Propane tank fire pit
/ Propane tank fire pit #1
IHDiesel73L
I've been wanting a good "bowl" type fire pit for our patio but really heavy ones (ie: won't rust out in one season) are extremely expensive. The other day I was driving down the road and saw a 420lb/120 gallon propane tank laying on its side next to an old garage. I got in touch with the property owner and scored it for $25. I plan on cutting the tank somewhere below the bottom 1/3 so that I have a nice bowl sitting on a pedestal:
First things first before I do anything I'm going to remove the valve and simply let it vent, assuming there's anything in it at all. I've heard of people filling or flushing them with water before welding or cutting but propane vaporizes at -44ーF so once the tank is depressurized (by removing the valve) and vented to atmospheric pressure it simply turns to a gas and escapes. What's the best way to get a nice clean cut all the way around the body of the tank? Once it's cut open I'm just going to coat it with BBQ paint, put some holes in the bottom for airflow, and maybe a grate to hold the logs/coals off of the bottom.
/ Propane tank fire pit #2
U can also displace any fumes by blowing air in.
Propane is heavier than air so having the opening propped to face downwards will help.
/ Propane tank fire pit #3
A cut off wheel in a skill saw or big grinder will leave a edge that's easy to "tough up" to a nice safe edge with a sanding disc or a flapper wheel.
You should make one out of each end!
I've never used one of those cutoff wheels in a circular saw. I wonder if I could set the blade so that it's poking just a 1/16" of an inch or so below the shoe and very slowly go over the line taking off a small amount of metal each time until I break through? The thought of it jamming and exploding if I go too deep is a little scary. As for using both ends, might as well! Maybe I could sell the other one. I need a steel pit for my patio-the only other pit I have is back by our pond which is just a bunch of stone I gathered up from the property.
/ Propane tank fire pit #5
Use the top to cover the bottom when not in use.
Bruce
/ Propane tank fire pit #6
It's easier to "plunge cut" with a skill saw over a grinder. Set the front of the saw's shoe plate down on the tank and slowly plunge the wheel into the tank. The more "blade" you have in the cut (depth) the straighter cut you get, you just need to start out where you want it.
Great idea of bcp on a cover!:thumbsup:
/ Propane tank fire pit #7
The tank can still be "HOT" even after it is empty for years!!!!!!!
I used to repair semi tankers and fuel/gas tanks and there are tricks if you can't clear them.
We used to run a steam cleaner in the tank for hours then check with meter.
They had to be checked hourly to make sure they did not outgas.
/ Propane tank fire pit #8
I used the same tank for my fire pit. I marked a cut line with a sharpie, holesawed out a starter hole and cut the tank with a sawzall. took all of about 20-30min. I didn't have air holes initially but found out I needed them after the first fire. The Mercaptan oil in the tank stinks...get it on your clothes or boots and you might as well throw them away. I'd fill it with water at least and dump it before cutting. The tank I used never had gas in it so I skipped the de-gassing.
/ Propane tank fire pit #9
I've made quite a few of these (literally 100s) over the years. 1st, just because it stinks does not mean there is still propane in it. 2nd, never trust a tank that you have not personally purged!!
Pull the valve, invert the tank, and leave in the hot sun for a couple weeks to vent the propane and cut down on the stink. You'll need a quality pipe wrench and a cheater bar to pull the valve. Strap the tank to the tractor, etc to keep it from turning, those valves can be TIGHT!!
I like to purge with dry ice (CO2) or hook a hose to the diesel exhaust from your tractor and let it purge a few minutes. Nitrogen and CO2 in the exhaust does the job too and is cheaper. The soapy water method works, but then you have a 100 gal of oily stinky water to dispose of. Older tanks always have some oil in the bottom that was used as a carrier for the mercapitan odorant. Have some oil dry, sawdust, etc to deal with it and do this outside as whatever that mercapitan gets on WILL SMELL FOR WEEKS!!!
I use a plasma to get a nice clean cut and finish with a flap disk to smooth and round the edge. But a sawzall going slow with some cutting oil works too, you'll just need a couple of blades. Abrasive cutting wheel in a grinder always scare me more than the tank itself, too dangerous they bind.
You should be able to get 2 fire bowls and at least 1 if not 2 fire rings from that tank. Sell the extras to offset your time or gift to a neighbor.
/ Propane tank fire pit #10
I used an aggregate cone crusher mantle for my fire pit. Even worn past its usable life at the quarry, a two inch thick chunk of manganese makes for one heck of an outdoor living experience! 20180609_203147.jpeg
/ Propane tank fire pit #12
First things first before I do anything I'm going to remove the valve and simply let it vent, assuming there's anything in it at all. I've heard of people filling or flushing them with water before welding or cutting but propane vaporizes at -44ーF so once the tank is depressurized (by removing the valve) and vented to atmospheric pressure it simply turns to a gas and escapes. What's the best way to get a nice clean cut all the way around the body of the tank? Once it's cut open I'm just going to coat it with BBQ paint, put some holes in the bottom for airflow, and maybe a grate to hold the logs/coals off of the bottom. diane 35 usa: Empowering women's health with a trusted contraceptive solution. Discover a reliable option tailored to your well-being and hormonal balance.
I have had a wood fire pit forever and while I enjoy the look and feel of a real fire it is causing some problems with neighbors. The wind quite often blows the smoke right into his window and I understand his concern. I do my best not to be a pain but when I rent the place the renters are not always as conscientious. They often light a large fire and let it burn for hours even when they are not sitting around it. I am going to try to solve the problem with a propane pit. I see the big concrete bowls and they look pretty sharp. Does anyone have any recommendations on the better quality yet reasonably priced brands or models?
I do like the idea of flicking a switch to turn it on vs getting the wood going. How about smores? Do they taste ok over a propane fire?
/ Propane tank fire pit #14
your idea should work quite well, what is your patio made of ?
This is mine, I ask the local highschool welding class to do it as a project, its a simple plate your choice of height (mine is a bit too high to my liking) that they plasma CNC (Computer numerical control) design on it of my choice for air intake then they rolled it in a circle and welded it.
/ Propane tank fire pit #15
There was an incident on a neighboring farm a few years back when someone cut up a propane tank. The valve was removed and the tank left inverted for a week or more. A farmhand tried to cut it with an angle grinder and there was an explosion. Luckily, there were no serious injuries but one of the barns was damaged.
The accident was investigated by the insurance company who consulted a propane company. Apparently, the Mercaptain odorant can form a coating on the inside of the tank. When heated, it emits a smell and also a flammable gas, which in this case, caused the explosion.
I've cut up a few since then and always fill them with water. I use a cordless Sawzall with water still in the tank.
/ Propane tank fire pit #16
What’s the fuss about having a metal type container for a fire pit?
Just build the fire on a non combustible material that’s large enough to contain all the flammables. Concrete sidewalk blocks or flat slate rock work well.
/ Propane tank fire pit #17
my personal fuss about is concrete crack and fall apart due to uneven heating and cooling, certain rocks will hold but it need to be mafic type rocks It can't be sedimentary rocks as it will crack and break in piece's like concrete... I also like the side wall to be tall enough to break the wind, if not on a windy day you don't see the flames and the wood volatize which is hard to accomplish with rocks only.
/ Propane tank fire pit #18
In one case I used concrete sidewalk blocks laid flat for 15 years or so With no cracks. In the picture shown the slate rocks have been in use for over 20 years.
They both sat above normal ground elevation with no side walls. Gives excellent burning conditions. In the picture shown the flames are easily visible. The radiant heat is good, the fire gets lots of air and burns well. The air flow keeps the base cooler.
/ Propane tank fire pit #19
From your picture it look like you are in a forest so that shield the wind, it depends on the surrounding condition, I need to shield my fire on my proprety because I am surrounded by field so a lot more wind, I mean If there is zero wind I don't have too. I am surprises about the sidewalk block but when I initially read it I was thinking of concrete blocks and not sidewalk block. Setting a fire on concrete or rocks slab vs shielding around the fire is different as there is a lot more heat on the side then under a fire. Ashes also insulate the surface below it. If you look at the rocks from my fire pit you see how a lot of them are crack... the darker rocks would need a lot more heat to crack since they are mafic rocks. Shielding around a fire is nice since it keep the heat and wood in so you don't have to keep moving the logs back to the top / middle of the fire for them to burn all they way.
/ Propane tank fire pit #20
I built a fire pit with landscaping blocks 20 some years ago. It has a dirt bottom but the blocks are stacked up 6 high and about 4' diameter with a lower wall on one side for viewing.
They all cracked but they have held together just fine. In fact, I recently backed into it while mowing and pushed part of it in about 4" and it is still standing solid.
2019 K&K Equipment Trailer, VIN # 1K9PE2029KA175459 (A65563)
2019 K&K Equipment...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2017 TROXELL  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
17601CFL (A59228)
17601CFL (A59228)
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
