duffer
I use my FEL quite a bit, as I suspect most of you do. I make sure I grease it good, about every 10 hours or less of actual use.
My problem is this: The 4 "bottom" curl pins get clogged up with dirt, etc way too often. Today I took them all out, for the second time in a couple of weeks, and cleaned them out. Previously I drilled the center hole to just under 1/4" so that more grease could get to the pins but they're still clogging up.
Anybody got any ideas, hints, on how to prevent this, or do I just have to pull the pins every 8-10 hours and clean them?
Thanx.
(forum board would not let me edit the title of the post, it should be FEL, not FEW. Forgive me, I'm an old fart and not into typing all that much)
Thanx.
