Modern Pow'r Pup questions
/ Modern Pow'r Pup questions
Why a Cat 0 3 pt hitch? I had a tractor with that a few years back. It was possible to find implements that could be used, but a Cat 1 would have been much better. I guess if you already have some implements for Cat 0 it would make sense.
It's a toss up right now for me which one to go with. Cat 1 does have more to choose from, since it's way more mainstream than Cat 0. I think it's just a pin size difference between those two and the dimensions were the same correct?
Get a 8.8 out of a Ford Ranger pickup, cheap, solid and readily available. Narrow the long side so you can use a short side shaft in that side. If you get lucky and find one with disc brakes. I would do the dual master cylinders.
That's the plan. Would need one out of a Ranger with the 4.0 or an Explorer/Mountaineer with the 4.0 or 5.0. The smaller engine Rangers (3.0 and 2.3) used the 7.5 rear end. Not that it would matter much, but I think my gear selection would be better with the 8.8. Gear wise I was thinking 4.56 in the rear end.
If you're scrounging, older cars before double circuit brakes had single circuit masters. Like 50s-60s VW bugs. Some of those parts are still pretty easy/cheap to find as replacements. Clutch masters are also single circuit (though not all of them are set up to use metal lines).
That was one option I was looking at last night, however, I'm not sure if it would work on Ford brakes. Something about different piston size on the master cylinder can cause the system not to work.
/ Modern Pow'r Pup questions #12
It might be easier to get a front Dana 30 Jeep axle and shorten the long side and use a short axle then weld the knuckles straight. They can be had cheap and are plentiful for parts.
/ Modern Pow'r Pup questions #13
Its all in the ratios in bore diameter and throw of the master, vs the caliper.
You need to see how much fluid the caliper needs to move and that will tell you how big the master cylinder needs to be and how much throw it needs.
Aaron Z
/ Modern Pow'r Pup questions #14
What does all that axle fab get you that a used Cub Cadet garden tractor does not have?
The old tractors were fabricated out of old car parts,,, because there were no used tractors to purchase,,
You can have a JD 650 for a couple grand, 4WD, pto, 3PH,,, diesel,,, and on,, and on,,,
My biggest concern on my tractor is,,,
"Where do I clean/wax next??"
and,,, I can cut grass with it,, if I want to,,,
ohhh,, and the 2 cylinder diesel sounds soooo good!! :thumbsup:
I don't exactly have a disposable income to buy something out right. Yeah I've thought about getting a large garden tractor, but at this point i don't have that kind of income. It's easier for me to save buy parts at a time and the steel...little here little there.
/ Modern Pow'r Pup questions #16
Not sure where you are but in my area the only thing "a couple grand" buys you is a pile of crap. You can't even buy a 50 year old 9N for 2 k here.
Send me the info and I'll buy all the 2k diesel 4x4 tractors I can find.
About a year ago, someone in Minnesota was selling an International Cub for $4500. Only came with a cultivator I believe. At the time, I thought it was a glorified garden tractor, because I've only had heard about the L and LA John Deere tractors.
You have to look very hard to find good deals like that... $2000 for a small 4x4 tractor would be nice and hard to find in decent condition that doesn't require much work.
Just browsed Lincoln Craigslist and found a JD425 with pto tiller for $5500. Way more than what I'm willing to pay up front.
I forgot to ask, besides buying a used garden tractor, if I wanted to add power steering to this tractor, what size hydraulic cylinder would I need to use bore and stroke size?
/ Modern Pow'r Pup questions #19
It's a toss up right now for me which one to go with. Cat 1 does have more to choose from, since it's way more mainstream than Cat 0. I think it's just a pin size difference between those two and the dimensions were the same correct?.
Not really, there is a difference in the dimensions, the Cat 1 is wider and probably taller. There are spec charts online, or do a search on this forum, they've been posted before.
/ Modern Pow'r Pup questions #20
Not a very big one. I just fixed one on a 4x4 JD tractor (about 30 hp) and it is tiny. I would guess about a 3/4" rod and a 1.25 bore. Depending on the geometry of the set up the stroke will have to be determined.
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
Flatbed Truck (A55973)
