JD Rotary Tiller - Jack Stand Bent/Issue
   / JD Rotary Tiller - Jack Stand Bent/Issue #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
My JD665 Rotary Tiller’s rear Jack stand got bent last evening when I went to put it away. :( Not the stand portion, but the plate that attaches to the tiller.
The plate must be soft metal, unfortunately. Does JD make a replacement attachment for this or should I attempt to bend it back myself? Just curious... Thanks!
-Bob
   / JD Rotary Tiller - Jack Stand Bent/Issue #2
A pic or three will help us answer your question..
   / JD Rotary Tiller - Jack Stand Bent/Issue #3
sounds like you want #38? Part# LVU14908 About $90 online
   / JD Rotary Tiller - Jack Stand Bent/Issue #4
JOHN DEERE BRACKET PART # LVU1498 | eBay
I see that part available unpainted on Ebay apparently as an aftermarket part. I guessing that there is a high demand for the part as I know, from experience, it is easy to forget to raise the support leg or tongue jack on any piece of equipment.
   / JD Rotary Tiller - Jack Stand Bent/Issue #5
I've got a 655 and it has two of those stands, front and back, on the same side. Both are unpainted (that includes the bracket).
   / JD Rotary Tiller - Jack Stand Bent/Issue #6
Bend it back and go about your day.
Thanks team. I did end up ordering the bracket - it was reasonable - and replaced it. I tried bending the other one back but was not successful. A new one was only $35 from the dealer.
I知 sorry, but I did not see your responses come to me via email - so I didn稚 get back here sooner.
Thanks again for all of your help!
-Bob
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2018 GENIE GS-1930...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
78'' root grapple (A53421)
78'' root grapple...
Skipper B Boat Trailer (A53117)
Skipper B Boat...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
