product name question
/ product name question #1
kclark2227
Kannapolis, NC
Kubota L4701 4WD HST
I am having a hard time remembering and finding what I am looking for since I can't remember what to call it. What I am looking for is a chain "set" for the FEL. It would have a chain that is several feet long with a Circle ring (about 3-4" in diameter) attached to one end. It would also have 4 chains several feet long attached to it so 5 chains connected to the ring. You connect one chain to the bucket and then use the other 4 to lift items that would allow you to transport items and rotate them, etc. What is it called?
/ product name question #2
The only kind I've seen has an oblong ring with 2, 3, or 4 chains attached to it for lifting machinery. You toss the big ring on the hook of a crane then the "legs" get attached to the item you wish to lift.
We called them simply "chain slings."
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
John Deere TX Gator (A60462)
John Deere TX...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
