7 pin connector
/ 7 pin connector #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I'm so tired of messing with trailer lights. Does anyone know of a 7 pin connector that is rock solid? I'd be willing to pay up if I never have to mess with it again.
/ 7 pin connector #2
Hahaha. I feel your pain. What issues are you having? I use shrink crimp connectors and shrink tubing on all connectors. My issues have been greatly reduced after replacing nearly all the cords on my trailers and any and all scotch locks I come across
Brett
/ 7 pin connector #3
I just went through that with my 2002 F350.
When I bought the truck in 2012 I didn't know the previous owner had rewired the plug. I had numeroaus problems until I tor it apart and found he had relied on RTV to hold the wires together. Fixed that and it worked for years, until 2 weeks ago. With a new tester light (Amazon.com: CURT 5827 7-Way RV Blade Connector Tester: Automotive) everything showed good, but the running lights didn't work. So we started testing all the trailer lights looking for a short. Finally our son found that there was virtually no power on the pin and the tester was bad.
Somewhere in the wiring harness it shorted. Bypassed that and all worked fine.
/ 7 pin connector #4
I put trailer wiring in PVC conduit/junction boxes and solder all connections. Running conduit right up to the brake backing plates takes some doing! Generally speaking, the plugs don't give too much trouble. Storing them when not in use is the biggest challenge.
/ 7 pin connector
Brett
I was pulling a 14,000# load. I was going down the steepest decline within 100 miles and my truck said "Trailer Disconnected". My first thought was "Why the F right now" Luckily my truck has an exhaust brake so I was able to maintain 25 miles an hour until I got to the bottom. I pulled over at a gas station and wiggled the connector around and it started working again. I searched on internet and found a connector that the wires are molded onto it instead of screwed onto the end. I think I'll replace the connector with one of these.
I've started soldering every connection as well.
18 wheeler trailers have to have a more reliable system than the POS on lighter duty trailers.
/ 7 pin connector #6
My problem on infrequently used trailer connections is usually the 7 ( or 3) brass connector pins/holes. I can usually wire brush the pins but it would be nice to have a little brush that would fit inside the holes. Kinda equivalent to a battery cable terminal cleaner.
/ 7 pin connector #7
Google "teminal connector cleaner" its a wire brush for inside the connections.
/ 7 pin connector #8
As I am prepping my big trailer for trip in a few days, I get to revisit my connections. Conduit is a good idea, as
are soldered connections. I have no good solution to storing my 7-pin plug as the trailer lives outside. This
trailer has electric brakes, so the connections have to be good to pass the high current needed.
My other trailer has no brakes, but I did convert it to LED lights. That is also something that can help as the
lights take much less current.
/ 7 pin connector #9
:thumbsup:
That and multiple grounding points around the trailer if your rewiring.
The biggest problem with the 7 pin flat RV type is not the connectors but the trailer side of things, usually the ground. The truck (factory) side has given me little trouble on both Ford & GM's. Die electric grease is your friend also!:thumbsup:
/ 7 pin connector #10
Actually I am quite impressed with those junky flat style (and single) connectors. I have never had issues with the actual connection prongs and sockets.
I do think some of my wiring jobs were worth more than the trailer itself. One I still borrow (that used to be mine) is rotted to death but the lights all work perfectly!
/ 7 pin connector #12
Put a covered socket on both ends and use a coiled cable. Little more up front, but I like it better.
7-way Coiled Cable | AW Direct
/ 7 pin connector #14
Next time you're at WalMart, go to sporting goods and get a .17 caliber bore brush.
/ 7 pin connector #15
/ 7 pin connector #16
The 7 pin round with round connectors is a better plug than the 7 pin round rv style plug. Keeping everything cleaned off and good electrical connections is really all it takes though.
/ 7 pin connector #17
I've used the molded plugs, they can still separate inside the plug. I just use the regular screw type connectors, keep a wiring diagram in the truck. An idea to "store" the unhooked end is to mount an old female end under the tongue and just plug it in. Keeps it out of the dirt, fill it with di-electric grease and you've solved a couple of problems
/ 7 pin connector #18
I spray a light coat of Fluid Film on all my plugs. It really makes connections easier/smoother and reduces oxidation and corrosion.
/ 7 pin connector #19
Thanks to the members who pointed out that these brushes are available. Teachu2's .17 caliber bore brush recommedation will be cheap and easy to try.
/ 7 pin connector
Thanks for the ideas. I just ordered the brush off Amazon
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2022 EZ-GO ELITE...
John Deere 720 Quick Attach Loader (A65640)
John Deere 720...
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
