30x50x16 pole barn construction
/ 30x50x16 pole barn construction #41
Its the same concept just different materials. You have to be sure the trusses are constructed correctly. Thats the key factor...these trusses are over built, which allows using a 2x4 purlin.
The potential sag that concerns me isn't rafter sag.
A test might be to walk on the roof after it's tinned. Can you tell where the rafters are?
/ 30x50x16 pole barn construction #42
On my 40x60x14 pole barn-designed for a 65#/ft gsl and with bottom loaded trusses on 12’ centers required 2x6 select structural purlins on 24” centers to meet code deflection criteria.
At low snow loads I could see the use of 2x4 purlins-As a structural engineer I personally would have spec’d 2x6 but if the engineering allows 2x4 and they meet the code deflection criteria then they are good enough
/ 30x50x16 pole barn construction #43
After much thought and reflection Ive come up with the following conclusion. I think I would trust certified engineers and building code enforcement officials on my construction project rather than anonymous internet posters.
/ 30x50x16 pole barn construction #44
Especially if those engineers are covering the warranty!!! :)
/ 30x50x16 pole barn construction #45
It looks fantastic and will give years of enjoyment. My only suggestion was to do whatever you think you may do now before moving in!
/ 30x50x16 pole barn construction #46
Really!? Now why??? :cool::rolleyes:
/ 30x50x16 pole barn construction #48
On my 40x60x14 pole barn-designed for a 65#/ft gsl and with bottom loaded trusses on 12 centers required 2x6 select structural purlins on 24 centers to meet code deflection criteria.
At low snow loads I could see the use of 2x4 purlins-As a structural engineer I personally would have spec壇 2x6 but if the engineering allows 2x4 and they meet the code deflection criteria then they are good enough
The only thing I question is if the live load (wind, snow, ice etc.) factor used in the design was interpolated to reflect contemporary weather extremes ?
I have not searched so I don't know if the design factor charts for things like storm water runoff (rainfall) and snow/ice loads have been updated in the last couple of decades??
/ 30x50x16 pole barn construction #49
Yea, because no one else is capable of reading a span table.... :rolleyes:
/ 30x50x16 pole barn construction #50
Using E=1,200,000,000 and deflection of 1/240. A 2x4, 12" oc as a rafter can span 11'3" and still support 10# sf live weight.
The motorhome goes is on one side. Not in a hurry to do all the concrete. Going to build a 10'x30' loft storage first. Going to run a couple 3" pvc conduit lines under the floor so I have access to the other side.
50 year warranty on the barn. 5 year warranty on wind damage. The roof is rated for 110 mph winds.
They do 12' on center trusses but you have to have 2x6s in between the trusses on edge on 2' center.
I am not going up on the roof...not my cup of tea anymore !! They did walk all over the roof before and after it was completely tinned.
Day 5. The roof is on ! There is a wire mesh screen under the ridge vent to keep birds from nesting. The skylights are a nice add. Our 2 dogs keeping a eye on things ! That platform truck is super. Should finish up the front tomorrow. 20180806_110226.jpeg20180806_133927.jpeg20180806_140535.jpeg20180806_163028.jpeg20180806_180608.jpeg20180806_134400.jpeg20180806_140544.jpeg
/ 30x50x16 pole barn construction #57
Looks nice.
/ 30x50x16 pole barn construction #58
I'm always confused when I see a thread titled "Pole Barn" and see a fully enclosed building being built.
Down here we refer to open structures as pole barns. Everything else is a barn or a building.
/ 30x50x16 pole barn construction #59
Off topic, but do you know who sells the metal trusses pictured?
4004SFL (A59228)
4004SFL (A59228)
16ft. Field Cultivator (A65640)
16ft. Field...
2026 Kearney 7'x20' Trailer (A64126)
2026 Kearney...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
2013 MAC LTT 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2013 MAC LTT 150...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
