Better quality finish mower?
/ Better quality finish mower? #1
Lee Majors
Midland nc
Ls 3033H & Bobcat CT235
Right now I've got a 72" king kutter dual side discharge. My LS 3033 apparently has more torque then the mower can handle and it slips the belts in tall grass. Is there a better quality finish mower that can handle tall grass without slipping mower belts? I've adjusted the tension on the belts, new spindles, sharpened blades & raised my PTO RPM without it helping at all.
My parents have a rear discharge version of mine and i've used it several times, although its better then mine its still not as strong as my commercial mowers.
I own a lawn maintenance business by trade so im used to the power that they transfer to the deck where the motor will bog before the belts will slip.
/ Better quality finish mower? #2
I have a 1991 Farm King that I converted to a rear discharge mower. I have no problems keeping the belts tight enough to make the tractor work.
/ Better quality finish mower? #3
I have kk 72" side discharge mower. If It's a finish mower, no way will the belt slip if used right. With that said, i mow my field with mine, if grass is too tall, raise front end up some. Only replaced belt once in almost 20 yrs. Have to slow down in real tall stuff. 0508181856_HDR.jpeg
/ Better quality finish mower? #4
This Woods does not slip,,, yet,,, when powered by a 41HP John Deere,,
The mower simply ejects everything out the back.
I cut 3 foot tall grass with it,, it looked like mowed hay, the only reason to slow down is to get a better cut.
When cutting 3 foot tall grass, the cut looks more like a flail mower cut than a finish mower cut,,,
This mower gives the best cut of any mower I have ever owned, GT, dedicated mower, or tractor mounted,,,
/ Better quality finish mower? #5
Perhaps the tension spring is weak, or in the wrong location? OR maybe you are just going too fast for conditions.
IF you actually look at HP ratings for single B-section belts, using all the pulley diameters and speeds.....it would be an eye-opener. Nothing in industrial stuff would ever be designed the way mowers are. And that not just rear mowers. Thats ZTR's too. Most pulley and speed combos of current mowers.....a single B-section belt is actually only good for about half the HP we are feeding them. Mowers get away with it because you arent always pushing it to the max. And replacing belts 2 or 3 times in 1000hrs use (about 300-500hrs per belt) is considered acceptable. That would never fly in an industrial setting.
But regarding your issue, it would help us to understand just how tall/thick the grass is you are cutting. And just how fast are you trying to mow it? Because a belt drive finish mower may not be the right tool for the job. A bushhog or flail might yield better results
/ Better quality finish mower? #6
I had a 16' triplex Alamo wing mower. PTO direct drive. The belts never slipped, but it would not cut tall grass. It was all rear discharge (the only game in town). I reconfigured the machine to sit higher off the ground, beyond the normal wheel adjustments, so I could cut long grass, but then it is not really a finishing mower. But I liked the good cut and high speed over a bush hog type mower. Just the noise was cool!
I also often cut late in the fall when vegetation has dried up.
You can't have your cake and eat it too.
/ Better quality finish mower? #7
I work on a fully hydraulic portable 34hp sawmill. The hydraulic pump was powered by a belt rated for less than 1hp. Big shock that they never lasted very long.
/ Better quality finish mower? #8
How did you set up your 16' triplex Alamo wing mower to cut higher?
What is the max height can you cut at?
/ Better quality finish mower? #9
Last year, my finish mower was not doing the job, belt slipping in heavy grass, just not working as well as it had. I had stored it outside under tarp that winter and when I pulled the covers all looked ok, with some rust here and there. Turns out the pivot on the tensioner was frozen. I cleaned things up and replaced belt, sharpened blades. All good then. I stored inside shop this last winter and need to sharpen blades, but am hoping everything else is good to go. I am behind again this year on my mowing so much of the grass is 5-6' tall (in low areas that are wet or sub irrigated)... not as tall on the hillsides.
Make sure the pivot is lubed and rotates properly. If you got oil or grease on belt, clean things up and replace the belt.
/ Better quality finish mower? #10
How about some pictures of it with the covers off? Maybe someone will notice something. Never hurts to have an extra pair of eyes on it, or, in this case, a couple hundred. :eek:
/ Better quality finish mower? #11
In your post you said you raised the pto speed some...might be the problem. It does not matter what you are cutting nor how tall or dense, you should verify the pto speed for that cutter and always run it at that pto speed to get the tip speed it is designed for.
Belt slipping often can be picked up on by listing or the way grass is pushed over. Just because it a tractor mower does not mean you can not over load it, regardless if lawn grass or such as johnson grass. Also look at the blades and be sure those are the correct blades and are installed correctly...all do not rotate the same direction.
/ Better quality finish mower? #12
We have used a woods RD7200 for 21 years. 1000’s of hours of hard use. Used Kubota b20, L3800 and b26. Have only had to replace one belt, no bearings but lots of blades. Like Oregon g5 gator blades the best. Had problem with the mower spindle shafts bending. Suspect tractor steering and traction particularly for trimming is too much for the mower design. Replaced the original shafts with 4140 1” tool steel and helped for about 10 years. They bent too and generally don’t bend back without breaking. The mounting arm bushings were worn too. Expensive OEM parts and the OEM parts didn’t last. On eBay bought 4, 3500# axle stubs and hubs $119. Welded axle stubs to caster wheels. Cut off the mounting arm worn bushings and welded a 1/2” plate cut to bolt the hubs to. This has worked great for 10 years now. Money saved from this one job paid about half the cost of a hypertherm plasma cutter that made the job easy to do. Wife does most of the mowing so got to keep her happy.
/ Better quality finish mower? #13
Sounds like you need to cut more often.
Pics of mower pullies might give some ideas.
Type and height if grass may be key in finding the problem.
There isn't a finish mower I am aware of that gives the cut performance of professional lawn mowers. They operate at a lower blade speed.
My 6 foot Agmate has a very simple 2 belt setup with 5/8" belts . Rear discharge lessons the blade drag in my opinion. I installed a smaller pulley from a smaller mower on mine to increase blade speed. Seems to help a little but it doesn't cut like a Dixie Chopper.
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Bush Hog RDTH84 (A64126)
Bush Hog RDTH84...
John Deere 6400 (A64126)
John Deere 6400...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
