Reversing front rims?
/ Reversing front rims? #1
lennyzx11
Bennington Vermont
Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
I know. My manual says NOT to reverse the front rims.
But in theory only if I was moving and wanted to put the L3301 on a Penske trailer with rails that measured 42" minimum and my fronts measured 37" maximum, sure seems like a good way to gain the needed 5"!
The trailer is rated at 4050 lbs capacity so this is the only hurdle I'm looking at. I'm going to take the L3301 HST with FEL and filled tires down to the scales this week to weigh it but armchair figuring puts it's weight as lower than that.
/ Reversing front rims? #2
If you're just doing it for a move, and you aren't doing it while working and moving heavy loads with a bucket you should be just fine to reverse the front rims.
Aaron Z
/ Reversing front rims? #4
Aaron Z
This is the way I would do it as well. You can lift the front with the bucket to do the swap easily.
/ Reversing front rims? #5
You can lift the front with your loader, but use jack stands under the axle. 1 for safety, and 2 for stabilizing the front end. Otherwise it will flop around while you work.
Joe
/ Reversing front rims? #7
Doesn't the bucket stabilize it?
Raising the tractor with the FEL stabilizes the tractor but not the front axle that will still rock back and forth on the center pivot pin. This may or may not be a big problem for you when moving the tires. The axle is never quite balanced and will flip back and forth as you work on it. When you remove the first tire, the axle is going to swing till it hits the stops. Hopefully your FEL has raised the wheels high enough so that you can still remove and swap the tires.
/ Reversing front rims? #8
These are all good tips. As BubbaJr pointed out you can stabilize it with jack stands if you feel intimidated by it.
UNDER NO CONDITIONS work UNDER a piece of equipment supported by a hydraulic cylinder. Raise it only high enough to get the tires off the ground and place no part of your body under anything connected to the tractor. And lock the bucket control.
When I am working with another person who is doing anything around a hydraulically actuated item, my hands are in the air so the other person knows: 1) That I see him and 2) That I have no intention of moving a a lever or valve.
/ Reversing front rims? #9
Reminds me of an old safety video... Three-Finger Joe... lol
Do as repeat says... don't go under the machine with it only on the bucket.
/ Reversing front rims? #10
The tapered face on the wheel bolt holes is a critical part of the design. They play a large part in centering the wheel on the hub.
However you do the reversal, consider using washers and putting the nuts on backwards so their tapered face is not distorted.
If you don't do this, you are often plagued with wheel nuts which wont stay tight.
Dave M7040
/ Reversing front rims? #11
Very good point! Never thought of that.
On another note, I already had a scare earlier this year when my lugnuts on my truck came loose even though I tightened them to spec.
Go to find out the tapering on them was distorted because of wear and tear. They got over 200k and probably have been taken off and put back on over 100x and beat to well... crap.
After that happened, I ordered up a new set for all 4 corners. Don't need to have my wheels flying off doing 65 on the interstate...
So yes, that is another good suggestion!
/ Reversing front rims? #12
Dave M7040
It also changes the loading on the front wheel bearings and support structure. Standing in front of the tractor while the wheels are in the narrow position, look at how the wheel is centered over the two wheel bearing as well as how it sits in relation to the "down turn portion" of the axle and pivot points. In the "narrow" position I bet you will see it more centered under this structure. In the wide position you will notice it puts more pressure on the outer wheel bearing as well as no longer being aligned under the pivoting portion.
I tried mine in the wide position for a while. My checkbook objected loudly but I guess on the positive side, I did make some friends at the Kubota parts counter.
Generac QT02724 Anax Generator (A61572)
Generac QT02724...
2022 EZ-GO ELITE...
2008 Volkswagen Eos Convertible (A61574)
2008 Volkswagen...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
