So what would you have done different with your new shop?
   / So what would you have done different with your new shop? #111
So I am continuing to pencil designs, lets talk lighting.
I am in a 45X45 shop, 18 to the eaves. I was thinking of 6 200watt LED Warehouse lights. I am a big believer in that you never have too much light but working with LED lights of this size (20K lumens I beleive) I am unsure if I am headed for happiness or depression. Not cheap, basically 1K to just put lights in this one area....
Don't forget you can put in spotlights to illuminate corners, workstations, etc... to augment your standard lighting.
   / So what would you have done different with your new shop? #112
In my uncles shop he ran 8ft fixtures along the walls to help fill in for the high bay lights. Worked pretty well for seeing under hoods.
   / So what would you have done different with your new shop? #113
Lighting seems simple but is very complex. The only way to properly measure it is foot candles at your work plane. The light output in lumens from a fixture doesn’t all make it to where you want. The positioning, style, specs of your fixture and the reflectivity of your walls, floor, and ceiling all come into to play. There is computer software that can model it.
For a quick and dirty estimation unless your lights are mounted extremely high 100 lumens or more per square foot in a typical shop should give you good light. You can see and work with much less but if you want it bright and don’t want to constantly be needing a drop light or area lights where you are working then aim for 100 lumens plus per square foot. I have 125 per square foot and it is great. Almost like being outside.
Be careful getting fixtures that are too bright. Mine are 100 watt and 13k lumen. If you look directly at them it sort of blinds you. I wouldn’t want any brighter with my ceiling height. You don’t want to go to far in the other extreme but generally speaking the more lights the better as it distributes the light more evenly. I have 24 of the 13k lumen lights. I am happy with it but I bet 48 6.5k lumen lights would give me better lighting as it would be distributed better and wouldn’t blind me as bad when I looked up.
Obviously you have to find a balance in the middle but definitely don’t go throw one or two ultra high lumen lights in a shop and think it will be good. I have approximately one light per 100 sq feet and it is good.
   / So what would you have done different with your new shop? #114
Yep, don't discount spot lighting on specific work areas. I bought a couple of these versatile LED portable lights and they are great to put on tools where you need some precision lighting. Magnetic so you can easily move and position exactly how you want and plenty bright! Here, lighting up my knife sharpener and grinder.
   / So what would you have done different with your new shop? #115
I might just go with 100W 6500k lights such as: GLORIOUS-LITE LED Flood Light, 1W(5W Halogen Equiv), IP66 Waterproof Outdoor Work Lights, 65K Daylight White, 8lm, 11V, Outdoor Floodlight for Garage, Garden, Lawn and Yard - - Amazon.com
We got some of those in at work and two of them light up a big room better than the two previous 400w Metal Halide fixtures did...
I have 4 similar lights, but 50w each and when mounted in the rafters (12' up) on a 10'x12' grid they light up the pole barn very well.
Aaron Z
Aaron Z
   / So what would you have done different with your new shop? #116
I bought some brand new Continental 5/8" water hose for the barn. The rats ate through the hose in a few weeks time. They did not have a hankering for the vinyl hose we had been using the past 15 year. They also ate through the plastic wheelbarrow. I suppose I will need to replace our 30 year old wheelbarrows sometime in the next few years.
All the wiring in the barn is in EMT conduit except the feed from the house which is in grey plastic conduit. While my mind does not do bends well with add 5 inches, subtract 5 inches, I still like running conduit. I have added circuits to existing 1/2 EMT. 3/4 inch EMT would have been handy in some places.
If you run water pipes under the slab, run insulation around it. Nothing more annoying than water pipe that is earth bonded so it take time to warm up the earth before you get hot water. Also that insulation maybe a little fudge factor that allows the pipe to expand and contract without tearing up.
all my outbuildings are emt...and my house was wires in MC cable and steel flex. im a semi retiring commercial electrician. i personally hate romex. worse invention ever. if you were to see the number of repairs ive had to make over the years to find rat and mouse chewed wires in walls you'd hate it also.
personally im surprised they dont burn down. what is it about mice and other rodents. heck, one ate thru my plastic diesel tank on my tractor.
in my house ive actually have modified some circuits over the 22 years that ive lived here...and love the fact that i could simply snake another wire thru the conduit and not have to open the wall.
all my wires running to outbuildings are in conduit. years after i built the barn, the wife wanted to be able to turn on the lights from the house to be able to check on horses at night, or to light the way to the barn (usually to turn off the lights when she noticed them left on when getting ready for bed). i simply snaked a 3 way circuit thru the 300' of conduit (i ran 2 empty conduits along with the circuit) and now i can control the barn lighting from house.
i also decided on running a WiFi circuit extension out to shop and barn. each building is approx 300 feet from each other. the empty conduits came in handy. i didnt have to redig anything. i now have wifi throughout major section of property.
i run my business off of a iPad that is WiFi controlled. its nice not to have to hotspot my phone to conduct business.
remember, the most expensive part, both in time and equipment cost, is the underground trenching and compaction/landscape part. run extra conduits. think about future changes
   / So what would you have done different with your new shop? #117
A couple other things come to mind in the shop design and creature comforts department.
WiFi has already been mentioned to which I would add a sound system. Classical, hard rock, or EZ listening, weather or sports my radio/sound is the second thing turned on after the lights.
A refrigerator for your soda, beer, and fish bait
A fire proof file cabinet for manuals, records, and the like
A dedicated locker for flammable, paint thinners, and gasoline cans
An alcove for a sit down desk with office supplies as needed
Plenty of heavy duty shelving or pallet racking
B. John
Its a real astute point to mention that these new 200Watt fixtures are brigth to look into. Never really thought of that.
Futureproofing is such a nightmare. This barn is going in next to the house, and so the electricity and plumbing are right there. But in a year or so the new house is going in, at least 500 feet away. And in a different direction than the current power. It is going to take some real thought on all of this to make sure I don't put myself into too deep of a corner.
I found in my neighbors shop that is all metal that his cell phone will not work. Guess that is an issue with metal buildings. We no longer have land lines, not worth the cost, so will have to figure that issue out.
   / So what would you have done different with your new shop? #119
I think you can get repeaters to bring cell signals inside metal buildings.
   / So what would you have done different with your new shop? #120
If you have good signal outside, then a passive antenna/repeater through the wall would probably work fine to give you signal inside.
Forklift (A56857)
Forklift (A56857)
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
Brent 420 Grain Cart (A56438)
Brent 420 Grain...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
