Black as standard loader attachment paint?
/ Black as standard loader attachment paint? #1
c304
Member
Fleetwood
Kubota M59
Maybe I'm being paranoid, but why are grapples, 4-in-1 buckets, forks, etc. standard in black while 3 point attachments come in bright colors?
Seems like for safety reasons you'd want brighter paint.
/ Black as standard loader attachment paint? #2
My 4-1 is orange:)
/ Black as standard loader attachment paint? #3
Black seems to be easier to spot repaint [ semi-gloss black ] and does not show rust much. I used to paint all my stuff Rustoleum Sunrise Red, but now just use the black. Paint your stuff what ever color you want.... Life is short, but it sure is good :)
/ Black as standard loader attachment paint? #4
Plus I think black is cheaper and if you have a green tractor would you want a orange bucket:D
/ Black as standard loader attachment paint? #5
Remember what Henry Ford said, "You can have any color you want, as long as it's black." His reasoning was that adding more colors would add cost to the product. It's cheaper to buy 10,000 gallons of black paint than it is to buy 2000 gallons of red, black, blue, green and white. Also it saves labor and changeover time.
/ Black as standard loader attachment paint? #6
Are you referring to '3rd party' manufacturers? They probably paint their's black to be appealing to as many buyers as possible.
My 4in1 and combo fork/bale-spike are painted JD green (made by an Aussie Co. "Fieldquip").
/ Black as standard loader attachment paint? #8
Some after market manufacture's will custom paint your attachment as you wish, for some extra money. The chipper manufacturers come to mind Woodmaxx says, "Black is the standard color, orange is $200 more".
That's a lot of green for orange:)
/ Black as standard loader attachment paint? #9
Because a ton of SSQA attachments are going on skid steers, not tractors, where they are used for construction by people trying to make money, and some long time ago Bobcat chose black paint for its buckets?
When I had a Deere 5105 with the proprietary Deere QA pin setup on the loader, my original bucket was green, and the aftermarket bale spear I bought to fit it was also Deere green. Nearly all other loaders use SSQA and black is the color that coordinates with all of the loaders, tractors and skid steers they go on.
I get the economy thing, but it seems weird that they'd default to black and not yellow or light grey or sky blue or something easier to see. Something about a black bale spear just seems inherently dangerous.
Everything Attachments will paint the grapple orange or green for $50, but the rear scraper or rake is yellow with no options. Seems like doing yellow standard for them would make sense.
But the obvious solution is for me to just spray paint the outside corners whatever high visibility color I want.
/ Black as standard loader attachment paint? #12
+1, semi gloss black is the easiest to color match for touch ups
/ Black as standard loader attachment paint? #13
OEM no, aftermarket, yes.
/ Black as standard loader attachment paint? #15
Black goes with everything - While I'm cheap and would certainly use a Kubota OEM bucket if I could find one at a really good price, and I wouldn't paint it, it would sure look odd with my blue tractor. Everyone would think I had a Mercum. 1 forecast.jpg
/ Black as standard loader attachment paint? #17
In my own blasphemous way, I think all tractors should be J.D. Construction, Cub Cadet, or Case Yellow, with semi-gloss black implements/backhoes/etc....... But, that is why they don't put me in charge.....
/ Black as standard loader attachment paint? #18
Black is just cheaper, hides a lot of sins, and has good coverage qualities ie. one coat usually does it. Better coverage than orange ;-(
BTW My OEM bucket is orange!
2014 Hagie DTS10 Sprayer (A63111)
2014 Hagie DTS10...
78'' SKID STEER BUCKET (A61572)
78'' SKID STEER...
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
Colombo Twin Master (A64119)
Colombo Twin...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
2019 PETERBILT 389 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 389...
