Which woodchipper for strictly evergreen diet?
   / Which woodchipper for strictly evergreen diet? #11
IT - Oh, boy - dead & dry pine versus live & green pine. The live/green stuff will give up its pitch like squeezing water out of a soaked shop towel. And if its a hot day - everything is hot - the little pine, the chipper, the chute, the sticky pitch - - ME. For all the mentioned reasons - I will start my operations before sunrise - around 5AM - and quit around 10 to 10:30AM.
By 10AM I'm beat to death and ready for my mid-morning nap. That's a solid five hours of identifying and cutting OR dragging and piling OR chipping.
A question - a chipper that can handle a 12" tree must have some form of winch to pull a tree that size into the chipper ?? With a 12" tree - you can grunt til the cows come home and it will not move an inch.
   / Which woodchipper for strictly evergreen diet? #12
I'm working on it. I thought I had the cat by the tail, until I tried finding stuff to feed the chipper that was accessible. A winch is too slow and a hydraulic one, pricey (and slow).
The chipper blew off the hat off my lady friend (and helper) and a nice chunk nailed her in the head. So, her enthusiasm for helping me chip has been diminished somewhat. Women always want to jump ahead three steps. She wanted to spread the chips that were being blown onto a muddy section of trail, not understanding the danger.
Definitely not a one man job! Probably, I should divide the operation. Stock pile material for chipping, and chipping. The problem with that is that I hate moving anything more often then necessary, and I would probably find myself moving the piles again.
   / Which woodchipper for strictly evergreen diet? #13
. . . There just may not be a chipper or shredder that can handle a lot of green spruce branches without plugging. . . I would also collect and keep close at hand - dead, ultra dry branches. . . .
I would imagine that you would have no problems with most any chipper if you could pile the cut material and wait a year to chip it.
I second most of oosik's comments although I have some differences with his MO (more on that later).
I have experience with only two PTO chippers, a 4" Wally (borrowed) and a 6" Salsco (now owned). I had a lot of problems with small, resilient twigs (evergreen or deciduous) jamming the chute of the Wally, but only once the same problem with the Salsco. The differences? The chute on the Wally tapered or narrowed from side to side while the chute of the Salsco was a constant width. The Wally was older so "fluff" or other debris may have restricted the air inlet ports; the friend from whom I borrowed it ran the Wally at 1000 rpm with no reported problems. It may be that a 6" chipper just has more airflow and a bigger discharge chute.
The 6" Salsco behaves well with the 32 PTO HP I have. The tractor bogs down at about 5' into a 6" eastern white pine, so my method of operation is to cut the 30' pine into 5 sections and carry or drag each 6' x 6" log to the hopper while the motor recovers. The fourth section may have dead branches that are the source of the "dead, ultra dry" material that helps clear the chute after I feed the 5th piece, the crown, with the (live) limbs still attached.
My recommendation would be to go with a 6" machine. You have the HP, the airflow will probably be greater, and the larger inlet is an advantage with crooks and forks. (The 4" x 10" on the Wally was a plus.) It may or may not be overkill for 4" limbs, but oversized is better than undersized. Also be aware of the physical size; the height of my PTO caused a 30 degree shaft angle with the 4" Wally.
   / Which woodchipper for strictly evergreen diet? #14
Ah - I see. Well - my M6040 with 62 hp eats 6" x 30' Ponderosa pine faster than a kid can gobble a candy cane. The standard 6" x 30' P pine will go thru the BX62S in about eight to ten seconds. Not quite enough time for me to grab another and drag it to the chipper.
I've tried cutting the bigger pines into chunks. I don't like doing it that way. It means I've got to make multiple trips to the stacking pile. Chipping it whole means there is usually three feet or more at the base of the tree with no limbs. This allows the chipper to get a good hold on the tree before it starts to get to the limbs. Chop it into chunks and that advantage is no longer there. My Wally does not have hydraulic in-feed. The way I chip the small pines - I've never needed it.
   / Which woodchipper for strictly evergreen diet? #15
Different strokes for different folks. There's more than one way to skin a cat or chip a pine tree (or chip a spruce bough). Oosik has more power in his tractor and more strength in his body than I. We have each found a method that works well for our own circumstances.
   / Which woodchipper for strictly evergreen diet? #16
Sounds like you need some kind of dumping trailer to blow chips into.
Aaron Z
   / Which woodchipper for strictly evergreen diet? #17
Captain Dirty - Thank God we DO each have our own way. BTW - MY WAY this spring - get my son out of his house, off his azz and out helping the old man. He has always found time to come and collect the chips - by golly - he can help make them. Besides - his pickup is 4WD - so he can get right out where the chipping is happening and we blew the chips right into his pickup.
If anybody ever does that - blow chips right into the pickup - may I suggest a sheet of plywood or the like standing up to protect the rear window of the pickup. Rear windows with sliding glass openings are especially $$$$$.
   / Which woodchipper for strictly evergreen diet? #18
Oosik--I suspect you and I agree on more matters than we differ--Captain Dirty
Aaron Z
When my son took a couple of loads of chips we covered his PU from hood to lowered tailgate with a tarp (thereby protecting his rear window). After loading he ."covered his load" by taking the tarp edge on the hood back to the tailgate. At his house he tied off the top corners of the tarp at the rear to 2 trees and drove away rolling the load of chips onto the ground.
Disclaimer: Considerations of the density/weight of the chips, strength of the tarp and ropes, and speed of driving away are the responsibility of the practitioner.
   / Which woodchipper for strictly evergreen diet? #19
Good disclaimer - funny. Good way to "do" the chips also. The chips my BX62S produces are a WHOLE LOT bigger than what the BX42S produced. The chips are about 1/3 the size of a normal playing card and all of 1/4 inch thick. And I've got the anvil adjusted down as tight to the knives as I dare.
   / Which woodchipper for strictly evergreen diet? #20
I have a dump trailer that I intend to put some more sheet metal on, to use for chips. I just don't have a spare tractor of the right size to pull it. And, I wouldn't even think about having my P/U anywhere near the operation. I was using my backhoe, with a hitch on the pallet forks, but that's awkward.
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2004 CATERPILLAR 320C L EXCAVATOR (A60429)
2004 CATERPILLAR...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2017 Genie GTH-5519 (A53317)
2017 Genie...
