mopardude318
WOW. I just read this thread from start to finish. You have some awesome skills, great talent! Very nice work you've done here.
I've had to put the tractor restoration aside for the past couple of months due to some more pressing jobs, this week I finally got back to doing some more stuff on the tractor so thought I'd resurrect this thread.
The instrument cluster was in a sad state
I found a clip on youtube
Instrument Panel Renovation - YouTube
where the guy reconditions the same cluster, got in touch with the very nice chap from Missouri and he sent me a copy of the photoshopped repaired fascia he has created. I did essentially the same process Jim shows in his video, plus repairing the broken needle. Before reassembling the cluster I tested the voltage stabiliser and it was shot, I replaced it with a DC to DC converter from eBay, by pure chance the eBay component mounted to the same holes on the cluster casting that the original bimetal stabiliser was screwed to.
I used a modern silicon sealant to seal the two halves of the casing rather than the strip of cellophane tape originally used. I also made up a sachet of silica gel by emptying a teabag and refilling it with silica cat litter, glued it into a void inside the cluster to absorb moisture out of the assembly and hopefully avoid condensation.
The cluster came up pretty well with the photoshopped fascia, repaired needle and fresh enamel on the surround.
I've got the tractor back in the shed to continue the 'freshen up' that has turned into almost a complete restoration. Fitted up the reconditioned instrument cluster, here it is insitu- I decided to zero the hour meter, given the fact that it had not been working for an unknown period, the numbers displayed were meaningless. At least now it will reflect a known starting point.
Made a start on stripping and painting the wheels, one rear wheel done so far. Wore out one wire cup wheel on the angle grinder cleaning this up.
View attachment 552787 View attachment 552788
That wheel centre casting is incredibly heavy, I had water ballast in the tyres but I suspect it may not be necessary with those wheel centres.
View attachment 552789 View attachment 552790
A bit of contrast was in order for the retainers
The end result is certainly an improvement. Who needs mag wheels.
I should get the other rear wheel done this week, then both the front rims.
