3pt Carry All
/ 3pt Carry All #1
Waynebob126
Pearl, MS
LS XG3037
Got my 3pt carry all finished today. Still need to add some storage type attachments but using it as is already.
/ 3pt Carry All #4
Very nice. :thumbsup: You will find it very handy for all kinds of stuff.
gg
/ 3pt Carry All #5
Turned out nice.
I've noticed a few others that cut the sides at an angle instead of running flush vertically.
Is there a reason that I'm missing. It seems like you could haul more if the side boards were all extended flush.
/ 3pt Carry All
Turned out nice.
I hope the angle will make it easier to reach over the sides
/ 3pt Carry All #9
Nice. Wish I'd thought of that. Needed mine fully enclosed to haul mulch down to the big garden that I no longer use.
Could take yours, add hinges at the outer bottom, with pins in them, and a matching 2nd part to enclose it. Just put latches to hold the 2 parts together. Remove hinge pins to get what you have.
Ralph
/ 3pt Carry All
I owe MMfrompa for the design. Got the dims from his YouTube channel. I have decided that there are 100’s of ways to customize these things
/ 3pt Carry All #11
Very nice.
I made my own and just copied a picture I saw on TSC web site.
What thickness did you use for steel?
/ 3pt Carry All #12
I built mine with no sides at all. Makes it easy to carry long stuff. I mounted hooks on the front of the headboard and under the rear deck and keep a length of small nylon rope which works great for tying down loads of firewood, which I stack crosswise in two or three rows. Hooks visible front and rear here:
/ 3pt Carry All
Very nice.
I bought the Countyline carry all from TSC. Added PT lumber on it and painted to match LS tractor
/ 3pt Carry All #14
Just did mine this last week. Still haven’t decided on how I am gonna do my sides. IMG_1266.JPG
/ 3pt Carry All #15
Ahh okay. Do you have a guess what they used?
I made mine from 5/16 3x3 angle iron with 5/8th thick mounting points.
/ 3pt Carry All #18
Looking great.
After MMM is Carry All probably the most used implement for me.
/ 3pt Carry All #19
Another useful possibility is removable stake sides
gg
/ 3pt Carry All #20
Thanks for you post - got me thinking.
I'm going to have to give some thought to making one of these and the way I handle my work. I have a 4n1 bucket that is on my tractor maybe 20% of the time and it is quite heavy. Most of the time I keep my forks on for toting things around often up to the maximum lift capacity of the FEL. I keep my backhoe on almost all the time, mostly for ballast but I also often find a handy use for it and it's thumb from time to time so it is not just dead weight.
I really like the idea of being able to carry stuff though and lift from the rear as well - I could incorporate ballast into the box as well (BTW my tires are loaded but they get really light with the 4n1 on and the BH off).
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2016 Ford F-150...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
