JD Rotary Tiller - Jack Stand Bent/Issue
/ JD Rotary Tiller - Jack Stand Bent/Issue #1
rmonio
New Market, MN
JD 4600, JD B
My JD665 Rotary Tiller’s rear Jack stand got bent last evening when I went to put it away. :( Not the stand portion, but the plate that attaches to the tiller.
The plate must be soft metal, unfortunately. Does JD make a replacement attachment for this or should I attempt to bend it back myself? Just curious... Thanks!
-Bob
/ JD Rotary Tiller - Jack Stand Bent/Issue #2
A pic or three will help us answer your question..
/ JD Rotary Tiller - Jack Stand Bent/Issue #3
sounds like you want #38? Part# LVU14908 About $90 online
/ JD Rotary Tiller - Jack Stand Bent/Issue #4
JOHN DEERE BRACKET PART # LVU1498 | eBay
I see that part available unpainted on Ebay apparently as an aftermarket part. I guessing that there is a high demand for the part as I know, from experience, it is easy to forget to raise the support leg or tongue jack on any piece of equipment.
/ JD Rotary Tiller - Jack Stand Bent/Issue #5
I've got a 655 and it has two of those stands, front and back, on the same side. Both are unpainted (that includes the bracket).
/ JD Rotary Tiller - Jack Stand Bent/Issue #6
Bend it back and go about your day.
Thanks team. I did end up ordering the bracket - it was reasonable - and replaced it. I tried bending the other one back but was not successful. A new one was only $35 from the dealer.
I知 sorry, but I did not see your responses come to me via email - so I didn稚 get back here sooner.
Thanks again for all of your help!
-Bob
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
DEUTZ MARATHON...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
2020 Kubota B2301 (A60462)
2020 Kubota B2301...
John Deere 24'' Backhoe Bucket (A60463)
John Deere 24''...
