Weather Underground Wundermap problem
/ Weather Underground Wundermap problem
I don’t use the browser but have the app on my iPhone. The app has been coming up with the temp but everything else is blank- map, extended forecast etc. Sometimes refreshing fixes it, sometimes closing the app and restarting it works while other times I just have to wait a few hours and it works again.
Have you tried clearing out your cache, history etc? I’d assume since you are using two different browsers the above wouldn’t apply but I’ll throw it out there as a long shot fix.
I did try clearing out the cache and history with no improvement.
Here's a screen shot of what I see (and don't see)!
Prior to Monday Jun 18, I had a map of Southern New Hampshire with all the PWS
displayed with wind speed and temperature.
/ Weather Underground Wundermap problem #12
Been using this app for over two years on a S4 and now the S8.
Now it opens up and does not load. removed week later reinstalled same thing.
Something is up with the leadership of this service asleep at the wheel.
SO removed it for good.
Use NWS. Just now getting adjusted to format.
Was planning to buy weather station to support this app as well.
Now will look for weather station better suited for local use.
/ Weather Underground Wundermap problem #13
Well - as I said previously, post #4, I've given up on WU. Too many nits, kinks and non-functional "extensions???". Like many sites, of all types, they don't cuddle up to Apple so well. I'm uploading my station data thru Weather Cat 3 to PWS Weather. No problems at all making that connection.
One thing that I forgot to mention in my original post is that this occurs
with both of my computers, both running Windows XP. One is a desktop
and the second is a laptop. As of this post, I'm still experiencing the same
problem.:confused::confused::confused3:
/ Weather Underground Wundermap problem #15
I don't think - OH, H E L L - I know, I've never been so involved in setting parameters, codes, passwords, names etc as this weather station situation. Then right in the middle of all this I get an email from my son - who has a degree in computer technology - saying great - you have an Aeris API key. Hey - to me - API is Alaska Psychiatric Institute. The one and only facility of its type in AK.
Sweet screaming Mary - I've got more darn charts and graphs roaring across my screen ............
This could be fun when I learn what I'm doing
/ Weather Underground Wundermap problem #16
I haven't had any issues with the WUndermap loading, but I have had issues with the '10 day' graphs not loading. Ever since Weather Channel bought them, they have been making more and more "improvements" and making the site less and less useable/enjoyable.
/ Weather Underground Wundermap problem #17
I doubt they support XP anymore, perhaps they made a change that killed compatibility.
I use WU only on computers, I am running Win 7 and Ubuntu, no problems beyond the usual slowness. Using Firefox on all.
/ Weather Underground Wundermap problem #18
B7510HSD - - you can check out my local weather data at - - PWSWeather.com. Click the tool tab at the top and enter my station ID - scabrock44u.
Or the direct approach - PWS - Station Observations for SCABROCK44U
/ Weather Underground Wundermap problem #19
It took a while to find you. The id. number brought up a map of america. I zoomed and hovered over some locations and found yours.
Pretty cool sight. and readings every 10 minutes. Wow.
/ Weather Underground Wundermap problem #20
I added the link at bottom of post# 18 - after I tried what I suggested above. Now if you want to get really tricky. Go to my site page - use the link at bottom of post #18 - see the little picture with the obnoxious weather vane - click on satellite view - click enlarge. Nice aerial shot of my place here in Amber.
The "default" setting was a reading and transmission every FIVE minutes. It made the red temperature trace look like somebody was smearing concord grapes on graph paper. I lengthen it out to every ten minutes and may go to 15 or 20 minutes to get better definition on the trace.
2012 Chevrolet Sonic Hatchback (A61569)
2012 Chevrolet...
2010 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2010 DRAGON 150...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
(4) ST225/75R16 Tires (A60462)
(4) ST225/75R16...
KBH Mule Boy (A60462)
Auger with 2 bits for mini skid steer (A61567)
Auger with 2 bits...
