Cab tractors and Loader Removal
   / Cab tractors and Loader Removal #11
I had my L3200 (no cab) for 3 years & the new canned L4060hstc for a year & a half. Both allegedly had/have the quick attach loaders that come off or on in a couple minutes. I say allegedly because I never felt the need to remove either. I'd dump the SSQA bucket or other impliment, but never got motivated enough to remove the loaders.
   / Cab tractors and Loader Removal #12
There's not a lot of clearance between the loader mounts and the cab. Tractors "back out" as the loader dismounts, but when remounting, one has to be pretty careful the loader masts don't hit the cab.
As you wrote, practice does make perfect, but one does want to use caution
Yeah, that could be a problem. The way my Kubota hooks you couldn't have that problem. If you drive in too far it will simply push the loader along in front of you. Not familiar with your setup.
   / Cab tractors and Loader Removal #13
Read the directions that came with it. Secret is keep your hydraulics hooked up till you are clear of the thing and hook them up before you contact it. You need hydraulics to move your bucket forcing the implement off your tractor mounting pads when coming off with it and the converse when loading it back on.
If your hydraulic connections aren't color coded for matching, get some nylon tie wrap and code the lines. I use 1 for the first one, 2 of them for the second and etc. Be sure and do the male and female sides. Shoot some WD 40 or a penetrating oil like PB blaster on the connections before you attempt to break them loose and clean up the fittings before mating back together when reinstalling......I know you new that but it never hurts to say it anyway.
   / Cab tractors and Loader Removal #14
The biggest hurdle just dawned on me. He can't stand at the right side of his tractor and reach the joystick to move the FEL into position to reconnect.
When I remove/install my FEL I stand by the joystick with the tractor running and operate the joystick to get the FEL to release itself from the tractor and to position itself back into the tractor framework to reconnect.
This will complicate the operation dramatically. Not saying it can't be done. Just saying it gets complicated.
Actually, I can operate the loader joystick from the right side...not a problem
I didn't understand the distinction about "cab" tractors versus "open station" tractors?
Actually, the hard part is ensuring the tractor is in line with the loader frame and the masts seat on the frame brackets without hitting the cab. A Curtis cab has two windows low so I can see how the operation is going. It's easier with an open station to ensure everything is aligned and, obviously, there's no cab to dent. Even with an open station, as bigtiller wrote in post #7, "a spud bar comes in handy occasionally."
Main thing, go slow and keep an eye on everything.
I reckon I'll find out how difficult it is when the weather finally warms up here (25 degrees in Bethel as I type this)
   / Cab tractors and Loader Removal #16
Roy, oddly enough I was thinking this same thing yesterday and removed my FEL this morning. Not familiar with the Curtis cab but removing the FEL and reinstalling it on my Kubota was really easy. I almost didn't do it today because I didn't have any directions. Glad I did. One less thing to worry/wonder about.
   / Cab tractors and Loader Removal #17
actually with mine being HST, i can stand outside with door open and control tractor movement and joystick while standing on ground on side of tractor. i can inch tractor along. also as described earlier, the tractors push cage would move loader forward before loader contacts the glass.
   / Cab tractors and Loader Removal #18
The design of my JD 440 loader must be different than what you guys are describing. Hooking it up is easy. Just drive up to it fairly close, get off to hook up the hydraulics, get back on use the joystick to seat the brackets. They have notches big enough to guide everything into alignment. The only hard part is if the loader has shifted and put pressure on the hydraulics. Parking it on a slab fixes most of that.
   / Cab tractors and Loader Removal #19
Safety Police will get me, but, I stand by the tractor with it running and adjust the joystick until my FEL is seated. :)
2013 CATERPILLAR 316EL EXCAVATOR (A52709)
2013 CATERPILLAR...
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
Okada OKB 304B Hydraluic Breaker (A55973)
Okada OKB 304B...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
