Homemade box scraper. Push me or pull me?
/ Homemade box scraper. Push me or pull me? #1
CreativeGuy
Newport, Oregon
PowerTrac PT-425
Greetings,
I am in the process of modifying the box scraper I built for my old mini dozer to attach to the hitch frame I made for my PT 425. I welded on a long 2 receiver tube. I intend to weld connector plates to pin on the sides for extra support and additional support up to the top link connector on the hitch frame. But first, I gave it a tryout. It worked really well pulling gravel on our driveway but driving backwards is less than ideal. I know the box blade from PT is also meant to be used in reverse.
I was wondering if anyone has tried to modify a box blade to push forward on their tractors? It seems like it would be much easier to control. I also thought that I could weld a longer 2 tube so that I could hook it up in either the forward or backward direction. I was also wondering if there would be an advantage in either direction regarding traction. I wasn稚 able to apply much downward force on the scraper without the wheels spinning.
What is the consensus on either wheel weights or filling the tires with some sort of fluid. Also, would it be ok to add weight to just the rear wheels? I am not sure if that would adversely affect the hydraulic drive.
Thank you for your thoughts.
/ Homemade box scraper. Push me or pull me? #2
I'd pull it backwards. Why? Because if you ever want to float it, you won't be able to if you push it while in float. It will bite in, and the tractor will want to drive up over the FEL arms almost immediately.
/ Homemade box scraper. Push me or pull me? #3
/ Homemade box scraper. Push me or pull me? #4
On a side note, have we seen your mini-dozer in another thread? I've seen so many things on TBN that I can no longer recall who has shown whom what! :laughing:
/ Homemade box scraper. Push me or pull me? #6
Guage wheels on a box blade don't really help with our geometry. Bobcat is just a bit lower on its pivot points, so the push is easier to attain.
I have been mulling a "3 point hitch" idea on my machine, something to pull my box blade and landscape plane.
One thing on the box blade... if you put the connector plate higher up, so the arms are sticking straight out, you might have a chance but honestly pulling is the way to go.
Hi,
I had (I begrudgingly sold it), a Magnatrac 4800. “Dozy” An amazing workhorse which I used for much of the excavation work on our earth sheltered home. But he was really slow and I needed something that that was quicker for maintaining our driveway. I miss him though.
/ Homemade box scraper. Push me or pull me? #8
The PT geometry really does not like to push against the ground. I have used a rear blade both ways and in reverse works much better. I also believe it would be easier to mess up the loader arms by going forward - steel strength in tension etc
Ken
Pulling it is!. Thanks everyone for your responses. The great thing is I now wont have to undo the welding that I already did.
Cheers.
/ Homemade box scraper. Push me or pull me? #10
I am thinking of buying a northern tool box blade
https://www.northerntool.com/shop/tools/product_200660623_200660623
If i welded a hitch tube to it and attached to hitch receiver welded to an attachment plate. Would that be enough to support it and drag when it's shipping weight is listed at 390 pounds? My gut says it would need some lateral support of some kind. I would only use it in reverse. Does anyone have any experience with the power trac box blade? It looks like it weighs about half what this one weighs.
/ Homemade box scraper. Push me or pull me? #11
Why not use two tubes several feet apart? More stability and strength.
Bruce
/ Homemade box scraper. Push me or pull me? #12
If I were going to be modifying a 3pt implement, like a box blade, I'd look for a used one at a farm equipment dealer, or local sales, first, before buying a new one and hacking on it. An implement like a box blade is usually pretty heavy steel, and not easily damaged. Used, it will most likely be good as new, just minus a pretty paint job.
/ Homemade box scraper. Push me or pull me? #13
I would think you would be better off welding some rectangular tube or C-channel with brackets across the 3 pt braces (parallel to the box blade) and then weld an attachment plate to that. I almost always buy this type of stuff used as Moss said. In this case though, it might be hard to find one that small.
Ken
/ Homemade box scraper. Push me or pull me? #14
If you get one for $100 you could narrow it yourself, too, if you have the equipment.
/ Homemade box scraper. Push me or pull me? #15
The wider they are, the thicker the metal so you have to worry about weight given the leverage of the blade. He is getting close to the limit but should be ok doing what you say if it is only a 5' or possibly 6' blade. I doubt I would want to try a 7 or 8' blade.
Ken
/ Homemade box scraper. Push me or pull me? #16
I owned a 6' box blade for my old IH2500b. It was HEAVY... there's no way my PT425 could have pulled it with even a small amount of bite in the soil. No way at all. So I'm guessing from experience that even a 5' would be difficult. If I ever were to get a box blade for the PT425, it would be 4' maximum width, with removable scarifier teeth. Just my opinion, of course. ;)
/ Homemade box scraper. Push me or pull me? #17
Sorry, I meant with regards to taking a larger one and cutting it down. I think the thickness of metal on an 8' box blade would make an 8' cut down to 4' be too heavy for the PT425.
Ken
The box scraper I built from scratch is 54" wide. I wanted something a little more than 48" but not as wide as 5 feet. It's not nearly as heavy as a commercial unit but that is an advantage pulling it with my 425. I attach it to my 425 using the 3point hitch that I welded to a spare quick attach plate. I still need to weld some pin holders on my scraper to make it a little more firmly attached.
/ Homemade box scraper. Push me or pull me? #20
GRRRrrr! Looks tough!
That's pretty good! How well does it work?
