Rounded off drain plug
/ Rounded off drain plug #402
He may not appreciate the attention.
Or he might have some ask-hole in him like me.
I used to go around the shop and ask everyone what they would do, then do what I had set out to do and everyone more experienced advised me against. Ask hole. Now I don't ask. Haha. If I do, I try to listen.
May have just been youth.
/ Rounded off drain plug #403
A mechanic mentioned in another thread might suggest a 1 inch drive pulled on by a backhoe to free up that plug. Or maybe it was tightened by a backhoe ? :laughing:
Apologies, work and life pulled me away. Plug is still in, nothing's been tried recently. Although I have made some hay.
/ Rounded off drain plug #405
No problem, we know you Kan do.
/ Rounded off drain plug #406
Learn to weld! Everyone that owns tractors needs basic welding. Any cheap 160+ amp stick welder should do it. Weld a piece of rebar or whatever to the thing and you'll have leverage, and have heated it up enough to break it. Maybe you'll need a buddy to show you how for this one but that's how to stop the wheel spinning. Good luck!
/ Rounded off drain plug #407
yeah, you just need a good 11 KW generator to run it, or buy a welder/generator..
/ Rounded off drain plug #408
Rebar would likely bend.
/ Rounded off drain plug #409
Good to hear from you Kando. You obviously started an interesting thread. Please keep us updated as you are able in between work and life and haying, etc.
/ Rounded off drain plug #410
I read the first 5 pages thinking how could this thread get to 41 pages to remove a bolt. Kan稚 Do has had the problem for over 3 months now.
I have never drained the oil out of my Mercedes and have 272k miles on it.
I assume this tractor has a dip stick? Use an oil extractor pump. Small plastic tube down the tube...apply vacuum and done. Simple, and little or no mess. KISS
Got mine from Northern Tool...Mity Vac
/ Rounded off drain plug #411
I tried that on my mom’s 2015 suburban because I didn’t have a catch pan to hold the 8 quarts.The stupid thing ( I hate that car) had a stopper at the end of the dipstick hole and I couldn’t get the hose through the bottom.
/ Rounded off drain plug #412
yeah you're right, guess i meant like a little piece of rebar or square bar or whatever that you can grab with vicegrips or a monkey or pipe wrench, just something that you could really grab onto with no difficulty. the heat too...
/ Rounded off drain plug #413
Monkey wrench, now there is a description I have not heard in a while. I have a couple of monkey wrenches but do not use them much.
/ Rounded off drain plug #414
nuh-unh. little cheap inverter welders run off a light socket 15-20 amps. never popped a breaker with mine and it goes up to 200 amps. I agree if you've got to find a welder and a generator it gets to being a pain in the ***. I've never tried it, but has anyone ever seen people weld with a car battery? I bet you could stick that thing with a big battery, a jumper cable and one 6013 stick problem solved.
/ Rounded off drain plug #416
What model Mercedes?
/ Rounded off drain plug #417
Great idea, suggested WAY back on post #120 and jumped on by a lot of people as something that will cause cancer in small children and plague.
I know a lot of people use mityvacs for engine oil and transmission oil change. Could that work here to get the old fluid out?
I've used my little HF $5 hand pump to take a half quart out of my VW when they vastly overfilled it.
/ Rounded off drain plug #418
/ Rounded off drain plug #419
Google is selling the info to Russia so they can convince all the tractor people here to buy Russian made tractors. lol Probably making them without drain plug, using a petcock.
/ Rounded off drain plug #420
I could accept a petcock before I could accept a Russian tractor. :eek:
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
CASE TR310B SKID STEER (A62129)
CASE TR310B SKID...
INOP/NON-RUNNING 2012 Ford F-450 Ambulance Truck, VIN # 1FD0X4GT2CEB23465 (A61165)
INOP/NON-RUNNING...
2017 Ford Transit 250 Passenger Van (A61568)
2017 Ford Transit...
Gooseneck Stock Trailer (A64047)
Gooseneck Stock...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
