JD 5065e Coolant Flush?
   / JD 5065e Coolant Flush? #11
Normally I would say that's a load of BS but in this case I agree. I only use Deere coolant in my sleeved cylinder Deere and I like it. They make way too many $400,000 tractors to make a bad coolant for them. WalMart stuff is OK for the regular non-sleeved tractor engines. You did the right thing.
Same with Toyota coolant. My Toyotas get Toyota coolant and that's the way it is. Too many stories of bad coolant and problems.
I'm sure I could connect the right aftermarket coolant with sufficient research and constant monitoring but I'd rather have the seat time.
QUOTE=JD 4520;3742199]I again changed my antifreeze this past week. When I went to the dealer to pick up a few items, I again asked what I should use that is Deere labeled and what I can otherwise buy on the open market. The service manager told me that I should feel comfortable using any brand oil, filters BUT really the only thing that is a must buy Deere product is CoolGard Antifreeze. It is due to the lubricants that are contained in the CoolGard and is a must for Deere engines.[/QUOTE]
If you do not remove thermostat when filling radiator, will air in block get flushed into radiator thru thermostat when it opens? Otherwise, is there a bleed screw you can open on top of block to assure high points of air pockets get out?
   / JD 5065e Coolant Flush? #13
I am currently working on this. I just watched a youtube video with guy changing/flushing his JD 6### coolant..... wrong. All he did was open the radiator drain. He never opened the engine block drain, provided any fresh water circulation or anything. If he had added water while leaving the engine running a bit he might have flushed something.
Oh well....... don't take my word for it........ OMCD16510
I have a JD 5425 with 4045 engine. From the pic I had a hard time locating the "oil cooling housing drain plug". From looking at some pics online it appears to be on the side of the engine below/under the oil filter. I haven't pulled the plug yet but plan on doing so and doing a proper "flush". Simply opening the radiator drain does nothing to move any debris or old fluid out of the engine (the radiator drain will not remove this unless you are running/engine and circulating water while draining). Some warm/hot circulation needs to be done and then open both drains.
   / JD 5065e Coolant Flush? #14
This thread seemed like a good place to ask for other's experience. I have 2011-2012 5093e limited with 6400 hours..yep 6400 hrs. I used Fleetguard/Cummins Restore Plus at about 1/3 gallon for the 3 gallon cooling system as label directed. Spliced in a "T" below the cab step for back flushing "just because" and assumed municipal water pressure would be enough to flush up the supply heater core out return. While doing this I had 1) both the right side and left side engine block drains open 2) then closed the block drains and put cap on the expansion reservoir and filled cooling system from tap and operated at temp for 10 minutes. 3) Opened up the block drains again and allowed to drain as well as "T" splice /port I installed at the lowest point in the heater core supply loop. Heater control valve was wide open. Bone dry as far as I knew after the draining 4) Refilled coolant at 5 quarts concentrated coolant to 7 quarts DISTILLED water. Everything running fine . No overheating but NO HEAT. Got a coolant sample from the "T" and it cloudy with rust flakes and when tested the coolant concentration was only good to "0" degrees but should be -15F degrees. I'M THINKING THAT EVEN WITH ALL THAT FLUSHING THERE MUST HAVE BEEN CLOSE to the entire heater core, supply and return lines left full of the COOLANT system FLUSH solution.
So now, since I need to replace the sediment-full, "0" degree protection coolant/flush combination I am also going to replace the THERMOSTAT.
QUESTIONS:
1) Recommendations on a better way to flush the Heater supply, Core/exchanger, return lines? My thought is to move the flushing "T" to just in front of the cab roof
valve under the cab access pan. Flush with tap water, then run some compressed air to empty the core.
2) Recommendations on how to refill coolant level to include or "charge" the heater core supply, core/exchanger , return line to eliminate possible "air lock" for the heater not heating the cab after the flush/recharge? Refill from the same "T" at this higher elevation? I do have a drill powered pump.
3) Anybody with recommendations or experience replacing the thermostat in the 5093e limited (Engine group 4045HLV60). The thermostat housing is R529893, the gasket is R502814 and the thermostat is DZ100555. Will all the "O" rings for the two adjoining lines need to be replaced or can the housing be moved off the block enough to get the thermostat out without detaching the lines.
I'll take and appreciate any help or recommendations other have any of these questions. Thanks
   / JD 5065e Coolant Flush? #15
QUESTIONS:
I have a 5520, which is the same engine and the owner's manual--maybe shop manual--says to remove the thermostat when flushing or you won't get a complete flush . Maybe that has something to do with it.
When I flush mine, I do not remove the thermostat. I just drain the old coolant out, add the radiator cleaner and fill with distilled water. Then I run it for maybe a few hours of normal activities, drain the water and coolant out and run again for a couple hours with fresh distilled water to circulate everything.
Then I drain that out, fill with Deere prediluted coolant and go do something else. This is how I was trained in a shop a long time ago and that's what I will do forever. Never a problem.
   / JD 5065e Coolant Flush? #16
So, when you flush the coolant, what do you do with it? There are no recycling centers around here. If I put it in a big tub will it evaporate so I can put dried remnants in the trash to go to the land fill?
I've got to get mine done soon. I've not ignored it, I just forgot. :eek: That really amounts to the same thing.
   / JD 5065e Coolant Flush? #17
I take mine to an Advance Auto and that take it. I dump it in a drum out back. As I understand it, TSC and the other auto parts places do it as well. It's been over a year since I've taken any in but that's the way it was then and I've heard nothing of any change. I've never been able to get anti freeze to evaporate.
   / JD 5065e Coolant Flush? #18
Thanks sixdogs. I'm ok using tap water for the flush 'cause I read in an older Deere Manual and in the Cummins/Fleetgaurd flush instructions BUT I wondered the same thing about not using Distilled water for the flush of the Coolant flush. Had I done that with distilled water maybe I would not have gotten so much sediment. Let me know if anybody has replaced thermostat in the same or similar engine group. I got a few days until the parts arrive. Thanks.
   / JD 5065e Coolant Flush? #19
I've got a 5520 shop manual if that helps. When I looked it up I felt why bother; as long as it heats up and is run hard for a while it will fully circulate. In my case I felt a good flush and thorough rinse with new distilled water would be OK as long as I gave it time to fully heat up and circulate and not a hurry up 10 minute flush where the thermostat doesn't even open.
Spend the money on distilled water and not tap water laden with the minerals you're trying to remove is my personal opinion.
   / JD 5065e Coolant Flush? #20
Distilled water is all I use in the tractors. CAT ELC is the ONLY coolant I use too -- we buy it in the big 55G drums so it's priced "ok" --- otherwise it's too expensive.
IIRC the "drain interval" is 12,000 hrs (perhaps longer with their extenders)
Miniature Metal Donkey Statue (A55853)
Miniature Metal...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2020 Ram 1500...
UNUSED FUTURE FTSSJ430J JAW CRUSHER (A57192)
UNUSED FUTURE...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
(2) Chainsaws, Electric Heater, Gun Case & Ground Blind (A56469)
(2) Chainsaws...
