Buying Advice What to do?
/ What to do? #1
hilltop Haven Farm
Huntingdon, Pa
1953 jubilee
Back in the market as the old jubilee went to bed. The rundown, 45 acres, half wooded, half field, ALL acres hillside. Uses would be using 6' bushog, plowing up food plots, skidding logs UPHILL, maintaining logging roads and trails, horse farm, clearing woodline overgrowth, etc. Have previously looked at kioti ck3510 and tym 394. Pretty locked on a hydro or I would just buy the 69 Ford 3000 down the road. Is a ck series or 394 enough? Or is the price jump worth it to go up to a 45 how tractor(nx4510, tym 454, or suggestions)? Budget for tractor and loader is preferably 20k. But could go a little more. Would want tires filled and maybe 3rd function to run a grapple at some point. Bring it on. Thanks
/ What to do? #2
If you're like the majority of us... go with the 45! You can never have too much power when it comes to working those ponies! The difference in price is worth it!
/ What to do? #3
After you opt for a Loader and loaded tires you will have a pretty fair load to motivate up hills, BEFORE mounting an implement.
For a six foot Rotary Cutter on hills you need a minimum of 45-horsepower.
Consider a PTO operated logging winch for pulling trees up hill, rather than skidding them uphill.
VIDEO: tractor logging winch - YouTube
Safe hillside operation demands more tractor weight than level land operation. Tractors optimized for hill work have liquid installed in the rear tires, rather than air. Loaded tires are filled to 75% capacity with liquid, which increases tractor weight low down ~~500 pounds to 700 pounds~~ for two loaded rear tires. Heavier rear tires lower the tractor's center-of-gravity, making the tractor more stable and increasing rollover resistance.
Safe hillside operation requires four wheel drive (4-WD). Tractors have brakes only on the rear wheels. When going down hill, weight distribution shifts forward, decreasing rear tire grip. With 4-WD engaged tractor feigns four wheel braking. Without 4-WD engaged, on a steep slope, an uncontrolled descent may occur.
Heavier tractors have adjustable rear wheel spreads; wide rear wheel spreads reduce tractor lateral instability.
/ What to do? #4
Almost identical to my setup/needs. Ford 8n didn't give up on me though - I have up on it. Slipped out of gear and ran down my hills one too many times!
I looked at lots of manufacturers and ended up with a Branson 3725 hst. Ran a spreadsheet with all the specs and Branson was the clear winner for me. I put at tires on it and spread the rest wheels. I didn't fill the tires.
Used the loader all weekend with 5' bush hog for ballast. Will probably make a ballet drum for maneuverability at some point. No problem carrying quite heavy loads uphill.
Bush hogging was so much faster and less stress than with the 8n.
/ What to do? #5
Since you're in the east, check out the new RK (Rural King) tractors. Built by TYM with Yanmar engines. Probabaly the most bang for the buck tractors out there now along with Branson, LS, and TYM.
/ What to do?
So I have a kioti and tym dealer nearby. Both would be great after the sale I feel. The nx4510 came in at 26,300 and the tym 454 25k. Both hst, fel, loaded tires.
/ What to do? #8
I just went thru this process and decided on NX > CK SE mostly due to loader upgrade. I skipped the DK series with preliminary pricing for the new HST model and "sometime in July probably" availability. For not an incredible amount of $ more, the NX just seemed to give a whole lot more than a DK.
Depends on if you want all the NX features. Some I do, some I don't think I really care. But overall, just really felt like a lot more compared to the amount of additional $.
/ What to do? #9
Also, just for reference, this is the deal I got for NX4510 HST:
$27,700
NX4510HST w/ KL6010 loader
Hydraulic top link
Ind tires
Filled rears
2 weld-on grab hooks front bucket
Delivery (15 min away)
6' Bush Hog brand rotary cutter
6' Bush Hog brand box blade
If you want to take a trip south and haul it home, I can give you my dealer's info. If the price you got was a cash price, yours sounds a little high? I think for mine the difference between cash price and 0% Kioti financed price was around $4k...so figure that in. My price also w/o state sales tax.
/ What to do?
Yes was cash price without sales tax. That's a pretty good deal you got. Could use a box blade but already have 2 cutters
/ What to do?
As I'm trying to decide what to get, I got offered a ck3510 with fel and filled tires for $15500. It's a 2016 leftover. I know I need(want) a bigger tractor but that's a tough one to pass up.
/ What to do? #13
HST and SE?
And the price you got on the new DK HST was a lot better than what I got as preliminary price quote. The # I got made NX a no-brainer compared to it.
/ What to do? #14
Dang, thats a good price. New 3510s are 18k here in MI.
/ What to do?
HST and SE?
HST. Talked to dealer today and can't get me one till mid June. Need something now. Trying to get a better price on the nx. Even though the best deal is the leftover ck, I feel I would regret not going heavier.
/ What to do? #16
My guy said late June would be the very first DK HST shipping, more availability in July, and good supply/availability in Aug. I wasn't in huge rush for replacement, but didn't want to wait until Aug either. I would bet you'd have to go to a bigger volume dealer like Larry Stoves Equipment or similar to get one of the first available ones.
My NX finally got delivered today. I'm not super tech savvy but will get a few videos of it on youtube from me tinkering with it today.
That price you got for the CK would make it a real tough call for me. IF you don't need all that loader capacity, I would guess you will still get everything done on the CK. I'm sure at times you might wish you had just a little more and think "I should have got the bigger one!"....but that's a huge cost saving as well so might be worth it. I went back and forth with the price difference between CK3510SE and NX a LOT trying to decide. Kept coming back to "I can rent a backhoe a LOT of times with that price difference and still come out ahead". Do that for the big projects, day-to-day stuff with the CK. But ultimately I just move so much dirt and IBC totes with water, I really figured it was worth the cost for the bigger machine since I would be working around the CK limitations too often. So really depends on what you need the machine to do.
/ What to do? #17
For the work you describing the CK is a bit to light.
Uphill skidding?
yeah because in real life you'll be busy; maybe cut a big tree down (like larger then 6-8 inches dia.) and the weight will challenge the CK.
Also the NX45 is wider and heavier so it will chug ah lug just fine. The linked pedal a plus and will operate a 6' foot medium duty cutter fine.
The CK technically can handle a 6 footer but not the medium duty, it will make the front end pretty light; per my dealer. so got a 5 footer when I bought the CK4010HST.
It's a pain cutting with a wider tractor but I can live with it...for now heh
......look honey yard looks bad...i think i need a larger cutter.....heh...well maybe not she is catching on...:D
Regards,...
/ What to do?
Skidding uphill isn't a main focus. I also have a log arch that will hook to drawbar. This allows to totally lift log off ground and pull as if were on wheels. Makes skidding much easier. Main jobs would be running a 6' brush hog, road maintenance, and clearing trails and overgrowth.
X (A68191)
X (A68191)
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A66738)
2019 Mercedes-Benz...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2013 Chevrolet Impala Sedan (A66738)
2013 Chevrolet...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2016 JAY FLIGHT BY JAYCO BUMPER PULL CAMPER (A67714)
2016 JAY FLIGHT BY...
