Choosing my first tractor
/ Choosing my first tractor #1
Kirby72
Cle Elum, WA
None
Newbie here, so sorry in advance for the newbie questions....
I recently moved to my little paradise in the foothills of the mountains in Eastern Washington. We bought a house on 6.5 hilly, and mostly forested, acres. My pipe dream would be to someday buy the adjoining forested property so that my total domain would be about 35 acres (although, this may never happen ). I am looking for my first tractor and would love some help sorting through all of the choices. Purpose for said tractor:
-Snow removal on my 200 yard long driveway and the large parking area in front of the house and (future) shop. Ability to occasionally remove snow on community driveway (additional 600 yards) when the neighbor can’t do it. Both driveway sections have some hills. Google says we get about 50 inches of snow per year, but the winter of 2016-2017 was 2 or 3 times that!!
-work on the same gravel driveway(s) when it is not snowing: grading, occasional gravel work.
-logging. Removing/thinning trees on hilly property for fire wise purposes and keeping the forest healthy. Turning the logs into firewood.
-Thinning/removing brush in the forest, particularly near our home (for fire control)
-general hauling and loader work
-landscaping. (Adding/spreading dirt/topsoil to our lawn). I will mow with our riding lawnmower.
Other considerations: I am leaning towards a cab model as It will make life more pleasant for snow removal chores. Storage of tractor will either be in my existing garage (8 ft tall door) or in my future shop with gigantic doors.
Any help or advice would be appreciated...
/ Choosing my first tractor #2
Brush over about 2" diameter will be too much for the implements that can run on a 35hp tractor. They make small PTO forestry mulchers that can do 4" or more but they require a larger tractor with more hp. And those mulchers are not cheap. We have brush ranging from 2" to 6" or more. I cut them with a chain saw, chip what I can with an 8" pto chipper and pile the rest to rot. Burning is not allowed in my county. I've cleared quite a bit around the house in the last year and a half. It's not fast like a forestry mulcher but it's kind of relaxing.
/ Choosing my first tractor #3
Dealing with snow will determine the minimum weight tractor you need. If you get enough tractor for handling snow on your hilly property you will have enough tractor weight and horsepower for the other tasks you designated.
I recommend a tractor of 3,500 pounds to 4,500 pounds bare tractor weight.
Kubota is the only tractor line I am knowledgable about so I have to start there. The Kubota tractors available with cabs in this weight range are the Kubota Grand Ls, also known as the /60 series after model suffix. (Neither the Kubota standard Ls nor the MX series are available with cabs.)
I own and operate the lightest Grand L, an L3560; 3,500 pounds bare tractor, 37-horsepower. A particularly nice, compact size for 6-1/2 acres.
There are five heavier, more powerful Grand L models built on a single chassis/frame: all 4,000 - 4,400 pounds, bare tractor weight. L4060/L4760 have naturally aspirated engines. L5060/L5460 and L6060 have the same engine with addition of a turbo-charger. (Turbo, additional cooling capacity and wheels/tires account for weight spread.)
What is your altitude? Tractors lose about 3% of engine horsepower for every 1,000 foot increment of altitude, over 500'. So if you are at 5,000' you lose around 15% of sea level engine power with naturally aspirated engines. In addition, the cab weights 500 to 600 pounds and it takes power to move cab weight up hills. Turbochargers force air into the engine, eliminating altitude power loss.
So, for snow moving the naturally aspirated L3560/Cab may have just barely sufficient power for your needs or be OUT.
The L4060 is probably OUT, leaving the L4760 naturally aspirated tractor and turbocharged L5060/L5460/L6060 as potential choices.
None of these cab models will enter a 96" garage door.
VIDEOS: Kubota Grand L6 Series walk around and feature review by Messick's - YouTube
5 Most Common: Compact Tractor Attachments - YouTube
Kubota Grand L66 Auto-hitch and attachments (walk around and demo) - YouTube
Hillside Stability - What Is Safe? - TMT - YouTube
KUBOTA WEB SITE:
https://www.kubotausa.com/docs/default-source/brochure-sheets/l60.pdf?sfvrsn=bad1e991_6
/ Choosing my first tractor #4
Kubota does offer lighter, cabbed tractors.
VIDEO: How to clear snow using your loader - Kubota B265
Cab Compact Tractor - YouTube
*NEW* Land Pride Snow Pushboxes for BX, B & L Series Kubota Compact Tractors - YouTube
B3350, may be enough for your non-snow tasks. B2650 with cab will not have sufficient horsepower for hills.
Open station models are 88.4" tall. Cab models MAY be several inches taller.
B3350: 1,896 pounds, bare tractor, 2,447 pounds with cab.
KUBOTA WEB SITE: https://www.kubotausa.com/products/tractors/compact/b50
/ Choosing my first tractor #7
Don't need weight to push snow if you're willing to put chains on. I had a Gravely with a big snow plow here the first 3 years. It pushed snow well with chains on the tires.
For your case, a rear snow blower and front FEL would work well. A friend of mine in Winchester has had an old Kubota with this combo for many years, on a long gravel driveway. I've an FEL and rear blade, but have had need for a snow blower a couple of years here in central Va.
Ralph
/ Choosing my first tractor #8
I went with the Massey Ferguson 1749. The 1700 series is a newer line that MF put out a coulple years ago. I looked at the normal brands before picking the MF. You can buy a cheaper tractor but you'll be hard pressed to find one that "fits" any better than the MF. All the controls are placed in spots that are easy to get to. For most controls I don't have to take my elbows off the arm rests. Means a lot if you pull long hours on a tractor.
/ Choosing my first tractor #9
IMO this is the prime driver for you. In Eastern Washington the logs can easily be 4' diameter or more. Where you are I am thinking 2' +. Find tractor weight, FEL capacity, and counter weight set up then figure in hills that you may have negotiate. Once you get to that capacity I think snow will be covered. Even if it is the wet and heavy kind although I think you tend to get dry and lighter most of the time.
Once you get that ball parked then you might consider closest dealer(s). There are several brands I would consider but they do not have competent dealers in my area.
/ Choosing my first tractor #10
Thinning for fire safety and forest health usually involves removing brush and small tree and leaving the mature trees. You'd want to remove mature trees next to buildings of course, and you have to handle them when they fall down. I had a couple 5' madrones fall this winter. An 8' section of lower trunk was too large for the grapple on my Branson. As it was going to firewood anyhow I sectioned it into rounds where it lay, quartered those and then used the tractor to move them. I don't think I could have picked up that section of trunk with my tractor's loader anyhow.
An important use of my tractor for fire safety is running a pto chipper. Even if there wasn't too much red tape to make burning practical I'd want a chipper anyhow as it can be run any time of the year and can be used under trees. If you want to chip larger material you'll need power. I have an 8" chipper and when chipping 6" or larger I have to slow the chipper feed to a crawl or stop the feed alltogether to let the tractor get the chipper flywheel back up to speed. Having more than 37hp would be useful for that task.
/ Choosing my first tractor #11
We don't have a lot of snow on our island in Wales so it wasn’t really an issue when I bought my Case IH 248. However, I do a bit of logging, a little landscaping and a lot of field mowing. I had originally thought of getting a 4 wheel drive compact tractor but even second hand prices were way out of my budget and attachments were not any better. Instead I got the two wheel drive 1995 Case and a brand new topper mower and stayed within my budget. I also figured that conventional (old) attachments would be cheaper. The tractor had a FEL already fitted and a cab. Interestingly enough, you mentioned a cab for comfort, but yesterday I discovered a new reason that I was grateful for it; one of the hydraulic hoses on the FEL burst and sprayed oil all over the cab windscreen. If it wasn't for the cab I would have had a face full of hot oil and who knows what damage that might have caused to eyes, skin etc.!! So, whatever you get, include a cab for your own protection! Good luck in your search.
Thanks for your replies so far. You guys have me thinking about bigger (heavier) tractors than I was originally looking at (Kubota B2650/B3350). I am now looking at 3 tractors with hp in the mid 30’s and weight of the bare tractor of 3000 lbs plus.
The 3 Cab tractors I am currently researching are:
Kubota L3560
Mahindra 2638
Yanmar YT235C
Any opinions on these 3 tractors? Brand reliability, other issues?
/ Choosing my first tractor #13
/ Choosing my first tractor #14
Don't forget about Kioti.
I would look at the frame size that I have....The NX series replaced the DKSE series that I have (same frame size as mine}, the NX has all the tier 4 final emmisions.
Mine is mechanical injected with a muffler, starting 2014 anything over 26hp has the emissions goodies.
The new DKs are not the same as mine.
They are now building 40/45 horse tractors on the 30/35 horse fame size
Again current Kioti new, in my frame size, would be the NX series.
Good luck:)
Yes, cab over here, yes lot of snow 16/17 winter, get the cab:)
I like my tractor :thumbsup:
/ Choosing my first tractor #15
Of the three models listed which is available from a tractor dealer? In my area there are three tractor dealers selling three well known brands. There are also outlet stores and lawn mower repair places that have added a tractor line to their retail options. Some items are up to 60 HP so they are not small tractors. IMO that does not make them a tractor place. Building a BBQ for display does not make you a tractor mechanic. That is important to me. If something goes wrong I would prefer it to be repaired by someone trained to do so with access to the necessary information. The local lawn mower guy may be a great mechanic for a CUT but I am not willing to make that assumption with my investment. I buy cars from car people, houses from realtors, and go to a doctor when I need to. For me the same applies to tractors. If you are going to fix everything yourself then it may not matter other than parts availability. As many have mentioned here, find the dealer then the product. Oh, and get the "domestic easement" first.
/ Choosing my first tractor #16
I also go back and forth between the L3560 and the YT235. Both are Japanese high-quality, high-feature tractors. Both Kubota and Yanmar have been in business for over 100 years, and both companies build the entire tractor from the ground up.
The L3560 is significantly heavier, longer, and taller than the YT235, and it has a more advanced transmission. It is also more expensive. Both have auto throttle. You need to decide if it's important to you to fit the tractor in the garage and figure out if they'll fit.
Both the Kubota and Yanmar have a mid PTO and will accept a front snowblower. Both tractor cabs have heat and A/C.
I'm hedging towards the YT235 because I'd have to chop the ROPS on the L3560 to fit it in my garage (7ft door) and I don't know that I need the weight for my purposes. Your purposes will differ and you'll need to decide if you need the weight and lift capacity of the L3560.
I'm not knowledgeable about the Mahindra.
As far as dealers go, the Mahindra dealer is an easy 25 miles away, the Kubota and Yanmar dealers are both about 60 miles away and over a mountain pass.
Mahindra 2638 cab has the MCRD technology, which makes the emissions requirements easier to deal with. But, the control layout leaves something to be desired from an ergonomics standpoint. The air ride seat will not go back far enough to make me very comfortable, I am too close to the pedals and steering wheel. There is something wrong with the design, as I am only 5’8” tall! The 3 point controls are right next to my right hip requiring me to raise the arm rest and lean to the side to see it. These types of things are annoying. The Mahindra dealer is the closest of the 3, and the salesman tells me that they will pick up the tractor for free for warranty work, etc. My impression is that they are trying to build their business and reputation as a relatively new dealer.
I have not been to the Yanmar dealer yet to see their tractors first hand. No Yanmar dealers within 200 miles have the exact model that I am most interested in.
Kubota seems to be better ergonomically, probably has a better reputation for quality and reliability, has good parts availability, but is more expensive than the other two.
Kubota website says the L3560 cab model is 90.6 inches tall, my garage is 96 inches tall.
/ Choosing my first tractor #19
Tractor dimensions are quoted with R1/ag tires as a convention.
If you order R4/Industrial tires the tractor will be less tall.
Thanks. I definately want R4's anyway
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
SCHEDULE 80 PIPING ON PALLET (A68842)
SCHEDULE 80 PIPING...
2025 Rake Mini Excavator Attachment (A66734)
2025 Rake Mini...
Hydro-Ax 721E Articulating Heavy Duty Forestry Tractor (A66734)
Hydro-Ax 721E...
2014 TEXAS PRIDE GOOSENECK TRAILER (A67714)
2014 TEXAS PRIDE...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
