Rounded off drain plug
/ Rounded off drain plug #261
To the original poster, I'd suggest if/when you take the tractor to the welder to get the plug removed, ask them if they can drill/burn a hole in the support so in the future you can get a socket on it.
/ Rounded off drain plug #262
Might have to do some bracing of the sides on the support if its got a hole drilled in it but thats a neat idea while the equipment is out and running at the weld shop.
/ Rounded off drain plug #263
Or simply use a hex headed pipe plug.
I feel for the OP.
He has to fix his truck
So he can fix his tractor wheel
So he can fix his tire
So he can drive his tractor to the welder
So he can remove his drain plug.
I've had days like this.
There's a Hole in the Bucket
Indeed. Waiting on stuff to ship. While the tires are off, I figured i may as well add to the project and look at doing the brakes. Simply can't be happy with one thing. New rim is on the way.
/ Rounded off drain plug #265
I think we have the makings of a reality show.
Flip My Tractor....on the Reno-Garage Show.:thumbsup:
Share royalties with the few thousand members and we all retire rich ......!!!:D:laughing:
Well it could happen...;)
/ Rounded off drain plug #266
I saw a construction reality show a few years back and the homeowner shot a nail into his hand. They showed it. Cut to commercial and he's right back at it with a bandage the size of a salami. It was so painful to watch I flipped the channel. :)
/ Rounded off drain plug #268
/ Rounded off drain plug #269
Like a pipe wrench?
Hum..mm..... One would have thought that someone MIGHT have suggested the pipe wrench idea, in at least one of the previous 269 posts !!!
/ Rounded off drain plug #270
They did. I’ve read most of those 269 posts
/ Rounded off drain plug #272
I admire the patients of Kando. It has been over a month now and that plug is still in there. That would drive me insane! At this point I would roll the tractor on it's back and drain the fluid out of the fill hole. Assuming I could get the cap off.
/ Rounded off drain plug #273
I would have done something by now... most likely which would have caused me even more problems.
/ Rounded off drain plug #274
/ Rounded off drain plug #277
I have a feeling this will be one of those threads that will live forever, even if the OP gets it fixed. It has a life of its own now.
/ Rounded off drain plug #279
Kando is a DOCTOR?
Well, if he's a doc as in MD that would explain everything and we need to cut him a whole lot more slack. Not because of the MD but because he's wired different and doesn't go through the same process we do in solving problems. He's never been here and done that but just needs some experience and before long will be doing the same things we are. Where I had planned on dropping this thread, I now sense a new degree of interest that will keep me riveted. This thread will go on a very long time because, if he's an MD will need OJT and life experience to solve the obvious.
If he's not an MD, I got nothin'.
/ Rounded off drain plug #280
We probably should cut Kando some slack. We all have things that seem to never get done. With me there is nothing more permanent than something I did temporary just to get by. As the old saying goes.
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
3ft. 5-Point Metal Star (A61574)
3ft. 5-Point Metal...
2020 Colombo CTA 6500 (A64119)
2020 Colombo CTA...
