5570 4WD Issue
/ 5570 4WD Issue #1
MsBehave
Small-town, Arkansas
Mahindra 5570, Kubota L3000F
My 5570 isn't shifting into 4WD. All was working fine until it wasn't. I can pull handle no problem there. Linkage all the way to transfer case is moving ok...no problem there. No weird noises, etc. Neither Owner's nor Service Manual are much help. I always shift into/out of 4WD when I'm in neutral and at a complete stop. I did notice a turnbuckle for adjusting linkage, but don't wanna go tweaking stuff unnecessarily.
Any suggestions? I'm buffaloed
/ 5570 4WD Issue #2
Is the shaft going into the transmission turning as well as the linkage? Sometimes a roll pin falls out.
/ 5570 4WD Issue
Shaft is turning. And today when I had someone else check it out, they were able to manually rock the drive shaft and 4wd engaged. However, when in neutral, there was a distinct whine. Went away after a couple shifts on high/low shifter. 4wd also went away. I'm feeling more strongly now the turnbuckle needs to be adjusted allowing for a bit more rotation of the shaft in the side of the xfer case.
/ 5570 4WD Issue #4
Let's hope that's all it is. Otherwise it sounds internal.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
2016 KOMATSU PC138USLC-10 EXCAVATOR (A62129)
2016 KOMATSU...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
