for it. I mean, if you are buying something for $20k....you would think they could put it on.
And yeah, I get it, the tractor would then be $20,080....so be it.
   / Turn signal / warning lamps #4
Yup. I was looking online at a new/newtome tractors, and it's amazing how many of them don't come with items that, heck, even my little BX has.
Also looking at older L series machines that are built like my old BX. Though finding one that is just the way I like it is hard to find. Some are sketchy as frig...
   / Turn signal / warning lamps #5
No idea if this is true, but I've heard others surmise they're designed this way so that on impact they'll pop off rather than crack in place. I will say I've side-swiped my wood pile more than once when mowing and had a lens pop off of the ROPS mounted signal lamps, unharmed. But I have had to replace a cracked lens that's screwed onto the rear fender.
   / Turn signal / warning lamps #6
I'd wager it has more to do with the cost of manufacture & assemble than anything else. Much faster to snap on lenses than fiddle with screws or anything.
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58216)
2019 ALLMAND...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
HOG COOKER MTD ON S/A TRAILER (A58374)
HOG COOKER MTD ON...
Giyi Mini 39" 4-N-1 Bucket (A57149)
Giyi Mini 39"...
Mini Excavator (A55787)
Mini Excavator...
43055 (A55851)
43055 (A55851)
