3-Point Hitch Log splitting with a B2630?
   / Log splitting with a B2630? #1
natethegreat
Toronto, Ontario
B2630
Hey All,
First time poster. I am in need of a log splitter and the last thing I want to do is have another small engine to replace. Was thinking about adding remotes to the tractor and buying a hydraulic one. I've be reading and it appears as though I can expect a longer stroke time due to the 5.6gpm coming out the rear, is this going to be very noticeable or should I be ok?
The other question is if we decide its going to be ok, I plan on getting the Kubota remote package. I've seen some conversation around floating valves yea or neh but I am slightly confused. When adding remotes isn't it just the valve that is already on the log splitter that does the work? I do plan on adding one of the factory levers so I can see that I probably want the float for one of them but with regards to the log splitter shouldn't it be fine with a float?
Thanks in advance
   / Log splitting with a B2630? #2
That's half of what a cheap 2 stage pump puts out. I'm guessing you'll be around 30 seconds cycle time for a 4x24 cylinder. I would hate it. My splitter with its dreaded small engine puts out 22 GPM and cycles it's 5x30 cylinder in a little over 10 seconds. I've got a stop to limit the stroke to less than 30" when it's not necessary and they further increases the cycle the time. You can get a PTO pump, but it's quite a bit more expensive than the rear remote opinion. Regardless of the expense tying up your only tractor to power a wood splitter is a terrible plan IMO.
Ya the more I read the more I'm realizing I need a stand alone. Even at 18gpm a guy was saying his stand alone does the same stroke almost double as fast. Then comes the other issue of running the tractor constantly at 3500 - 4000rpm.
   / Log splitting with a B2630? #4
I debated this too Natethegreat. My big splitter is pretty tired and I wanted to replace it. I ended up getting a 25 ton Forest King on sale at Tractor Supply for $1000.
It can used horizontal or vertical and has a 5 h.p. Kohler engine on it. A motor like that can be replaced pretty cheap. So like you say....better to wear that out than put hours on your tractor.
   / Log splitting with a B2630? #5
I have no fireplace or use for split wood but I want one!
   / Log splitting with a B2630? #7
As Paystar said... cheaper to purchase splitter parts than Kubota parts...strain factor.
   / Log splitting with a B2630? #9
You are not helping...(wanders off to google wood splitters)
Good plan. When I'm splitting my tractor sits there with the hoe/thumb on one end holding long logs for bucking and/or I'm throwing the split wood right into my bucket to haul it for stacking. Meanwhile, my assistant (DW) is running the splitter and life is good.
The price of a decent splitter is not much more than the remote kit (which you should get anyway). A replacement engine is not much and I do 20 or 30 cord a year with mine (we do a needy person firewood give away program) and I've been running it 12 years without a hitch.
   / Log splitting with a B2630? #10
Stop you guys, I have personal issues with overkill. While I was out this morning spending $800 on a stand for a $600 miter saw...I saw a boat with FOUR large Mercury outboard motors, I nodded in approval!
2023 John Deere 333G for Parts (A56435)
2023 John Deere...
Rooster Artwork (A55758)
Rooster Artwork...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A55973)
2006 Intellistrobe...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
