Buying Advice 40 hp-- which brand?
/ 40 hp-- which brand? #1
GFirkus
1953 allis ca
Hi guys. I currently own a '53 allis ca and rented a 3033r jd to do groundwork for a pool, and decided I new a newer tractor. I have done a bit of research, but need help. I need a tractor I can work on and repair myself (hyd cylinders with welded female fittings instead of male nipples). I broke a elbow off the jd and the cylinder had to get rebuilt. To me thats unacceptable that I couldn't remove broken pipe thread and install new elbow. I've split my ac to change clutch in the past. I want hst, 4x4, will have backhoe, loader lift 2000lb or more, joystick for loader on fender, and back blade for snow. Open station. I was pretty set on a kioti nx4510, then learned more about branson, ls, and massey. I think the ck series is just a bit to small for me. All maintenance will be done by me unless under warranty. I have very heavy/rocky soil. Chores will include- fire wood, move logs to staging area, plow snow, build roads/trails, food plots, misc. landscaping. I have 40 wooded acres. I want to get a tractor that I will keep for 30 years. I don't want $ to be a big issue in the decision, but it always is. Any advice?
/ 40 hp-- which brand? #2
Welcome to the forum.
Any new tractor that you buy will be computer controlled with Teir IV emissions equipment unless you stay under 25hp. So like everything else in life it’s a trade off. New tractors are not as easy to fix as a 1952 Ford 8N but they’re far more reliable and capable.
Most on here will recommend renting construction equipment to do heavy ground work like digging a swimming pool which compact tractors aren’t designed for which is probably why you busted the 3033r.
All the brands nowadays build good tractors. The Korean tractors (TYM, Kioti, Branson, LS) tend to be robust and less expensive. The Japanese tractors (Kubota, Yanmar, Iseki) tend to be refined and a little more expensive.
For a 2000lb loader lift capacity you should be looking for a 4000lb machine. The Kubota MX series is rugged, capable, and good for woods work.
/ 40 hp-- which brand? #3
I would look for a Case or Deere (or Cat) construction tractor with backhoe, used, with a few thousand hours on the clock, for about half of the price new. Maybe have a dealer put into shape for you, or buy it from a dealer. Better to be a bit over-powered than under-powered. Should last the rest of your life.
/ 40 hp-- which brand? #4
If you goal is something you can keep for 30 years then your best bet is to go with a brand/model that's popular and going to stick around.
Our Ford 1500 is almost 37 years old and despite being Ford/New Holland it's near impossible to find any parts from existing tractors much less new parts. 8N/TE-20/etc are easy because there's a following.
If I were you I'd probably lean towards JD, Kubota or *maybe* LS since they do NH as well.
My personal vote would be MX4800, doesn't have the bells and whistles that you see with the Grand L(which will help you when it comes to repair time) and a bit more utility oriented but similar specs. I say this as someone who just did the 40HP search and landed on a L4760.
/ 40 hp-- which brand? #5
My Branson 3520h - 35hp - isn't computer controlled. It's got a passive DPF (no regen cycle) and runs fine (due to lack of computer control) without the DPF, though I personally haven't done this.
I know OP said 40hp - I'm not sure if the larger Bransons (40+hp) are similar - but I wanted to counter this blanket statement.
/ 40 hp-- which brand? #6
Personally, I don't like the idea of DPF, more stuff to burn out / screw up.
While no one here has mentioned the "Red" tractors, I am completely satisfied with mine.
/ 40 hp-- which brand? #7
Allis Chalmers CA
1950 - 1958
Row-Crop tractor
Previous model: Allis Chalmers C
The live PTO on the CA was due to a hand clutch that "broke" the right side of the rear axle, causing the differental to spin freely.
Production:
Manufacturer: Allis Chalmers
Factory: West Allis, Wisconsin, USA
Total built: 39,499
Original price (USD)
$1,900 (1958 )
Allis Chalmers CA Engine:
Allis Chalmers 2.1L 4-cyl gasoline
Allis Chalmers CA Power:
Drawbar (claimed): 18 hp [13.4 kW]
PTO (claimed): 23 hp [17.2 kW]
Drawbar (tested): 22.97 hp [17.1 kW]
Belt (tested): 25.96 hp [19.4 kW]
Capacity:
Fuel: 13 gal [49.2 L]
Hydraulic system: 2 gal [7.6 L]
Rear Hitch:
Type: Allis Snap Coupler*
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 538
Dimensions & Tires:
Wheelbase: 82 inches [208 cm]
Weight: 2835 to 5045 pounds
Front tire: 5.00-15
Rear tire: 10-24
CA Serial Numbers:
1950: 14
1951: 322
1952: 10539
1953: 22181
1954: 31424
1955: 32907
1956: 37203
1957: 38618
1958: 38977
Final: 39513
Mechanical:
Chassis: 4x2 2WD
Steering: manual
Brakes: differential mechanical contracting band
Cab: Open operator station
Hydraulics:
Capacity: 2 gal [7.6 L]
Pressure: 3200 psi [220.6 bar]
Belt Pulley:
Diameter: 8 inches [20 cm]
Width: 5.5 inches [13 cm]
RPM: 1220
Speed: 2555 ft/min [778.76 meters/min]
Page information:
Last update: January 29, 2016
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
/ 40 hp-- which brand? #8
I need a tractor I can work on and repair myself.
I want open station, hst, 4x4, will have backhoe, loader lift 2,000 pounds or more. I want a tractor that I will keep for 30 years. I don't want $ to be a big issue in the decision, but it always is.
Kubota has about 49% market share in compact tractors. Deere has about 19% market share in compact tractors.
Kubota and Deere will be around in thirty years. Some tractor brands with avid supporters on T-B-N have 2% market share or less. Absolutely nothing wrong with this avidity, T-B-N is an enthusiast's site, but be aware.
Your spec for minimum one ton FEL lift skews choices available to heaviest tractors with HST.
VIDEO KUBOTA MX SERIES: Kubota MX series walk around and features by Messicks. | MX48 MX52 MX58 - YouTube
Kubota Grand L Series VS. Kubota MX Series - YouTube
/ 40 hp-- which brand? #9
there you go, I never understood people's fascination with imports.. they'd never stand up to any of these..
/ 40 hp-- which brand? #10
You said a 40hp unit. Might want to step up to 50-55hp. Might not be that much more and you will have all the capability you need. The only reason i would go smaller is if you plan on moving it from place to place a lot.
/ 40 hp-- which brand? #11
You can't count on Deere and Kubota, or any company of any type, to be around for 30 more years. That's a LONG time. Many of us won't be around then. Who would have guessed 30 years ago that Sears would disappear? Possibly, the odds are higher with Deere and Kubota...maybe. In the global economy we have, who's to say that the Korean made parts of any tractor will be available in that time frame?
My local dealer told me that parts availability for Korean made New Holland tractors is on par with Korean made tractors in general, some available, some not. I'd still look for best value and what you think will be strong for the next 10 years. I have not bought mine yet, but have pretty much decided on a Kioti at the end of the year. When/if my (future) tractor is 15 years old and needs some major repairs, maybe it will just be time for a new tractor...
Case and Deere of this size are made in Korea. No fascination required for the imports - you just don't have a choice if you want a CUT.
/ 40 hp-- which brand? #12
The past seldom predicts the future.
However, Deere was founded in 1837 and Kubota in 1890. Pretty good records for longevity.
The next big test will be implementing battery power in compact tractors to avoid predictable Tier V emission controls on all tractors, not just those with over 19 kW engine power output.
/ 40 hp-- which brand? #13
Any new tractor that you buy will be computer controlled with Teir IV emissions equipment unless you stay under 25hp. New tractors are not as easy to fix as a 1952 Ford 8N but they’re far more reliable and capable.
If you can make do with 1,100 to 1,300 pounds FEL lift capacity you can avoid spending considerable money and have a tractor that will fit in a garage.
If you move logs with pallet forks mounted on the Three Point Hitch, rather than the FEL, you will not need as heavy nor as expensive tractor. Kubota L2501 Three Point Hitch lift capacity is 1,918 pounds at lift points, 1,389 pounds 24" behind lift points. (Including weight of pallet forks.) Carrying a ton is much safer with cargo weight on the heavy rear axle and large rear tires.
Every tractor brand includes a model in the 2,600 pound to 2,900 pound (bare tractor) range with 100 cubic inch/24 horsepower engine ample for your applications. Tractors under 19 KW ( 19 KW = 25.4794-horsepower) are currently exempt from stringent, Tier IV emission controls which abruptly increase a tractor's cost some $2,000 above the 19 KW power demarcation.
L2501 VIDEO: l251 kubota - YouTube
L2501 SPECS: https://www.kubotausa.com/docs/default-source/brochure-sheets/l2501.pdf?sfvrsn=34e9b1d_8
/ 40 hp-- which brand? #14
Just curious, how easy/difficult is it to get parts for a 30 year old Kubota?
/ 40 hp-- which brand? #15
Jeffy was too busy in Wikipedia to notice, but Geotech, are you positive a deere model exists that is/was korean made? Small Case is same as NH/ LS so that is understood. But the deere?
/ 40 hp-- which brand? #16
Allis Chalmers - Founded 1901 - didn't make it. Even for Deere and Kubota I think I'd go with who the heck knows in 30 years. As Yoda said, “Difficult to see. Always in motion is the future”.
Jeff, here is a forum thread from you back in 2015:
https://www.tractorbynet.com/forums/all-other-brands/336055-defunct-tractor-manufacturers.html
Defunct Tractor Manufacturers
I blundered across this list of defunct tractor manufactures on Wikipedia.
Tough business.
List of former tractor manufacturers
From Wikipedia, the free encyclopedia
This is a list of companies that formerly manufactured or sold tractors. Some have discontinued manufacturing, were bought out or merged with other companies, or their names may have changed.
A[edit]
Aaron David Co. (Denmark)
Abenaque (US)
Acam (Denmark)
Acason
Accord (Greece)
ACME (US)
ACO (South Africa)
Acremaster (Australia)
Adams Husker (US)
Adams Sidehill (US)
Adams-Farnham (US)
ADN (France)
Adriatica (Italy)
Advance (US) purchased by Rumely
Advance-Rumely purchase by Allis-Chalmers
Aecherli (Switzerland)
Agcostar (US) part of AGCO Corporation formed from McConnell
AGE Agricultural & General Engineers (England)
Ager (Italy)
Agil (Austria)
Agracat (US)(imported)
Agra Farmer (Canada)
Agrifull (Italy) purchased by Fiat
Agrimeca (Argentina)
Agrimotor (US)
Agrip (France)
Agri-Power (US)
AGRISA-Bungartz (Brazil) became Agrale
Agritec (Argentina)
Agromet (Turkey?)
Ahlborn
Aion (Australia)
Ajax (US)
Aktivist (Germany)
Albion-Cuthbertson James A. Cuthbertson (Scotland)
Wm Allchin (England)
Alfa Romeo (Italy)
Allaeys
Alldays & Onions
Allgaier (Germany)
Alliance
Allis-Chalmers (US) purchased by AGCO Corporation
Allwork (US)
Alpenland (Germany)
Alpina (Switzerland)
Alpina-Oekonom (Switzerland)
Alu-Trac
Amepic
American (US)
American (American Tractor Corporation) (US) purchased by J.I. Case
American Harvestor (US)
American Steel (US)
American Tractor (US)
American-Abell (CANADA)
Amiot (France)
Amog (Italy)
Andrews (US)
Andrews-Kinkade (US)
Ansaldo-Fossati (Italy)
Antigo (US)
Appleton (US)
Arator
Argo (Italy)
Armington, A.P. (US)
Armstrong Siddeley (England)
Arnold-Sandberg (US)
Assembled
Asso
Astoa (Spain)
Aston Martin (England)
Atlas (US)
Aulendorf (Germany)
Aulson (US)
Aultman (US)
Aultman & Taylor (US)
Austin (US)
Austin (France/England)
Austin-Leyland BMC Sanayi (Turkey)
Austrak (Australia)
Austro (Austria)
Austro-Pimus (Austria)
Auto Tractor (US)
Automotive (US)
AutoTrac (Canada)
Avance (Sweden) Merged into Munktell
Aveling Marshall (England)
Aveling & Porter (England)
Aveling-Barford (England)
Avery (US) purchased by Minneapolis-Moline
Avia (Spain)
B[edit]
Danish Bukh tractors (1959?966) from Danmarks Traktormuseum
B.F. Avery (US)
Babiole (France)
Backus (US)
Badley (US)
Bailor (US)
Baird (US)
Bajaj Tempo (India) spun off and renamed Force Motors
Baker, A.D. (US)
Baldwin (Australia)
Balilla (Italy)
Balmar
Bambi
Bambia
Bantam (US)
Banting Machine Co.
Barford & Perkins (England)
Bariole (France?)
Barreiros (Spain)
Bates (US)
Bates Steel Mule (US)
Bautz (Germany)
Bear (US)
Bearcat (US)
Beaver (US)
Beeman (US)
Belazerus (Belarus)
Bell, Robert (US)
Beltrail (US)
Ben (Italy)
Benz-Sendling (Germany)
Berliot (France)
Bertolini (Italy)
Besser (US)
Best (US) purchased by Holt > became Caterpillar Inc.
Bethlehem (US)
Bi.Som.Trac (France)
Big Bud (US)
Big Bull (US)
Big Four (US)
Big Lizzie (Australia)
Bima (France)
Birrell (US)
Bischoff
Bison (France)
BJR (Spain)
Blackstone & Co (England)
Blanc-Plaiche (France?)
Blaw-Knox (England)
Blumberg (US)
BM Volvo (Sweden) has evolved into the current Valtra, part of AGCO Corporation
BMB (England) (British Motor Boats)
BMC (England) From Merger of Austin & Nuffield, later became Leyland then finally Marshall (tractors)
Boenker (US)
Bofors (Sweden)
Bohrer
Bolgar (Bulgaria)
Bolinder (Sweden)- merged with Munktell to become Bolinder-Munktell
Bolinder-Munktell (Sweden) merged with Volvo to become BM Volvo/Volvo BM
Bolte (US)
Bori (Slovenia)
Boring (US)
Borsig (Germany)
BOS Hydro-Trac (The Netherlands)
Boyett (US)
Bradley (US)
Braud (France)
Braun
Bray (England)
Bready (US)
Breda (Italy)
Breed (US)
Bristol (England)
British-Canadian (US)
Brockenhexe (Germany)
Brockway (US)
Brons (The Netherlands)
Brown (US)
Brummer
Bryan (US)
BTG (East Germany)
BTW
Bubba (Italy)
B?her (Switzerland)
Buckeye (US)
Buffalo
Buffalo-Pitts (US)
BUKH (Denmark)
B?rer (Switzerland)
Bull (US)
Bull Dog (US)
Bulldawg
Bull-Madison (US)
Bullock (US)
Bulltra
Bungartz (Germany)
Bungartz & Peschke (Germany)
Bunton
Burn-Oil (US)
Burrell (England)
BWS
C[edit]
C. & G. Cooper (US)
C.L. Best (US)
C.O.D. (US)
Caldwell (Australia) became Caldwell Vale
Caldwell Vale (Australia)
Calsa (Spain)
Cameco (US)(sold to John Deere)
Cameron (US)
Camisa
Campagnolo
Canadian (Canada)
Canadian-American
CanTRAN
Canycom
Carter
Case Corporation (US) purchased by Tenneco, and later merged with International Harvester to become Case IH
Case New Holland (India)
Case, J.I (US) was purchased by Massey-Harris
Cassani (Italy)
CAST (Italy)
Caterpillar (sold tractor business to AGCO Corp (US)
Cayuga (US)
CBT Companhia Brasileira de Tratores (Brazil)
CDHL (US)
Centaur (US)
Centenario
Century (US)
Ceres (France)
Ceres (India)(brand of International Tractors (Sonalika))
Certified (US)
Chamberlain (Australia) purchased by Deere & Company
Champ (Thailand)
Champion (US)
Champion (France)
Chaseside (England)
Cherry (Japan)
CIMAC (Italy)
Citroen (France)
Claeys (Belgium)
Clarktor
Clayson (England)
Clayton & Shuttleworth (England)
Cleveland Tractor Company/Cletrac (US) purchased by the Oliver Corporation in 1944
CMC (France)
Cobey (US)
Cockshutt Plow Company (Canada) purchased by White Farm Equipment
Cockshutt Hart-Parr (Canada)
Codem (The Netherlands)
Coleman (US)
Colpron (Canada) rebadged Landini's
Colt (US)
Common Sense (US)
COMPACT Junior (Austria)
Conord
Consolidated (US)
Continental (US)
Co-op (US)
Co-op (National Farm Machinery) (US)
Co-op Implements (Canada)
Cooper
Corbitt (US)
Corliss (US)
County (England)
Crawley Agrimotor (England)
Crystal Zetor (Czech)
Csepel (Hungary)
CTM
Cultivac
Cultor (US)
Custom (US)
Cutherbertson James A. Cuthbertson (Scotland)
D[edit]
Daimler (Germany)
Daimler-Benz (Germany)
Dammann (US)
Davey Paxman & Co. (England)
David Bradley (US)
David Brown Ltd. (England) purchased by Tenneco and renamed Case
DECA (Argentina)
Deering (US) merged with other manufacturers to form International Harvester
Defaut (France)
Detroit (US)
Deuliewag (Germany)
Deutz (Germany) merged with Fahr
Deutz-Allis (US) formed when Deutz-Fahr bought Allis-Chalmers. Purchased by AGCO and became AGCO-Allis.
DF (China)
Diesel Ox (US)
Dragon (US)
Drexler (Austria)
Dufuat
DUTRA (Hungary)
DUTRA Steyr (Hungary)
E[edit]
1916 Emerson Tractor, made by Emerson-Brantingham (US)
Eagle (US)
Ebro (Spain)
Ebro-Kubota (Spain)
Eclipse (US)
Edwin Alber
Eicher Goodearth (India) became just Eicher
EMCO (US) later Power Horse
Emerson (Canada)
Empire (US)
Enter (Turkey)
Enti (The Netherlands)
Epple-Buxbaum (Austria)
Erickson (US)
Euro-Trac (India)
F[edit]
Fageol (US)
Fahr (Germany) merged with Deutz to become Deutz-Fahr
Falke-trac (Germany)
Farm Ette (US)
Farm System
Farmall (US) by International Harvester
Farmç–µ (Czech)
Farmaster (US)
Farmcrest (US)
Farmer's Union Co-op (US)
FarmHandy (US)
Farmliner Daedong (Australia) built in S.Korea
Farmobile (US)
Farmwell (England)
Farquhar, A. B. (US) merged into the Oliver Corporation
FBW (Switzerland)
Ferguson (Ireland)
Fendt (Germany)
Ferguson-Brown (England)
Fiat OM
Fiat Someca (France)
Fiat-Agrifull (Italy)
Fiat-Goldstar (South Korea) now LS-New Holland
Field Marshall (England) became Marshall
Finn Ursus
Foden (England)
Ford (US) purchased by Fiat, now New Holland
Ford-Ferguson
Fordson tractor (US) by Ford
Fordzon-Putilovec (Russia)
Fortschritt (East Germany)
Foton (China) now Lovol
Four Drive (US) also known as Fitch Four Drive
Four Wheel Traction (England)
Fowler (England)
Frick (US)
Froehlich (US) purchased by Deere & Company
Futian (China) changed to Foton, now Lovol
Futian Leopard (China) now Foton or Foton Leopard
Futian Oubao (China) changed to Foton, now Lovol
FWD Wagner (US)
G[edit]
Galloway (US)
Gambles Farmcrest (US)
Gardner (England or Belgium)
Garner (England)
Garrett (US)
Garrett (England) Steam tractors & Showmans engines
Gaar-Scott (US)
GBT (US)
GeDe (The Netherlands)
Geiser (US)
General (US)
General (England)
George (US)
Gibbons & Robinson
Gibson (US)
Gilson (Canada)
Glasgow (England)
Global (US)
GMW (Sweden)
GoldStar (South Korea) later LG. Now LS.
Graham-Bradley (US)
Gray Tractor Manufacturing Co. (US)
Greaves (India) later SAME Greaves
Greyhound (US)
Griffin (US)
Grissly
G?dner (Germany) later part of Linde
Gulliver (Italy) now SEP
H[edit]
Harrison Machine Works 1882 tractor.
Haas (US)
Hahn-Eclipse (US)
Hanomag (Germany)
Hanomag-Barreiros (Spain)
Hanzi (China)
Happy Farmer (US)
Harrison Machine Works (Belleville, Illinois, USA)
Hart-Parr (US) merged into the Oliver Farm Equipment Company in 1929 purchased by Oliver Corporation
Hattat Agricultural Engines <http://www.hattattarim.com.tr/en/home/> TURKEY
Hatz (Germany)
Heider (US)
HELA (Germany)
HEMOS
Herriau
Hesston (US) tractors were part of Fiat. Hay equipment and name purchased by AGCO
Highlander (England) specialist forestry conversions
Hindustan (India) now MGTL *Mahindra Gujarat
Hinomoto (Japan) acquired by Hitachi and renamed Tierra
Hitachi (Japan)
Hofherr HSCS (Germany)
Hofherr-Schrantz (Hungary)
Holder GmbH (Germany)
Holt Manufacturing Company (US) merged with Best to form the Caterpillar Tractor Company
Homesteader (US) Clinton, AR Garden Tractors
Homier Farm-Pro (US)
Richard Hornsby & Sons
Horwood Bagshaw (Australia)
Howard (Australia) Tractor, Rotavators & Rotary Tillers
Howard Farmers (England)
HSCS (Hungary)
Huber (US)
Hume (US)
Hydratiller (US)
I[edit]
ITM (Iran Tractor Manufacturing Company)[1]
IFA (Germany)
Illinois (US)
IMA (Argentina)[2]
IMT (Serbia) Industrija maå–¨na i traktora
Imperial (Australia)
Imperial Super Drive (Canada)
Intercontinental (US)
International Harvester (Australia)
International Harvester (US) Agriculture division sold to Tenneco and merged with Case to form Case IH in 1985.
Is Bora (Turkey)
Ishikawajima-Harima (Japan) now Shibaura
ITC (US)
Ivel (England) invented by Dan Albone
J[edit]
J & H Howard
Jackson (US)
Jeep (US)
Jela
Jelbart (Australia)
Jiangling (China)
John Deere Lanz (Germany) Formerly Lanz AG
Jumbo (US)
June (Sweden)
JWD (UK)
K[edit]
Kaelble (Germany)
Keck-Gonnerman
Kelkel (Germany)
Kelly & Lewis (Australia))
Kelpie (England)
Kemna
KHD (Austria)
K?ai
Kirloskar (India)
Kirov Plant (Russia)
Kirschmann (US)
Kitten (US)
Kiva (France)
Knudson (US)
Kodiak (US)
K?el (Germany)
Kolomenec (Russia)
Komatsu (Japan)
Komatsu International (Japan)
Kommunar (USSR)
Komnick (Germany)
Koni
K?fli (Switzerland)
Kramer (Germany) Merged with Neuson, who then merged with Wacker AG
Krasser (Austria)
Kuhnhausen (Germany)
Kullmo (Sweden)
Kullervo (Finland)
Kumiai (Japan)
Kunow (US)
L[edit]
L&T John Deere (India) joint venture, bought out by Deere & Company
Labourier (France)
Landhope (Japan) by Iseki
Landleader (Japan) by Iseki
LandTrac (US) by Long
Lanz (Germany), bought out in 1956 by John Deere & Company
Latil (France)
Lauer (Germany?)
Lauson (US)
Le Percheron (France)
Le Pratique (France)
Le Robuste (France)
Legras (France)
Lehr's Big Boy (US)
Lely Multipower (US)
Leo Rumely (US)
LeRoi (US)
LESA (Italy)
LeTourneau (US)
Leyland (England) later Marshall
LG (South Korea) now LS
LG-Fiat (South Korea) now LS-New Holland
LG Montana (US) now Montana
LG-New Holland (South Korea) now LS-New Holland
LHB (Germany)
Liaz (Czech)
Liberty (US)
Lightforce Deluxe
Lightforce Tractore
Linn maker of the Linn tractor Republic Motor Truck Company (US)
Lioness (England)
Li-Trac (Germany)
Little Giant (US)
Loiseau (France)
Loko-Mobil
Long (US)
LongAgri (US)
LTS (Germany)
Luoyang Fiat (China)
LUX-TRAC (Luxembourg)
M[edit]
M.R.S. (US)
MacLaren
Macrosa (Argentina)
Madson (US)
Mahindra & Manhindra(India)
Malkotsis (Greece)
Malcus (Sweden)
Malves (Brazil)
Malyshev Factory (USSR)
MAN (Germany)
Mancini (Argentina)
Mann's Patent Steam Cart and Wagon Company (England)
MAP (France)
Marshall, Sons & Co. (England) Builders of Field Marshall brand
Marshall Tractors (England) Formerly Leyland tractors
Martin Diesel (Slovak)
Massey-Harris (Canada)
Massey-Harris-Ferguson (Canada)
Matbro (England)
Mathis-Moline (France)
Maverick (US)
Maxitrac
McConnell (Canada) sold to AGCO Corporation, later AgcoStar
McCormick (US) merged with others to form International Harvester
McCormick-Deering (US) by International Harvester
McDonald (Australia)
McKee Ebro (Canada)
McLaren (England) see J&H McLaren & Co.
MDW-Fortschritt (East Germany)
Mecavia (France)
Medved (Russia)
MeMo (US)
E. Meili Traktorenfabrik (Switzerland)
Mercer (US)
Metis (Slovak)
Millennium (US)
Minneapolis (US) merged with Moline Plow to form Minneapolis-Moline
Minneapolis-Moline (US) purchased by White Farm Equipment
Minnesota (US)
Moffett (Ireland)
Mogul (US)
Moline Plow Company (US) merged with Minneapolis to form Minneapolis-Moline
Monarch (US) purchased by Allis-Chalmers
Morris-Leyland (Turkey)
Motocultores Pasquali(Spain)
Motrac Werke AG. 1937?969 (Switzerland)
Motransa (Spain)
Mountain State (US)
Mt. Super (Slovakia)
MTW (Germany)
Muir-Hill (England)
M?ler (Brazil)
Munktell (Sweden) merged with Bolinder to form Bolinder-Munktell.
MVM (Russia)
MWM (Motoren Werke Mannheim AG) (Germany)
Myth-Holm (England) formerly Muir-Hill
N[edit]
Nallahay
NanYue (China)
Naughton (Australia)
Nelson (US)
New Holland Agriculture
New Holland Tractors (India)
Newman (England)
Nibbi (Italy)
Nichols & Shepherd (US) merged to form Oliver Farm Equipment Company in 1929
Nordtrak (Germany)
Normag (Germany)
North Land (US)
Northrop (England)
Northwest (US)
Nuffield (England) later Leyland and then Marshall Tractors
Nuffield Morris (Turkey)
O[edit]
O&K/Orenstein and Koppel (Germany)
Oliver
Oliver Corporation (US) purchased by White Farm Equipment
Oliver Cletrac (US)
Oliver Hart-Parr (US)
OM (France)
One Man Motor Plow (Canada)
Orsi (Italy)
OTA (England)
Ottawa (US)
OUTZ
P[edit]
PAL (US)
Panda
Panzer (US)
Paramount (US)
Parca
Parrett (US)
Pavesi (Italy)
Pavesi-Tolotti (Italy)
Peerless (US)
Perl (Austria)
Petropoulos (Greece)
PGS (Italy)
Phillips (Australia)
Phoenix (Australia)
Pillman (South Africa)
Pioneer (China)
Planet, Jr (US)
Plymouth (US) became Silver King
PMA (Algeria) now Cirta
Polytrac (Switzerland)
Porsche (Germany)
Port Huron (US)
Power Track
Power-Horse (US)
President (England) Designed by BMB (British Motor Boats)
Price (US)
Primul (USSR)
Primus (Germany)
Profintern (USSR)
PTZ (Kazhakistan)
Punjab (India)
Q[edit]
Quaker Mule (US)
Quattrino
Quincy (US)
R[edit]
R�BA (Hungary)
R�BA-Steiger
Ransomes, Sims & Jefferies (England)
Rayes (US)
Raygo Wagner (US)
Red Star
Reeves (US)
Rein Drive (Canada)
Remington (US)
Renault agri (France) purchased by Claas in 2003
Renault Sonalika International (RSI) (Mauritus/India)
Rhino International (US)
Rice (US)
Richard Continental (France)
Richter (Australia)
RIP (France)
Rite (US)
Ritscher (Germany)
Roadless (England)
Robey (England) Steam tractors
Rock Island (US) purchased Heider, was purchased by Case
Rockol (US)
Rogers (US)
Rohff (France)
R?r (Germany)
ROLA (Sweden)
Rollo (Denmark)
Rome (US)
Ronaldson Tippett (Australia)
Roux
Royal (Germany)
Rumely (US)
Ruston (England)
Ruslan (Argentina)
Russell (US)
Ruston & Hornsby (England)
Ruston, Proctor and Company (England) Steam tractors
S[edit]
S.W.Wood (US)
Sabatier (France)
SAME (Italian) Taken over by Deutz-Fahr
SAME Greaves (India) a joint venture, wholly purchased by Same Deutz-Fahr
Samson (US)
Sandusky (US)
Satoh (Japan) merged with Mitsubishi
Saunderson (England)
Scemia (France)
Schilter (Switzerland)
Schindler (Germany)
Schlueter (Germany)
Schneider
Schramm (US)
Scientific Farming Machinery Company (US)
Selene (Italy)
Sepa (Italy)
Shakti (India)
Shaw (US)
Shire
SIFT (France)
Silver King (US)
SIMAR-Bodenfr舖e (Switzerland)
Simpac Trak (Italy)
Simpson Jumbo (US)
Sirio (Italy)
Skoda (Czech)
SLC John Deere (Brazil) a joint venture, wholly purchased by Deere & Company
SM
Smallholder (England)
Soci� Fran軋ise de Vierzon (France) purchased by Case
Someca (France) purchased by Fiat
Speedy
Squire (Australia)
Steiger (US) purchased by Case
Steinbock (Austria)
Sterling (Canada)
Steyr-Nigeria (Nigeria)
Store (Yugoslavia)
Strong
Sunshine (Australia)
Sunshine (kubota) (Japan)
Sunshine Massey Harris (Scotland/Australia)
Superson
Sutcliff
Svedala (Sweden)
Svoboda (Czech)
Swed-Trac (Sweden)
Standard (India)
Sonalika International (India)
T[edit]
TAISSA (Spain)
Takra (Finland)
TAS (US)
Tasker
Taylor (US)
Terra Power
Terratrac (US) crawler tractors built by American Tractor Company purchased by J.I. Case
Thieman (US)
Thomas-Bilt (US)
Thorobred (US)
TianTuo (China)
Tidaholms (Sweden)
Tiger (US)
Tiger (China)
Tiger (Ranger) (Japan)
TigerTrac (US)
Titan (US)
Titan (Steiger) (US)
Titano (Italy)
Titus (Germany)
Toft (Australia)
Tom Moore (US)
Toma Vinković (Croatia) now TTB
Torpedo (Croatia)
Torpedo Deutz (Croatia)
Tortone (Argentina)
Track Marshall (England)
trac-technik (Germany)
Tractocoop (France)
Tractor Supply Co. (US)
Tractormobile (US)
Tratoretto (Brazil)
Trojan (US)
Trusty (England)
TUR (Poland)
Turf Boss
TurkFiat (Turkey) now New Holland
Turner (England)
Twin City tractors (US) merged to become Minneapolis-Moline
Twister (US)
U[edit]
U.T.B. (Romania) now just Universal UTB
Uncle Sam (US)
Unigraf
United (US)
UniTrak (Germany)
Universal (US) built in Ohio
UPD
Upton (Australia)
Ursus Hellas (Greece)
Ursus Italtractor (Italy)
Urtrak (Germany)
Utos (Romania)
Uzel (Turkey) ([3])
Massey Ferguson (under license)
V[edit]
Valmet (Finland) now Valtra
Valor (France)
Valtra Valmet (Finland) now Valtra
Valtrac (France)
Vanguard (US)
Variotrac (France)
Vendeuvre (France) purchased by Allis-Chalmers
Versatile (Canada) purchased by Ford, now owned by Buhler
VeWeMa (Germany)
Victor (Japan)
Vittorio Cantatore (Italy)
Vladimir Factory (Russia)
Volgograd Tractor Factory (Russia)
Volvo (Sweden) merged with Bolinder Munktells, now Valtra
Volvo BM (Sweden) now Volvo Construction Equipment
Volvo BM Valmet (Harvesters) (Sweden) now Valtra
Vevey tractors (Switzerland)
W[edit]
WACO (Austria)
Wagner (US)
Wallis (US) purchased by Massey-Harris
Wallis & Stevens (US)
Wallis & Steevens (England) Steam tractor (Note odd spelling of name)
Waltanna (Australia)
Walter Barrett (US)
Wards (US)
Warrior (Italy)
Waterloo Boy (US) purchased by Deere & Company
Weber (US)
Webfoot (US)
Welte
Werner (Germany)
Western (US)
Wesseler (Germany)
Wheel Ox (US)
White (US) purchased by AGCO Corporation
White Oliver (US)
Whiting-Bull (US)
Wikov (US) (certain products now manufactured by Wisconsin Engineering [4])
WildCat (US)
Williames (Australia)
Winget (Australia)
Winget (UK) More noted for site dumpers & plant (was part of Babcock & Wilcox for a time)
Wisconsin (US)
Wood Brothers (US)
Woods & Copeland (US) purchased by Rome
Woody
Worthington Mower Company (US)
Wright (South Africa)
X[edit]
XT3 (Ukraine)
Y[edit]
Yankee (US)
Yewers (Australia)
Z[edit]
Zadrugar (Yugoslavia)
Zanello (Argentina)
Zanello (Pauny)(Argentina) now Pauny Rino
Zaporozhec (Ukraine)
Zebra (US)
Zetor (Czech) with Zetor Crystal built in Poland by Ursus
ZTS (Slovak)
External links[edit]
List of Tractor Models by Manufacturer
Categories: Tractor manufacturersLists of defunct companies
Navigation menu
Create accountLog inArticleTalkReadEditView history
This page was last modified on 25 March 2015, at 22:33.
Text is available under the Creative Commons Attribution-ShareAlike License; additional terms may apply. By using this site, you agree to the Terms of Use and Privacy Policy. Wikipediaï½® is a registered trademark of the Wikimedia Foundation, Inc., a non-profit organization.
/ 40 hp-- which brand? #17
Deere and Kubota are legendary for tractor parts availability back thirty years, Deere for longer.
However, parts for thirty year old tractors are low volume and are often astoundingly expensive relative to the original acquisition cost of thirty year old tractors.
/ 40 hp-- which brand? #18
Actually I am not sure where Deere assembles their small tractors. They have yanmar engines, so they are not "made in the US". Not that it bothers me.
/ 40 hp-- which brand? #19
/ 40 hp-- which brand? #20
RNGRR,
Be it not for you tube, Wikipedia, or tractor data, at least one poster would be devoid of any ability to comment, and no it is not you of course. His stuff is tedious and boring, oblivious that we All have search engines.
There was a post yesterday, in which your kubota pricing research was helpful. I copied the data from your purchasing post, properly credited the original author. OP was weighing the difference between a new L6060 and a slightly used version. CAB Model.
Did you notice that Viperdriver posted some tractor photos?
Certainly the OP won't object to a minor deviation, afterall Viper did purchase a 40 hp machine.
Jeffy, deere actually obfuscates w/ regard to "country of origin" data for some models. Doubt the advent of battery charged tractors is on the horizon, althogh I hope you are the first beta recipient.
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59908)
2015 ISUZU NQR 4X2...
2015 FREIGHTLINER CASCADIA 125 6X2 T/A SLEEPER TRUCK TRACTOR (A59909)
2015 FREIGHTLINER...
2023 CATERPILLAR 299D3 SKID STEER (A62129)
2023 CATERPILLAR...
2018 CATERPILLAR 906M WHEEL LOADER (A62129)
2018 CATERPILLAR...
2019 John Deere 344L Articulated Wheel Loader (A60352)
2019 John Deere...
1998 New Holland TC21 (A62177)
1998 New Holland...
