Ballast box question-size/weight?
/ Ballast box question-size/weight? #1
rockingclawhammer
South Texas
Case 485, MF 265, Kabota 26hp
I need to build a ballast box and I have found many ideas to work off of here searching the forum. I want to be in the 1500lb range and it seems I should have paid more attention in math class. How do you figure the volume/weight/size need when using the plywood form and concrete method? The redneck in me says buy 19 bags of concrete and stack them up in the shape I want and go from there.
/ Ballast box question-size/weight? #2
To give you an idea and starting point of what it takes and your own calculations:
Just last month I poured a concrete ballast block. The inside dimensions of the box was 2'x 2'x 2' = 8 cubic feet. I used (12) 80# bags of Quikrete.
12 x 80 = 960# of Quikrete + the steel for the 3Pt hitch and the 2" receiver for a ball hitch I incorporated in the block, I estimate total of around a 1000#.
/ Ballast box question-size/weight? #3
Concrete weighs about 150 pounds per cubic foot so you’d need 10 cubic feet to weigh 1500 pounds. Figuring the volume of a rectangle is pretty straight forward.
/ Ballast box question-size/weight? #4
It can, but it depends upon the concrete mix (ratio of cement, sand and aggregate).
/ Ballast box question-size/weight? #5
That’s what google says. It’s probably close enough for the intended use.
/ Ballast box question-size/weight? #6
Don't mean to hijack the thread but anyone know how many bags of 80lb concrete fill a 55 barrel?
/ Ballast box question-size/weight? #7
Using the 150 pound number it’s going to take 13.75 bags.
/ Ballast box question-size/weight? #8
So does google say that is the weight of wet or cured concrete? I do not believe a 30# per cubic foot difference is close enough to be overlooked.
My real life experience, not armchair research on a computer, resulted being the dry 4000# PSI concrete mix to equal 120# per cubic foot. ;)
2013 Mack CXU613 T/A Day Cab Truck Tractor (A61573)
2013 Mack CXU613...
Shamrock 8ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 8ft. S/A...
2007 30ft. Regal 30 Express Cruiser Boat with T/A Trailer (A61574)
2007 30ft. Regal...
(2) Lights (A64119)
(2) Lights (A64119)
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
