HOW MUCH WEIGHT
/ HOW MUCH WEIGHT #1
coupman35
Gold Member
Northen Ontario
Now a L4060 had B2650
Am looking to add some weight in the back of my b2650, just not sure how much will I add. What you info on this am sure some of you did this .300-400 hundred pounds. Let me no thanks
/ HOW MUCH WEIGHT #2
Depends what your wanting to do.
I used mine tonight with fluid filled oversized R4 tires and a tiller on the back.
And I was able to still pick up the back tires while curling the bucket.
/ HOW MUCH WEIGHT #3
How about a 5 foot box blade @ about 500#?
Doesn't stick out too far and has other uses.
I always have mine on for most loader work.
Good Luck!
/ HOW MUCH WEIGHT #4
I did extensive research on this when I built my ballast box. I kept adding weight till the machine stayed planted doing max loader work. I ended up with 750 lbs to keep it planted well even on uneven ground. Not saying you cant get away with a little less for lighter work. But that is what it takes to keep it planted nicely and be safe doing whatever.
/ HOW MUCH WEIGHT #5
I have a Titan ballast box filled with surplus gym weights, fire bricks and sand. It hangs about 3" further back off the tractor as I have a Pat's on the arms. I'm not sure how much it weighs, probably 400# to 500#. It's not enough for serious loader work. Rkidd's 750# sounds about right w/ weighted tires.
/ HOW MUCH WEIGHT
Am going to move sand and mud whit it .Am going to get a blade but not yet.
/ HOW MUCH WEIGHT #7
If you are going to move mud and sand you better get some serious weight. All that is super heavy!!!
/ HOW MUCH WEIGHT #8
Was the 750 lbs on a ballast box or did you have something attached further back on the 3pt?
/ HOW MUCH WEIGHT #9
I have about #750 of permanent counter weight, not counting any attachments.
Note in the photo it would have been too dangerous to carry the stump any distance so I transferred it to a larger tractor.
/ HOW MUCH WEIGHT #10
View attachment 554198View attachment 554199
+1. I have a 5 foot blade on my BX2680. It needs more for full loads of dirt.
/ HOW MUCH WEIGHT #12
I have 1550# of Rimguard in my rear tires and a Rhino 950 rear blade at 1050# on the three point. I can lift 2850# - I've carefully lifted 3100# but the grapple left drag marks in the dirt - I kept that load(large chunk of my Ponderosa pine) lower than a snakes belly. I have internet data that allowed me to develop two weight charts - one for large rocks and the other for large chunks of Ponderosa pine. Basically those are the only two items I lift that will approach the max capacity of the tractor. By simple measurement and reference to either weight chart - I've got a fairly accurate estimate of what the load will be.
/ HOW MUCH WEIGHT #13
Rkidd, what sort of ballast box do you have? I'm asking because I know I'm going to be getting a b2650 and in the planning stages for items I'll need to go along with it...thanks.
/ HOW MUCH WEIGHT #14
My ballast box is home made. I welded up the frame and bought 10 pieces of rail road track that weigh a 100 lbs apiece at a good price and added the pieces till I had enough weight. That was the thing I found that any kind of hanging or stacking weight is a dollar a pound. Ouch. I found my weight for considerably cheaper.
/ HOW MUCH WEIGHT #15
Thanks for the reply. I'll have to go the dollar a pound route as I haven't learned to weld yet.. it's on my bucket list though.
/ HOW MUCH WEIGHT #16
Just curious. Are you saying you lifted 3100# plus the grapple or total was 3100# including the grapple? How much does your grapple weigh. Thanks.
/ HOW MUCH WEIGHT #17
wbuffetjr1 - My grapple - Land Pride SGC1560 is listed as weighing 820 pounds. From my lifting chart tables out of my front loader operators manual - I can lift 4300 pounds at a distance 12 inches forward of the FEL pivot pins. BTW - 12 inches forward of the FEL pivot pins is the physical center of the grapple.
So....... subtract 820 pounds from 4300 pounds equals 3480 pounds. I say 3100 pounds - just to be on the safe side.
I can vouch for the fact that a pine log weighing 2850# will NEVER get more than 6" off the ground if I'm operating the tractor. I moved a chunk that big last summer and it was not a lot of fun.
So - Yes - my lifting charts say I can lift the grapple @ 820# plus at least 3100#. Its never going to happen - I don't have the cojones plus, around here, there is never the need to go that heavy. That's why I have a log and rock weight chart - helps me stay out of trouble.
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A62129)
CATERPILLAR 631E...
2018 International HX620 Quint Dump (A62613)
2018 International...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A62130)
2008 GMC C7500...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
