OK, I have an 8050, you say you are buying new, check the build date on a 8050 I know that branson still listed it on their website the last time I looked however I think that you will find that 2015 or 2016 was the last year built and brought into this country. Branson says that there is no service manual available for this tractor. It has been a decent tractor for me, it has had a few issues, my dealer has been decent.
If you go to the Branson forum I have posted a few times about issues with mine.
When I bought mine I compared the 7845 and the 8050, the 7845 was a 1000 pounds lighter with the same engine, the 7845 has more transmission gears and 3 speeds for the pto and weights a lot less the castings on the 8050 are much beefier and the front axle has a planetary reduction which I prefer to the spur and bevel on the others.
The 8050 loader is self leveling which has it plus's and minus's. The "clutch" on the 8050 and I am pretty sure on the 7845 is not a dry clutch, they have multi disk wet clutches one pack for forward and another set for reverse, the tractor does not need to have the clutch pedal used to move, you can just move the shuttle to forward or reverse and the tractor will modulate the clutch pack for you, that is what the power shuttle does. It can be jerky and hard to modulate trying to back up to hookup to the drawbar or 3 pt. also attaching to the loader ssqa as it is difficult to gently ease it an inch or two. The 8050 comes with the euro style hook lift arms which is a type of quick hitch for the lift arms, it handy.
The rear remotes do not have a float position, one does have detents for continuous operations. The cab is decent sized, I have bounced my head off the ceiling a couple of times.
