Snow blower performance
/ Snow blower performance #61
Well, as usual, I'm late to the party... I'm still going to suggest welding some 3/16" strap to the blades... make the pieces all the same length and width so balance isn't screwed up... NOW .... usually the impeller is not centered in the housing... So, when welding the plates in position, be sure you measure plate placement where the impeller main shaft is closest to the housing where you put the new 14 gauge liner... I would leave about 1/16" gap at the closest point of the housing... Make sure the impeller shaft bearing is not sloppy.. that could have disastrous effects on the impeller modification.. You could even modify the outboard edge of the newly installed plate to have the cup effect of the one impeller suggested in one of the posts... I'm thinking I may make that modification to my new blower...
Thanks for the suggestions. I have it exactly to about a 1/16” from the tightest spot of the housing. And that’s why I’m only doing one of the blades at a time. So I can fit it one perfectly. I thought about trying to modify the impeller. But I would then want to balance it and since I can’t remove it I figured I better just leave it the way it is. Between relining the housing, getting the clearance down to a 1/16 and adding the triangle piece on the upper left hand side of the opening I think the performance will improve. If not she will be for sale!
/ Snow blower performance #63
If you hurry and get all this done, we won't have to wait until next winter to see the results...
/ Snow blower performance #64
Dan, looks like you did a nice job relining that drum. Well done!
Be sure to let us know how it works! Are you guys getting hit with the big storm that we are in the Northeast starting tonight/tomorrow?
On a side note- I have to build an impeller kit for my blower. I've got the power to run it, but it just doesn't throw far enough for my needs. and the drum gets caked up with sticky wet snow. I figure if I can use some thick conveyor belt material and close up that gap, it won't plug up as much. Mine's a 6' McKee Sno-Lander 520.
No storm here. Mostly sleet and was snowing a little bit ago. But won’t accumulate. Going to finish the 3 other blades on the impeller and sandblast and get it painted and ready for storage until next year. Hope we ha e a good snow fall next year to see how it works.
/ Snow blower performance #66
Ah nuts. Current forecast for my area is showing 8-18" inches. It's gonna be in the mid thirties, so chances are it'll be wet/heavy. I'll probably just push it with the loader mounted plow.
Lucky your to be able to play In That snow. I converted a plow to Go on my loader also. Almost wish I would have just adapted it to mount on the tractor frame instead of loader. But it works nice.
/ Snow blower performance #68
Yeah, I frame mounted mine and am really pleased with the operation.
I initially made it manually angled but welded it permanently into a pusher configuration as I lacked the weight to push snow sideways. I did add a wing to one side however so when pushing it only slops to one side.
I only push in light snow situations and use the blower when over 4" or so.
While always on my 'to do list' is to close up the fan to wall gaps, that or make up a 4 blade fan.
/ Snow blower performance #69
I'd love to frame mount mine, but my machine is a '64, no quick attach anything. And it's got a front mounted gear pump for the loader, so I'd need to figure a way to loop the lines. If I built a sort of carriage/sling out of 6x6 posts, installed hydraulic quick disconnects etc.. I might be able to remove the loader 'easily.'
But I do use the loader frequently in the snow, so I still like the option. Besides that it's a 2wd machine and it helps me get un-stuck when I do something foolish haha!
/ Snow blower performance #70
Just checked the impeller spacing on my rear mounted Kubota 2789 blower and it is about 3/8 inch. I've been using the blower in some pretty heavy snow for 8 or 9 years. I often hit gravel and that might account for any impeller wear. I have lots of videos on Youtube showing the blower operating on my BX25.
If I forget to have the engine pretty well wide open the impeller will jam with (wet) snow and shear the pto pin.
Most of my videos have been posted on TBN
/ Snow blower performance #71
If you look at newer blowers most have a part of the circular fan opening blocked off near where the snow enters the chute
You can experiment with your blower by adding this triangle piece. Make it from plywood to start with so you can fine tune the size.
Bolt the piece on, don't weld it on when you get to the correct size as it must be removed to remove the fan should you ever need to.
Dave M7040
Dave M7040
Thanks for the suggestion, I already have it on there. I will post some pictures.
Just need to wrap a few things up and sandblast prime and paint the blower.
/ Snow blower performance #73
I've seen this picture before, but I still can't make heads or tails out of exactly what it is. I don't get any perspective/depth perception as to the placement.
Here is a picture. All blades are clearanced to the new smooth housing to about a 1/16
Front plate is on with 4 bolts.
Just need a few more touches and it will be ready for sandblast and paint.
/ Snow blower performance #75
The triangle wedge that is welded to the upper left portion of the impeller throat is there to keep the snow
inside the impeller housing so it can be ejected through the chute and spout.
If you look closely you will see that the base of the snow blower chute is directly above the left side of the impeller housing directly above the triangle of plate steel, and yes there is room to remove and install the impeller in the event the impeller is damaged or the snow blower drive train needs to be removed.
Toro has modified one model of its walk behind 2 stages with a spill over opening which essentially allows the
snow to be thrown out to prevent the impeller from plugging.
Single stages are so much simpler to own and operate
/ Snow blower performance #76
When BERTA was making snow blowers for 4 wheel mules they had three sizes and they were built tough as nails. they used three different chute and spout designs with hydraulic rotation of the chute and hydraulic control of the 2 chute types that used them. The third chute was a curved type that they offered had no adjustable spout making it very simple to use with no extra hydraulics.
It had two gear box drive speeds mounted on the snow caster and you could order it with adjustable skid pads or steel wheels set at one height.
The smallest unit was 4 feet wide and could be run by an 18-23 horsepower sub compact tractor.
The left and right cross augers were both solid in shape and had serrated flighting.
The serrated flights were fully welded to the steel tube with no openings creating an auger.
The center section with its worm to spur gearbox drive was protected with a wrap around steel weldment that was circular in shape and did not prevent the snow from entering the impeller housing.
/ Snow blower performance #77
The gear box shaft extends a long way from the back of the fan housing to support the fan. The fan will not come off and out of the enclosure with the triangle in place
The only way to remove the fan is to pull the gear box back!!
This dimension spec from COMER shows the fan shaft of the gearbox is 6-1/4"
The fan is 10" deep x 30" diameter.
The fan has to move forward approx 6" to clear the gearbox shaft
That is why more expensive blowers have the triangle restrictor bolted instead of welded.
Dave M7040
/ Snow blower performance #78
I just want to follow this thread.....
In one of the pictures I noticed that the inside of the chute was very rough. The paint was pitted and rusty. Along with impeller clearance I'm thinking that the roughness inside of the chute is also part of the problem.
I have a JD 59 for the front of my tractor and even though the impeller clearances are on the high side I can still throw snow 30-40 feet. The inside of the chute is shinny metal as the paint is all worn off.
Yes the chute was pretty rusty and pitted. The blower sat for awhile. It will be all sandblasted and primed. Sanded smooth then painted shiny kubota oranage. Will then wax it with snow ski wax. The blower should work good after all the fixes are done.
/ Snow blower performance #80
Going to all that work I'd suggest, if U can, to line the chute with some plastic that you could heat and mould to fit.
Even a strip lining the curved backside of the chute will help greatly.
I had some very thick 8" wide PVC tape that I lined mine with. Made a fair difference until the tape shredded from stones.
Waxes and oils just don't last.
When I store my blower for the summer I 'rattle can' spray all the bare metal parts as even the thin spray can coating is enough to prevent rusting over summer. Naturally first blowing event removes the paint but there is no pitted rusty metal to deter snow movement out of the chute.
Ice and snow will grip on the rough metal but not on a slick surface.
2008 New Holland T2420 (A62177)
2008 New Holland...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2010 Honda Accord Passenger Car, VIN # 5KBCP3F82AB012291 (A61165)
2010 Honda Accord...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
