rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,689
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I have a couple of big wrecking bars, prybars, to get leverage on opposite sides of the pto coupling, to pull it off the tractor's shaft. After applying penetrant, vibration, etc. (Not heat).
Yikes! Do you have to do that often?
I remember one Yanmar PTO pump I worked on - in fact it was for one of Yanmar's own 3pt backhoes - and it appeared to be stuck fast. Turned out to have a nearly invisible set screw in the collar that connects the PTO shaft to the hyd pump. The collar had rubbed on something at some time and blended the set screw into the collar surface.
