Iseki tx1300f looking for engine repair manual
   / Iseki tx1300f looking for engine repair manual #11
You said it smokes but does not start. The color of the smoke is a good indicator of why your tractor will not start. What color is the smoke?
Blackish color I think the fuel is not being atomized enough
Ok I got all th parts manuals all the services manuals and the user manual thank you for the info I will be putting it to good use after I finish this next projects transmission again thank you very much.
James Morgan
Jmorgan177437
   / Iseki tx1300f looking for engine repair manual #15
Is it getting enough fuel? Check the fuel filter
to see if its clogged. Also when trying to start
the engine push the throttle lever to full throttle
if it starts just quickly pull throttle to a low setting.
   / Iseki tx1300f looking for engine repair manual #16
I'm wondering why when it quit running the fellow you
bought it from didn't fix it? Unless its not something
easy or cheap to fix. A running tractor is worth
more than a non running tractor.
   / Iseki tx1300f looking for engine repair manual #17
he probably didn't want to replace all the worn out injectors that are letting too much/unatomized fuel in the cylinders.. maybe he just didn't know what the problem was, and thought of a big repair bill from a shop..
,it is getting too much raw fuel it is not spraying a mist it's like a stream it tries to start but instead it just puts out black smoke indicating too much fuel
   / Iseki tx1300f looking for engine repair manual #19
Sounds like the typical loss of compression over time. The engine gets to point where it is on the cusp of not starting due to lower air charge in the cylinder (a lot of it is escaping the cylinder during compression). In turn this reduces temperature, increases black smoke as the glow plugs try to ignite the mixture (lack of oxygen) and reduces energy available from complete combustion to spin the motor up to speed for continued running. Spinning the engine faster helps as it reduces the time for the air charge to escape and the time available for heat to transfer into the cylinder head and block. That's why these will run great once started but getting them there can be difficult. A re-ring is required at a minimum. New pistons/over bore in the worst case. These engines start fairly well when the cylinders have good sealing, even down to temperatures near 0 degrees F with only glow plug assistance. It could be valve leakage. Valve adjustment is unlikely unless someone messed with it. New injector tips can help but the root cause is more likely excessive blow-by which is very common with these engines.
   / Iseki tx1300f looking for engine repair manual #20
he needs to examine why the injectors are putting out a stream instead of a mist first, though.. it could be bad injectors, or not enough pressure to them from a worn injector pump.. these parts are similar to an oil burner with either a worn nozzle, or low pressure to the nozzles, it puts out black smoke because the fuel is not being atomized properly..
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2004 GMC Sierra 3500 Flat Bed (A60460)
2004 GMC Sierra...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2024 Frontier FL1061S Hydraulic Flail Mower (A56436)
2024 Frontier...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
