David Brown governor repair process
/ David Brown governor repair process #1
Uncle Dan
I have a DB 3800 Selectamatic that has been setting for 4 years. I have it running but the governor does not work. To remove the governor do I need to remove the distributor first?
/ David Brown governor repair process #2
LOL... I was thinking his name was Jerry Brown. And that would be a fix beyond the scope of even THIS forum...
Thanks, Tody I removed the top of the governor and the distributor comes off with it. After cleaning everything and making sure the centrifical weight would move freely I put it back together Started engine and it is running well I was able to drive the tractor for the first time since I bought it last year. All gears and other parts seem to work, but I might have to work on the brakes.
/ David Brown governor repair process #4
That's good uncle dan! I tend to not work good either after I sit for a while too.
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
200 gal Poly Tank (A66408)
200 gal Poly Tank...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
