Rustoleum implement paint mix ratio?
   / Rustoleum implement paint mix ratio? #1
davedj1
Jackson, NY
Kubota L2501
I picked up a quart of Rustoleum implement paint today and some paint thinner. The can has no directions on it.
I saw a youtube video where the guy did five parts paint, two parts acetone and .33 part hardener.
I have never heard of using acetone for a thinner.
What say you all?
Thanks
   / Rustoleum implement paint mix ratio? #4
Never used hardener.
Rustoleum is formulated differently than most paints (acetone thinner, etc.). Hardener might or might not work. I would definitely do a small test first.
A web search might find something about Rustoleum hardener.
Bruce
   / Rustoleum implement paint mix ratio? #5
I checked - "Rustoleum hardeners" and there are several recommended. The hardener type depends upon the Rustoleum being used.
   / Rustoleum implement paint mix ratio? #6
I thin Rustoleum with acetone all the time and have for 15 years. You need to thin more than you think. I spray a light coat outside on a warm day and then a few minutes later a slightly heavier coat. Works fine. I never use hardener because of the risks of lung damage. Lots of threads on that.
   / Rustoleum implement paint mix ratio? #7
My experience is that Rustoleum works pretty well without a hardener, but be careful for the first month or so. It gets really hard and durable but cures very slowly.
   / Rustoleum implement paint mix ratio? #8
Prefect timing on this thread. I have a 15 year old rotary cutter that is mechanically sound but could use a paint job. Thanks!
   / Rustoleum implement paint mix ratio? #9
Can't say enough good about Rustoleum paints, I've used them for around 30 years. I thin with mineral spirits not quite half and half for great results.
The stuff takes a long time to dry but the longevity is excellent. You'll notice once cured the paint is impervious to gas and oil also.
Best of luck, Fred
Well I sprayed the top today. Overall it went OK. I thinned it according to their website to about 15% and then I added about a third of an ounce of hardener. I made 10 oz of paint at a time. It's not a real glossy finish, I couldn't seem to get a wet look. I don't know if it was today's weather or what.
I sprayed my winch with the Magic paint a month or so back and had no trouble getting that glossy.
Maybe the acetone? and the weather?
It almost looks like a matte finish.
1997 Caterpillar 950F Articulated Wheel Loader (A55973)
1997 Caterpillar...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
