FEW curl pins clogging
   / FEW curl pins clogging #1
duffer
Platinum Member
Aiken, SC
'16 Mahindra 2538
I use my FEL quite a bit, as I suspect most of you do. I make sure I grease it good, about every 10 hours or less of actual use.
My problem is this: The 4 "bottom" curl pins get clogged up with dirt, etc way too often. Today I took them all out, for the second time in a couple of weeks, and cleaned them out. Previously I drilled the center hole to just under 1/4" so that more grease could get to the pins but they're still clogging up.
Anybody got any ideas, hints, on how to prevent this, or do I just have to pull the pins every 8-10 hours and clean them?
Thanx.
(forum board would not let me edit the title of the post, it should be FEL, not FEW. Forgive me, I'm an old fart and not into typing all that much)
   / FEW curl pins clogging #2
Thanx.
I haven't had to do anything like that yet but I think our loaders are different. Mines a KMW while I think yours is Korean made unit.
   / FEW curl pins clogging #3
On my Branson I had to replace the grease zerks themselves since they wouldn't take grease. Had no problems since doing this.
My zerks work fine, no problems. But in the center of the pin, is an access hole to let grease get up thru the pin, and then start coating the outside of the pin. That center hole is what is clogging up consistently. It appears the tolerances are close. No wiggle in the bucket, or cylinders.
Guess I've been playing in the dirt too much.
   / FEW curl pins clogging #5
Sounds like your zerks are in the pins themselves instead of in the sleeves that the pins go thru ? Doesn't really matter, I guess. Maybe you aren't putting enough grease to it to push the old grease & dirt out - this issue has been beat to death over the years about leaving the grease build-up at the ends of the sleeves to help "cap" it from letting more dirt back into the interface.
When my tractor was new I was pretty **** about pressure washing it regularly and not letting the grease build up at all the pins - that was then. For the about the past 10 - 12 years I've just let the grease build up and just keep greasing and have had NO problems with ALOT of dirt/loader work. Yes, my tractor looks like crap but it works well when I need it to. I just wipe the zerk off before I grease so I don't push the dirt into the interface of the pin & sleeve. My tractor has always lived outside and Mother Nature helps keep the grease caps down to a "reasonable" size over time. If you worry about how your tractor looks or cannot keep from getting some grease on your work clothes when working around it, this may not be the option for you.
   / FEW curl pins clogging #6
Thanx.
Often I find the dirt cake can be dislodged be applying pressure and then curling the joint back and forth. A a grease gun hose works best for this of course, but also because it expands a little under pressure.
Also, caps are available for the zerks. ... Theyre cheap.​
   / FEW curl pins clogging #7
Is this a case of the wimpy grease gun that doesn't build much pressure? I have some guns that will force a zerk right out of it's threads if you try.
Re: FEL curl pins clogging
I already drilled out the center holes to almost 1/4 inch to let more grease flow thru the pin. I also leave the excess grease as a "cap" on the ends.
I guess I need to grease it even more (hard to imagine) than I have been to keep the hole clear of debris and caked dirt.
Thanx for the ideas and hints.
   / FEW curl pins clogging #10
Perhaps you just need to find a different grease that doesn't firm up like that.
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
2019 Komatsu PC490 Hydraulic Excavator (A49461)
2019 Komatsu PC490...
2012 Ford F-350 Omaha Crane Service Truck (A48081)
2012 Ford F-350...
2011 Jeep Grand Cherokee Overland 4x4 SUV (A48082)
2011 Jeep Grand...
2015 GEM e4 Electric Golf Cart (A48082)
2015 GEM e4...
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
