Bobcat 763 Help
/ Bobcat 763 Help #61
:thumbsup:
Don't over tighten the jam nut, or it will damage the O ring again. :eek:
/ Bobcat 763 Help
Nice job making that socket. Did you cut the hex with a torch? I've done that a few times. Glad you got it out.
Thanks for the compliment. I drilled along the perimeter of the hex using a 1/8" bit, then used a chisel to punch out the center and finished up by using an end mill in the milling machine. It worked well.
:thumbsup:
Thanks for the tip. I have it installed and it doesn't appear to be leaking. I'm guessing it is torqued to about 20 to 25 ft/lbs. Just a guess though. Sure hope I never have to do this again but if I do it should not be anywhere near as hard to get off.
VOLVO L330C GP Bucket (A68134)
VOLVO L330C GP...
2013 Dodge Durango SUV (A66738)
2013 Dodge Durango...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
Power King Tractor
Power King Tractor
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
WACKER NEUSON LTN6 LIGHT TOWER (A65056)
WACKER NEUSON LTN6...
