Oil & Fuel BX23 fuel tankwill only fill with 3.5 gallons
   / BX23 fuel tankwill only fill with 3.5 gallons #1
fierbyrd
Ran out of diesel in my BX23, had just filled it up the day before. Used most of the day but it runs quite a while on a tank. Thought it might be a filter, disconnected the line into the bottom filter and no diesel. Inserted a long piece of stiff wire into tank and it came out wet. Filled up tank and it only took 3.5 gallons more or less. Any ideas?
   / BX23 fuel tankwill only fill with 3.5 gallons #3
Sounds like the crossover vent hose is plugged. Tip tractor over on to left side and fill.
David
   / BX23 fuel tankwill only fill with 3.5 gallons #4
I'm not 100% sure of the differences or sameness of my BX2200 with your BX23. I have experience with a BX2230 and another BX2200 besides mine. I never did get more than about 3.5 gal of fuel into mine when it appeared empty. Partly because if I fill it totally full it will leak.
These machines all HAD a known defect where the tanks leaked if they were totally filled. Not sure when or if that defect was corrected, recalled or fixed. I am not up on exactly the final answer as to the cause. Some say it was a vent that was poorly located, a poor reverse flow vent protection, etc. Regardless I just know not to completely fill it in the sense of being to the top of the filler. I do fill it to where the gauge reads very close to full.
The tank is a contorted odd shaped thing to begin with and I never dug into it. I know of dealers who have pulled the tanks off (to try to cure a "shuts down when hot" issue) and hints that "the older ones had a leaking issue." Way too much sheet metal and nuisance job to remove and investigate for me.
Anyway, my point is that 3.5 gal usually fills mine when near empty and there is reason in my case at least not to fill it completely to the filler opening.
   / BX23 fuel tankwill only fill with 3.5 gallons #5
If you look at the parts breakdown, there is a vent line going from engine to left side of tank and one going from left side to right side, a large amount of capacity is in the rleft side above the low point under the seat and can become airlocked. Parking the tractor on a slope with the right side higher usually will allow the tank to take more fuel.
David
   / BX23 fuel tankwill only fill with 3.5 gallons #6
David
Hey David, that is great info. Do you know how this plays in to the leaking problem people have had over the years ?
   / BX23 fuel tankwill only fill with 3.5 gallons #7
I know some of the models had a leak in the gasket of fuel sending unit.
The BX has a main tank and then below it there is a second fuel tank that has a couple of vents to main and the fuel return from the engine and is also fed from the main tank. I am guessing that this is so that if you are on a hill the fuel will not slosh around and allow air to get sucked in by the lift pump. With all the vents and fuel lines there are quite a few places where you can get a leak.
I have already replaced sections of fuel line by the engine when I upgraded the fuel filter and use the Gates Barricade fuel line and it resists the Bio Diesel pretty good.
David
   / BX23 fuel tankwill only fill with 3.5 gallons #8
Early 22/23s either leaked fuel around the sending unit, or the tank got a crack in it up high. Problem seemed to occur when tanks were nearly full. At least, that's my recollection.
My BX2200 will hold nearly 5 gallons when tank is about empty.
Ron
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
CAT Chassis Only (A59076)
CAT Chassis Only...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
