Rounded off drain plug
/ Rounded off drain plug #402
He may not appreciate the attention.
Or he might have some ask-hole in him like me.
I used to go around the shop and ask everyone what they would do, then do what I had set out to do and everyone more experienced advised me against. Ask hole. Now I don't ask. Haha. If I do, I try to listen.
May have just been youth.
/ Rounded off drain plug #403
A mechanic mentioned in another thread might suggest a 1 inch drive pulled on by a backhoe to free up that plug. Or maybe it was tightened by a backhoe ? :laughing:
Apologies, work and life pulled me away. Plug is still in, nothing's been tried recently. Although I have made some hay.
/ Rounded off drain plug #405
No problem, we know you Kan do.
/ Rounded off drain plug #406
Learn to weld! Everyone that owns tractors needs basic welding. Any cheap 160+ amp stick welder should do it. Weld a piece of rebar or whatever to the thing and you'll have leverage, and have heated it up enough to break it. Maybe you'll need a buddy to show you how for this one but that's how to stop the wheel spinning. Good luck!
/ Rounded off drain plug #407
yeah, you just need a good 11 KW generator to run it, or buy a welder/generator..
/ Rounded off drain plug #408
Rebar would likely bend.
/ Rounded off drain plug #409
Good to hear from you Kando. You obviously started an interesting thread. Please keep us updated as you are able in between work and life and haying, etc.
/ Rounded off drain plug #410
I read the first 5 pages thinking how could this thread get to 41 pages to remove a bolt. Kan稚 Do has had the problem for over 3 months now.
I have never drained the oil out of my Mercedes and have 272k miles on it.
I assume this tractor has a dip stick? Use an oil extractor pump. Small plastic tube down the tube...apply vacuum and done. Simple, and little or no mess. KISS
Got mine from Northern Tool...Mity Vac
/ Rounded off drain plug #411
I tried that on my mom’s 2015 suburban because I didn’t have a catch pan to hold the 8 quarts.The stupid thing ( I hate that car) had a stopper at the end of the dipstick hole and I couldn’t get the hose through the bottom.
/ Rounded off drain plug #412
yeah you're right, guess i meant like a little piece of rebar or square bar or whatever that you can grab with vicegrips or a monkey or pipe wrench, just something that you could really grab onto with no difficulty. the heat too...
/ Rounded off drain plug #413
Monkey wrench, now there is a description I have not heard in a while. I have a couple of monkey wrenches but do not use them much.
/ Rounded off drain plug #414
nuh-unh. little cheap inverter welders run off a light socket 15-20 amps. never popped a breaker with mine and it goes up to 200 amps. I agree if you've got to find a welder and a generator it gets to being a pain in the ***. I've never tried it, but has anyone ever seen people weld with a car battery? I bet you could stick that thing with a big battery, a jumper cable and one 6013 stick problem solved.
/ Rounded off drain plug #416
What model Mercedes?
/ Rounded off drain plug #417
Great idea, suggested WAY back on post #120 and jumped on by a lot of people as something that will cause cancer in small children and plague.
I know a lot of people use mityvacs for engine oil and transmission oil change. Could that work here to get the old fluid out?
I've used my little HF $5 hand pump to take a half quart out of my VW when they vastly overfilled it.
/ Rounded off drain plug #418
/ Rounded off drain plug #419
Google is selling the info to Russia so they can convince all the tractor people here to buy Russian made tractors. lol Probably making them without drain plug, using a petcock.
/ Rounded off drain plug #420
I could accept a petcock before I could accept a Russian tractor. :eek:
49"X79" WIRE MESH TAILGATE (A62130)
49"X79" WIRE MESH...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
25' SINGLE AXLE VEGETABLE TRAILER 5TH WHEEL (A62130)
25' SINGLE AXLE...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
2016 Jeep Renegade 4x4 SUV (A61569)
2016 Jeep Renegade...
2016 Nissan Pathfinder SUV (A61569)
2016 Nissan...
