3-Point Hitch LS mt125 3 point "update"
/ LS mt125 3 point "update" #21
Just not getting the point of all this, I just fold up my 3 point and leave it on the tractor when I put the back hoe on. Some days I have the hoe on and off 3 times a day switching with the box blade, landscape rake, and back hoe . no problem at all and only takes a few min to do.
Do you just fold the lower arms up between the frame? I figured the top link would come off, but don't the arms interfere with anything?
/ LS mt125 3 point "update" #23
Now that's a really interesting question here. Install the lower three point arms and forget it?
/ LS mt125 3 point "update" #24
Well "LSmt125owner" this subject just gets more interesting. My local big New Holland Dealer just got in a nice selection of the "New Holland" Workmaster 25S and extremely interesting to look over. The original LS MT125 is truly the factor special as the trim package is much nicer on our tractors but they are truly identical with the Workmaster 25S! They had one there with the backhoe on it like my tractor and they also had a couple of the tractors that were NOT setup for the backhoe. But here is where it gets interesting............ They had their 3 point hitches mounted up and the "NEW" hitch mount was factory installed and I could see all the parts mounted up and in place. The bottom line is all I need to do to install this on my tractor is buy the two "pins" #40369516 and cut my original long bar that we have to take a tire off and install and I'm almost home free. I need to take the lower hitch brackets off and cut the outside welds to slip out the bushings that LS put in there. What I find interesting about his is they had to INSTALL those bushings and weld them in place to make that lousy design work. So for a total of $38 and my friends milling machine to cut the bushings and welds out of the way I can modify what I have to the new design.
Here are some pictures of what I saw today.
If you look closely you will see the "spacer" that we with backhoe's don't need. Also "LS mt125owner" could you measure and give us the length of your new pin so I don't have to cut and fit? In my opinion for $38 and a little work I can have the completely new redesigned hitch.
Gotta love our LS tractors.
Lisa
View attachment 553785View attachment 553786View attachment 553787View attachment 553788View attachment 553789
Lisa
Yes, it's a pretty neat set up when installed. Takes me under 2 minutes to tack off the whole assembly. Your idea is absolutely correct... Get the "pins", drill out the sleeves, and cut the shaft...your good to go. I went out and measured the shaft. It is exactly 13 1/2" long.:D
/ LS mt125 3 point "update" #26
Please put some pictures on of what you are doing.
/ LS mt125 3 point "update" #27
For me the point of updating my three point hitch is to update my tractor to the latest and greatest idea's. I do not have any three point implements except a receiver hitch that I want to make a "heavy hitch" out of for the counter weight. But I love do the modifications and upgrades as that is part of the fun for me of owning this machine.
Just one persons thoughts on the question.
Lisa
/ LS mt125 3 point "update" #28
Mr. "LSmt125owner", I appologize I didn't not thank you sooner for going out to your tractor and pulling the bar and measuring it for me. That was very nice of you to provide that information so fast. Monday I will order the "pins" and when they come I'll do the full modification and of course publish pictures of the finish product. Thanks for your help, thanks for driving your dealer to get the parts for you and thanks for sharing all the information with the rest of us.
Best regards,
Lisa
/ LS mt125 3 point "update" #29
Hmm, after reading this thread, I still think my design works much better.
/ LS mt125 3 point "update" #30
And your design is.............................?
Post some pictures please.
/ LS mt125 3 point "update" #32
Ah yes............ I remember! Please forgive the "old lady brain". I was actively working on building your system but where I live and the local metal supply I could not get the proper dimensional steel to do the job. Thus I abondoned the idea. But I had everything on my bench ready to build it. Great idea and you did it. Yes indeed you improved on the "lazy design".
As I mentioned in a previous post, I ordered the pins, will cut the shaft when they get here and mill off the bushings LS went to so much trouble to make their lazy design work.
/ LS mt125 3 point "update" #33
DOM Carbon Steel Tube: 1.25" OD x .188" wall x 12" | eBay
/ LS mt125 3 point "update" #34
Well today I finished the upgrade to the new LS factory configuration. This was really easy to do as first I ordered from my local dealer 2 number 40369516 "Pin-Lower Kink"s and together they were $30 total. Not bad for factory parts. Next I removed my backhoe and then the three long bolts on each side and then the three bolts on the actual draw bar assembly on the horizontal brackets. Then I took my grinder and cut the welds that secured the bushing LS installed in the side brackets. I painted these brackets to cover my grinder marks and reinstalled them after pushing out the old bushings with my press. Next I cut the draw bar long pin to 13 1/2" in length. In the last picture of this set I show the two bushings I cut out, the short piece of the draw bar pin that I cut off and then one of the two new "pin-lower link" that I installed left and right. Now to remove or install the three point I remove one bolt that retains one of the "Pin-Lower Link"s and remove this part and the main draw bar pin can be removed without removing a tire. Fabulous upgrade that took a total of one hour, $30 in parts and some black spray paint. Exceptional factory fix to a really poor original design. :):thumbsup:
Hope my pictures help you seee what I did.
Best regards,
Lisa
Awesome job! :drink: And a whole lot cheaper too than buying "the kit". :thumbsup: Not to mention the fun working and fabricating! :D
/ LS mt125 3 point "update" #36
Oh yea. You had a wonderful dealer that helped you and you helped me. I'm down with a $30 mod and as you said I got the fun of fabricating and doing it myself. Awesome and thanks so much for your help too. Also to a great New Holland dealer in my area that will work with me on these things. I got the factory update and I did it myself. :drink:
Best regards my friend,
Lisa
/ LS mt125 3 point "update" #37
Can we get some more information here before I get into trying to order parts?
/ LS mt125 3 point "update" #38
looking at some of Tony's videos for reference. Are you able to remove the pins for the side links and bring arms straight up. maybe use a bungee to hold them up along with the side links?
/ LS mt125 3 point "update" #39
/ LS mt125 3 point "update" #40
looks like it could be possible. You will want to remove the pins from the lower lift arms at the bottom leaving the side links hanging on the upper lift arms. then bringing the lower arms up. However, you might need to remove the PTO shield...
That's what I was just looking at. The turnbuckles hit the PTO shield keeping the arms from fully clearing. Being under a fresh warranty, I'm not sure I want to get into safety features. Thought crossed my mind though to notch the shield for clearance for those turnbuckles.
Question remains, will they interfere with leg room when the seat is turned around?
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2015 International ProStar T/A Day Cab Truck Tractor (A61573)
2015 International...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61572)
2025 BS43 44in...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2004 Ingersoll Rand SS-3 Portable Air Compressor (A61572)
2004 Ingersoll...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A61572)
2023 John Deere...
