Flail Mower Ford 917 Flail mower
/ Ford 917 Flail mower #1
TheFarmerInAdell
Gold Member
Adell, WI
Massey Ferguson 2706E, Massey Ferguson GC1705
First post, but cruised the forum for a while for information on flails.
I just picked up a 5 foot Ford 917. It wasn't a screaming hot deal, but it was local (as in it was stored in a shed I rent out on my property...) and a decent price. It is missing the rear roller. Messick's has it, but it's almost $300 plus shipping. A local machine shop that I have connections with is willing to make it (for free!), but I need some measurements. I know the bearing it goes into is 35mm so that takes care of the shaft ends. I need the roller diameter and length between the bearings, and perhaps a good picture of the ends of the roller.
It also needs some blades. It has scoop blades on it, but a bout a half dozen are missing and another half dozen are damaged. With having to replace half of them I figured I probably should replace all of them. Should I go side slicer or back to the scoops? It is on a Yanmar 424 (24 HP, 18 PTO) and I will mostly be cutting/maintaining trails around the property with it along with mowing my ditches. I don't plan on cutting down brush with it, but I would like to not lose knives when I hit a stick in the path. I will also be reclaiming a field after my CRP runs out (probably just a pass or 2 around the perimeter, then burn it), but will maintain it after. What do you recommend?
I did play with it a bit (I couldn't resist!) and it cuts. Not well, missing those knives, but it runs and cuts. I did bottom out a few times missing the roller and all. No major vibrations. I didn't dig out all the grease fittings yet, but that is next on my list before I do any more mowing.
I'm sure it will be requested, so here are pictures.
/ Ford 917 Flail mower #2
I like my 917, with the same blades you have. It's the 74" version, so I can only help with the roller dia.
Yours looks in great shape.
Both New Holland and Flailmaster have the blades and belts.
I'm curious how your tractor handles it.
/ Ford 917 Flail mower #3
I want to welcome you as the newest member of the "Flail Mower Nations",
B4 your machine shop builds this rear roller out of tubular steel for you, you have be sure that the end stubs welded to the rear rollers end weldments are not too long as you will be unable to install it other wise. chances are the rear roller bearings are toast as well since rear roller failures are generally caused by rear roller bearing failures so keep that in mind before you wander any further.
If you can spend the money on the replacement identical parts including the rear roller bearings you will be much better off as the new rear roller bearings will be matched properly to the new rear roller.
Just replace all the scoop knives buy some new hanger straps, D rings, nuts, bolts, washers, and new V belts for spare parts and leave it at that for now as you will need to buy a complete set of knife hanger straps, D rings and nuts and bolts to equip it with side slicers as you will need many of them to equip properly for finish and brush mowing.
/ Ford 917 Flail mower #4
I had two 917s and still have one 6 foot fine cut. I thought the stones around here would trash the "slicers" but that has not been the case and I prefer them over the scoop which the stones totally destroy. I once bought a special sharpener at auction for those scoop knives. I never used it as I only once removed all the blades for sharpening and that was enough for me.
Make sure the end of the roller is rounded otherwise it will tear open the turf when turning. I'm not even sure how I would make those rounded ends.
I haven't mowed anything real heavy with it, just some overgrown yard grass. That it handled just fine. It did struggle when I tried to mow the dirt, however... Other than that I think it will work well for what I need it for.
No worries about the stubs being too long. I'm a mechanical design engineer and I'm familiar with how to design that stuff. I will need 2 new bearings as there are none on the mower right now. In fact, one of the bearing housings is missing as well. That I can get from Messick's for $50. The bearing size is called out on Messick's website and I have connections to get them for half of the cost through a distributor we use at work so acquiring the correct bearings isn't a problem either.
I thought the side slicers used the same hangers as the scoops? And I thought I was able to just replace with the same number of stations regardless of which blades I was using. At least that's what I had gathered from the Flailmaster website. Perhaps I thought wrong.
Is there a power requirement difference between the two blades? I know the heavy scoop blades cut brush better, but do they use more HP?
/ Ford 917 Flail mower #7
If I recall, there are maybe three times as many hangers for the fine cut knives. I think all of the holes of the flanges get used for the fine knives.
Magic! :thumbsup:
Those rounded edges are a breeze with CNC lathes. They are a bit more time consuming with the manual lathe, as you need to do it in increments. I actually have a book with the increments needed for different radii. It takes a while when you need to make a 1" radius going on .005" increments...
I was going to stick with rough cut blades. According to Flailmaster I can use the same rough cut blades as the Alamo/Mott mowers on my ford with the factory hangers. At least that's what the picture shows me.
/ Ford 917 Flail mower #10
I pulled the flail mower file. Invoices going way back, sales brochures and an owners manual.
They show Standard, Fine, Coarse and Thatching blades
For 62" model
Thatching & Regular 27
Coarse 54
Fine 162
I see they speak about weight stacks to compensate for different blades. One mower had regular and one had fine, so I never had to worry about that, nor did I know about that.
/ Ford 917 Flail mower #11
Alamo/Mott built those mowers for Ford
/ Ford 917 Flail mower #12
......................................Make sure the end of the roller is rounded otherwise it will tear open the turf when turning. I'm not even sure how I would make those rounded ends.
My first thought would be to use concentric weld reducers on the ends of a piece of pipe. It shouldn't be too hard to adapt the ends as needed for bearings. Search for "weldbend concentric reducers".
Those weldbend reducers are nice. That might be a helpful piece of the puzzle. If not for this project (probably will be done on a lathe), there will be one that I can use them for.
Anyone able to get me the diameter of the roller? I will attempt to measure the length needed, but I will need a diameter to start with.
/ Ford 917 Flail mower #14
I tried to measure mine in between the rain storms.
It’s between 5 and 6 inches.
If it’s not raining tomorrow I’ll try to get it raised up and get a better measurement.
/ Ford 917 Flail mower #15
I got the battery replaced in my tractor today, so I my 917 off the ground and the roller measurement is 5.5”.
Thanks! That's bigger than I thought it would be. Good thing I waited.
/ Ford 917 Flail mower #17
I’m still searching to realize if my b2150 can run a 6’6 Ford 917. 24 hp 18 pto. Pasture cutting, Johnson and Blue Stem are the toughest I usually run over. I’m hoping to join the Flail Mower Nation
/ Ford 917 Flail mower #18
KMoJo, I think you would be short on power and possibly lift height too with a B2150 and a 6'6" Ford 917.
/ Ford 917 Flail mower #19
It will handle it, an old 8N ford can and it is rated at 24 hp, if in really heavy stuff you might need to take a half width cut but other than that if it can pick it up it will cut with it.
/ Ford 917 Flail mower #20
I ended up getting a 60” 918L. The B2150 hst, with 18ho pto advertised, is handling it well. So now I want to try the 60” 918H, run the slightly heavier blades. There also is an extra pivot in the hanger/blades compared to the 918L
2019 Dodge Grand Caravan Van (A61569)
2019 Dodge Grand...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
2007 Volvo VNM T/A Day Cab Truck Tractor (A61568)
2007 Volvo VNM T/A...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 International HX620 Quint Dump (A62613)
2018 International...
