3 Pt. Hitch - Extra Tractor Weight ?
/ 3 Pt. Hitch - Extra Tractor Weight ? #1
Buckchaser
Member
Bradford PA
Massey F 1734
Other than filling the rear tires or building a homemade 3 point hitch weight , does anyone have suggestions on a simple 3pt. attachment to add extra weight to the rear of my tractor ? I've seen plenty of homemade things like concrete filled barrels etc.. I just want something to buy to hook on for extra weight that's easy to attach. Thanks for the help anyone.
/ 3 Pt. Hitch - Extra Tractor Weight ? #2
I have no idea what you will be doing with your Massey. I have several implements that serve double duty - Rhino 950 rear blade @ 1035 pounds - Land Pride GS2584(LPGS) @ 796 pounds - Bush Hog roll over box blade(ROBB) @ 710 pounds. I guess I could also say my Wallenstein BX62S chipper @ 770 pounds - although I've never considered using the chipper as extra rear weight.
I NEVER use my tractor without something hanging on the 3-point. Its alway the Rhino rear blade when I'm using the FEL with either the bucket or grapple.
Added note - my rear tires are filled with Rimguard, also, @ 750 pound per tire.
/ 3 Pt. Hitch - Extra Tractor Weight ? #3
Do you weld, and do you have access to scrap steel? If so, you can glue together a steel box and fill it with concrete, sand, gravel or whatever you have.
Hooking a 3-point item is all about the same, doesn't matter if you buy it or make it. It is a 3-5 minute task, so the "easy to attach" part of your statement is fairly irrelevant. It's all the same.
I use loaded tires combined with whatever I need or last left on the rear... backhoe, grader blade or box blade. I have never tried just loaded tires.
/ 3 Pt. Hitch - Extra Tractor Weight ? #4
A carryall, but you'll have to build something on it to allow you to carry something in it. It won't stick out as far as a bush hog.
Ralph
/ 3 Pt. Hitch - Extra Tractor Weight ? #5
Titan weight box is the lowest cost, ready-made, single purpose option.
I concur with OOSIK that an implement mounted on the Three Point Hitch is the best additional weight.
My rear tires are filled only with air. The three implements I use for ballast most are a Cultipacker/600 pounds, Rollover Box Blade/700 pounds and TR3 Rake/ 800 pounds.
TITAN: titan ballast box - Google Search
/ 3 Pt. Hitch - Extra Tractor Weight ? #6
I have kept my hoe installed for ballast but I'm going to build a dumping carryall box that will have a 4" concrete "floor" on it to provide about 800' of ballast hanging on my TPH. It will be essentially like the Titan box but larger and like this. It will give me the weight I need and won't be anything close to as "out there" as my backhoe is and will give me a lot of hauling ability and places to put stuff when working away from the barn.
Kind of like this. Of course, one needs to be able to fabricate to use it but it will be as easy to mount as any TPH implement and will be exceedingly useful for my purposes anyway. Just hanging weight on the TPH does the job but serves no other purpose - this will serve many.
/ 3 Pt. Hitch - Extra Tractor Weight ? #7
I don't know why it won't let me post my photo properly nor why it names it the old name "clamp on" but that is a pic of the box similar to what I will be building.
I do have a Brush hog and Tiller.. I could use the tiller for the extra weight if I needed to, but may want to consider that Titan ballast box..It does have a couple slots for shovel, pry bar etc..which is kind of handy.. Thanks everyone for the input..
Great Idea also..More uses with this attachment..Something for me to consider also.. Thanks.
/ 3 Pt. Hitch - Extra Tractor Weight ? #10
I think my point is - if you hang something out back - find or make something that will have multiple uses. I LIKE the projects I've seen on TBN for ballast boxes that will have the weight but also carry multiple tools - hoes, shovels, pry bars, chain saws,etc, etc.
If you burn wood - a 3-point wood transport box would be nice.
/ 3 Pt. Hitch - Extra Tractor Weight ? #11
A box scraper attached via a quick hitch is a nice amount of weight, doesn't stick out too far, and useful for more than just weight. Like others, I don't have a dedicated weight box because I just keep an implement installed.
I could see use of a weight box if you need to move in extremely tight quarters, or if you simply have no use for any other 3pt implement. For typical users, a box blade or rough mower is a good weight when not in use.
/ 3 Pt. Hitch - Extra Tractor Weight ? #12
A Titan ballast box and filled tires has worked the best for me. In the past I would use a box blade or backhoe but inevitably they would hang up or strike something while working in tight quarters. I filled the ballast box about half way with iron which leaves plenty of room for tools, chains etc which wasn't the case with the hoe or blade.
/ 3 Pt. Hitch - Extra Tractor Weight ? #13
I built a 3pt ballast box out of an old leaky 60 gallon air compressor. I rarely if ever use it. I usually have another impliment on. Every other impliment is more awkward & bulkier, than the tank by a fair bit. But it's never been enough of a problem to use dedicated ballast over a 3pt impliment I'll end up using for some task as well as ballast.
/ 3 Pt. Hitch - Extra Tractor Weight ? #14
A man I know in my town made a 3 pt "bar", not sure exactly what you would call it, but the John Deere suitcase weights just hook to it. Pretty neat, and real compact. Not sure you really get much for the dollar though..When I needed weight I just got a 3pt ballast box, seem to think it was only a few hundred dollars. I fill it with rip rap, so the weight can be adjusted.
/ 3 Pt. Hitch - Extra Tractor Weight ? #15
This is what I currently use for f I don't have the box blade on.
Each disc is 64 lbs. I have 10 more discs but haven't gotten around to using them to up the weight as the 650 lbs I have approx now seems to be working well.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Case skid steer wheels and tires (A63689)
Case skid steer...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
