30x50x16 pole barn construction
/ 30x50x16 pole barn construction #21
While I have full confidence in Morton and their engineers, I seriously question the use of a 2x4 on edge over a ten foot span. Their reputation of building quality buildings is well established, as is their reputation of inventing newer, faster ways to build a building. My concern is that every time that I've seen a 2x4 span 8 feet, it sags. A lot of the time it's just being stored for future use, and over time, it will sag under it's own weight.
It seems like a long ways- engineers who do truss and roof calcs seem to have their own “book”. For some reason it works.......
Same thing with standard trusses and gang nails
In every building that I've seen, and everything that I've read, to span ten feet, you need to be using 2x8's on edge.
Keep in mind that the metal roofing has ribs on 12" centers and spaced 24" apart. You are going to have 12 screws per 2x4 purlin and 10 purlins which would give you 120 screws per 10' bay. 50 year warranty says it will work !!!
/ 30x50x16 pole barn construction #23
I agree with Eddie's theories. I also agree with his faith in Morton. I simply know I wouldn't attempt it in my design. I'm using 2x4s on edge spanning 4 feet.
/ 30x50x16 pole barn construction #24
The metal and the screws do not support the load, the 2x4's do, and at the middle of that ten foot span, right around the five foot area is where I have my doubts in their engineers.
What I'm really hoping to see posted is that you talked to the engineers at Morton and they realized that the wrong materials went out and they are gong to ship out 2x8's right away. I'm sure it's just me, but I just cant grasp the concept that 2x4's on edge can support any sort of a load over ten feet. I'd be afraid to walk on it in five to ten years.
/ 30x50x16 pole barn construction #25
My barn isn’t a Morton, but is built in a similar way only engineered for a heavier snow load (Northern Ohio). Mine has 8’ span, but with so much overlap on the 2x4’s they remain flat with no sag after 10 years.
It was my choice to go this way, I could have went with 8' span. 10' was the limit on a 2x4. They do go up to 12' on center purlins but you have to use 2x6s on edge in between the trusses instead of on top of the purlins. The key factor in this design is the trusses. You couldn't do this with a 2x12 rafter,1/2" plywood and shingles vs a truss,purlin and metal. I still scratch my head when I think about using 2x4s, but those screws and metal roofing attached to the 2x4 do stiffen it. Its the same design used in commercial aircraft structures I worked on. In individual pieces they are flimsy, but when you connect them all together with the proper hardware it becomes much more stiff. Much like builders today still want to build with 2x lumber for joists and rafters, instead of using engineered lumber which will span incredible lengths.
You can only go this way by using metal roofing panels. Its light weight and no lap joints, just one continuous length, peak to eave per 3' panel. Its 26ga metal.
If you get the chance go to YouTube and search for RR Buildings. This guy really builds nice pole barn structures. He is based in Illinois. He is what sold me on 8' and 10' span with 2x4 purlins.
As always Eddie I value your judgment and thoughts. You always give sound advice !!!
I grew up near Bowling Green, OH. Don't get heavy snow here in Tenn. but the Morton Rep. said if it sags do to a snow load we will rebuild the roof free !
Day 4 and got 2 walls sided. It was just to muddy to do the other side, equipment kept sliding which is close to a sharp drop off. 20180803_144903.jpeg20180803_144834.jpeg20180803_144800.jpeg20180803_143043.jpeg20180803_151438.jpeg
/ 30x50x16 pole barn construction #29
Again, I agree with Eddie. The tin and screws do nothing to carry load.
I'm really surprised Morton offers this.
As to warranty. I never consider it. When my building fails no one cares but me....... :(
/ 30x50x16 pole barn construction #30
Thanks again for the pics!! I really like the colors!!!
/ 30x50x16 pole barn construction #31
...Keep in mind that the metal roofing has ribs on 12" centers and spaced 24" apart. You are going to have 12 screws per 2x4 purlin and 10 purlins which would give you 120 screws per 10' bay. 50 year warranty says it will work !!!
The design of the metal roof panels when fully installed equally distributes the dead load over the supporting members...
Thanks for explaning it in simpler terms than I did !!
/ 30x50x16 pole barn construction #33
Guys in the aircraft industry know that when you rivet the skin onto the many stringers and frames the assembly becomes much stiffer than the individual pieces were. Seems like the same concept here.
/ 30x50x16 pole barn construction #34
I wonder why all truss rafter buildings aren't built with 10ft span using 2x4 purlins? Definitely cheaper!!!
/ 30x50x16 pole barn construction #35
Couple things to think about I would have done differently. I would have buried pvc pipe one side to the other to pull water, air, alarm wire or electric through.
Wire then insulate and walls, (osb would be fine) before moving anything in. Once moving stuff in it's a nightmare working around. One good thing is I buried a barrel outside and everything goes through it, so water & propane main cutoff is there, it has a cast iron cover.
/ 30x50x16 pole barn construction #36
Honestly I don't think the same LRFD or ASD principles that apply to building structures are the same used for airframes...
I plan on running that pvc from side to side under the floor...thanks for the tip ! Easier than trying to run wire up a 16' wall then across 30'. Don't plan on insulating, maybe put in a wood stove for those cold days I need to work in.
Its the same concept just different materials. You have to be sure the trusses are constructed correctly. Thats the key factor...these trusses are over built, which allows using a 2x4 purlin.
Not sure what you mean. But building houses you have to add the weight of the plywood decking,shingles etc. and drywall,etc.
/ 30x50x16 pole barn construction #40
I should have been more specific. I wonder why all pole buildings aren't built with 10ft span using 2x4 purlins?
I hope your building is straight for generations to enjoy.
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
2019 Chevrolet Express Box Van, VIN # 1GB0GRFP7K1370206 (A65563)
2019 Chevrolet...
1997 MACK MIXER (A65643)
1997 MACK MIXER...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
