John Deere 5205 aux hydraulic problem
/ John Deere 5205 aux hydraulic problem #1
Firefighter912
GA
JD 5205 MWFD
I have a root grapple on my 5205. The grapple was working, but when i went to go pick up some limbs and drop them, the grapple wouldnt open.
The hydraulics lines are all hooked up and not knocked loose.
I can push down on the aux lever and it wont even go in the float.
I pull back and it wont go back like it is suppose to.
I dont know if the valve body is messed up or if there is trash in it.
All my other hydraulic parts work.
/ John Deere 5205 aux hydraulic problem #2
Sounds as if detent mechanism is not operating correctly. Try applying some penetrating oil to the detent area accessed by removing valve cover(key 1).
/ John Deere 5205 aux hydraulic problem #3
Could you post some pictures so it is easier to understand your grapple system.
It is not going to be a "trash in valve" problem.
How is the grapple powered? By sharing the bucket cylinders using an electric selector valve?
From a rear remote outlet?
Which brand of Grapple and model? Who installed it?
Dave M7040
