Oil & Fuel whoops - Stable in diesel
/ whoops - Stable in diesel #1
Mudfarmer
Gold Member
Western Washington
JD 3005, Kubota B2710, Kubota B2650 (sold the ford 1700 and kubota B7100)
I inadvertently put a dose of "Stable" (gasoline storage stabilizer) in a five gallon can of Diesel. Will that damage the diesel engine in my tractor if I use it?
/ whoops - Stable in diesel #2
I doubt that tiny amount of Stabil will do anything to hurt (or help) your diesel fuel. If you are concerned, however, simply get another 5 gallons of clean diesel and an empty 5 gallon can - pour half of the clean diesel and half of the Stabil contaminated diesel into the empty can. Then pour the remaining 2.5 gallons of clean into the stabil contaminated diesel and repeat the process one more time and you will have halved the amount of the Stabil in your diesel fuel.
/ whoops - Stable in diesel #3
Should be alright If you have another 5 gal can put half in it then add more fuel to the cans to dilute it .
/ whoops - Stable in diesel #4
You beat me you must type faster:D
/ whoops - Stable in diesel #5
The old Stabil said it was okay for diesel at about half the rate as for gas. Since then, Stabil has a special diesel formula and their gas version no longer carries the rate for treating diesel. Here is an older post on this same subject in TBN.
/ whoops - Stable in diesel #6
I used to put Stabil in diesel that went unused over the winter, before I knew better.
It never caused any problems.
/ whoops - Stable in diesel #8
Yep, Before Stabil started doing specific mixes to target environments, it was for gas or diesel. So your just fine, you just may not be getting any biocide with the gas only formula.
The general product is all similar, it is how they dress it up with unique additives for different environments that changes. Pour it in and go to work. All is going to be A Okay.
/ whoops - Stable in diesel #9
The dose for five gallons is what one ounce? Diesels are pretty resilient unless you are talking about these modern pickups with their fragile fuel pumps. On things like a tractor I doubt one ounce of pretty much anything would hurt much. No I wouldn’t recommend an ounce of water or battery acid but you could put an ounce of oil, gas, transmission fluid, stabil, sea foam, cooking oil, WD-40, hydraulic fluid, whatever and I doubt it would hurt anything.
/ whoops - Stable in diesel #10
I would ask that question to the manufacturer. They will probably tell you the same thing which everybody else already has though.
/ whoops - Stable in diesel #11
Check the ingredients or contact the manufacturer. Alcohol is hard on injectors...
Dutchy
/ whoops - Stable in diesel #12
I put some of the wife's Chanel #5 in the M-F by mistake and had a bunch of guys start hangin' around the tractor. I countered it with some Old Spice. Now a bunch of babes are c....you get the idea.
2009 Dodge Charger (A64194)
2009 Dodge Charger...
Peterbilt 379 with a CAT C13 (A63689)
Peterbilt 379 with...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2022 EZ-GO ELITE...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
